[PATCH] aarch64: add qemu bsps for cortex-a72
Gedare Bloom
gedare at rtems.org
Tue Jun 8 20:32:38 UTC 2021
The a72 BSPs are identical to the a53 BSPs just changing a53 to a72.
bsps/aarch64/a72/console/console.c | 69 +++++++++++++++++
bsps/aarch64/a72/include/bsp.h | 74 +++++++++++++++++++
bsps/aarch64/a72/include/bsp/irq.h | 67 +++++++++++++++++
bsps/aarch64/a72/include/tm27.h | 46 ++++++++++++
bsps/aarch64/a72/start/bspstart.c | 49 ++++++++++++
bsps/aarch64/a72/start/bspstarthooks.c | 50 +++++++++++++
spec/build/bsps/aarch64/a72/abi.yml | 22 ++++++
.../bsps/aarch64/a72/bspa72ilp32qemu.yml | 19 +++++
.../build/bsps/aarch64/a72/bspa72lp64qemu.yml | 19 +++++
spec/build/bsps/aarch64/a72/grp.yml | 42 +++++++++++
.../build/bsps/aarch64/a72/linkcmds_ilp32.yml | 71 ++++++++++++++++++
spec/build/bsps/aarch64/a72/linkcmds_lp64.yml | 71 ++++++++++++++++++
spec/build/bsps/aarch64/a72/obj.yml | 37 ++++++++++
spec/build/bsps/aarch64/a72/optloadoff.yml | 18 +++++
spec/build/bsps/aarch64/a72/optnocachelen.yml | 18 +++++
spec/build/bsps/aarch64/a72/optramlen.yml | 18 +++++
spec/build/bsps/aarch64/a72/optramori.yml | 18 +++++
spec/build/bsps/aarch64/a72/tsta72.yml | 41 ++++++++++
18 files changed, 749 insertions(+)
create mode 100644 bsps/aarch64/a72/console/console.c
create mode 100644 bsps/aarch64/a72/include/bsp.h
create mode 100644 bsps/aarch64/a72/include/bsp/irq.h
create mode 100644 bsps/aarch64/a72/include/tm27.h
create mode 100644 bsps/aarch64/a72/start/bspstart.c
create mode 100644 bsps/aarch64/a72/start/bspstarthooks.c
create mode 100644 spec/build/bsps/aarch64/a72/abi.yml
create mode 100644 spec/build/bsps/aarch64/a72/bspa72ilp32qemu.yml
create mode 100644 spec/build/bsps/aarch64/a72/bspa72lp64qemu.yml
create mode 100644 spec/build/bsps/aarch64/a72/grp.yml
create mode 100644 spec/build/bsps/aarch64/a72/linkcmds_ilp32.yml
create mode 100644 spec/build/bsps/aarch64/a72/linkcmds_lp64.yml
create mode 100644 spec/build/bsps/aarch64/a72/obj.yml
create mode 100644 spec/build/bsps/aarch64/a72/optloadoff.yml
create mode 100644 spec/build/bsps/aarch64/a72/optnocachelen.yml
create mode 100644 spec/build/bsps/aarch64/a72/optramlen.yml
create mode 100644 spec/build/bsps/aarch64/a72/optramori.yml
create mode 100644 spec/build/bsps/aarch64/a72/tsta72.yml
diff --git a/bsps/aarch64/a72/console/console.c b/bsps/aarch64/a72/console/console.c
new file mode 100644
index 0000000000..08532d68cd
--- /dev/null
+++ b/bsps/aarch64/a72/console/console.c
@@ -0,0 +1,69 @@
+ * @file
+ * @ingroup RTEMSBSPsAArch64A72
+ * @brief Console Configuration
+ * Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <rtems/bspIo.h>
+#include <bsp.h>
+#include <dev/serial/arm-pl011.h>
+#include <bsp/console-termios.h>
+#include <bspopts.h>
+arm_pl011_context a72_qemu_vpl011_context = {
+ .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
+ .regs = (volatile pl011 *) BSP_A72_QEMU_VPL011_BASE,
+ .initial_baud = 115200
+const console_device console_device_table[] = {
+ .device_file = "/dev/ttyS0",
+ .probe = console_device_probe_default,
+ .handler = &arm_pl011_fns,
+ .context = &a72_qemu_vpl011_context.base
+const size_t console_device_count = RTEMS_ARRAY_SIZE(console_device_table);
+static void output_char( char c )
+ arm_pl011_write_polled(&a72_qemu_vpl011_context.base, c);
+BSP_output_char_function_type BSP_output_char = output_char;
+BSP_polling_getchar_function_type BSP_poll_char = NULL;
diff --git a/bsps/aarch64/a72/include/bsp.h b/bsps/aarch64/a72/include/bsp.h
index 0000000000..7ae9bd8239
--- /dev/null
+++ b/bsps/aarch64/a72/include/bsp.h
@@ -0,0 +1,74 @@
+ * @file
+ * @brief Core BSP definitions
+ * are met:
+#ifndef LIBBSP_AARCH64_A72_QEMU_BSP_H
+#define LIBBSP_AARCH64_A72_QEMU_BSP_H
+ * @addtogroup RTEMSBSPsAArch64
+#ifndef ASM
+#include <bsp/default-initial-extension.h>
+#include <bsp/start.h>
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#define BSP_ARM_GIC_CPUIF_BASE 0x08010000
+#define BSP_ARM_GIC_DIST_BASE 0x08000000
+#define BSP_ARM_GIC_REDIST_BASE 0x080A0000
+#define BSP_A72_QEMU_VPL011_BASE 0x9000000
+#define BSP_A72_QEMU_VPL011_LENGTH 0x1000
+#ifdef __cplusplus
+#endif /* ASM */
+#endif /* LIBBSP_AARCH64_A72_QEMU_BSP_H */
diff --git a/bsps/aarch64/a72/include/bsp/irq.h b/bsps/aarch64/a72/include/bsp/irq.h
index 0000000000..c3de523d48
--- /dev/null
+++ b/bsps/aarch64/a72/include/bsp/irq.h
@@ -0,0 +1,67 @@
+ * @file
+ * @brief BSP IRQ definitions
+ * are met:
+#ifndef LIBBSP_AARCH64_A72_IRQ_H
+#define LIBBSP_AARCH64_A72_IRQ_H
+#ifndef ASM
+#include <rtems/irq.h>
+#include <rtems/irq-extension.h>
+#include <dev/irq/arm-gic-irq.h>
+#ifdef __cplusplus
+extern "C" {
+#define BSP_INTERRUPT_VECTOR_MIN 0
+#define BSP_INTERRUPT_VECTOR_MAX 1023
+/* Interrupts vectors */
+#define BSP_TIMER_VIRT_PPI 27
+#define BSP_TIMER_PHYS_NS_PPI 30
+#define BSP_VPL011_SPI 32
+#ifdef __cplusplus
+#endif /* ASM */
+#endif /* LIBBSP_AARCH64_A72_IRQ_H */
diff --git a/bsps/aarch64/a72/include/tm27.h b/bsps/aarch64/a72/include/tm27.h
index 0000000000..f31396e8bd
--- /dev/null
+++ b/bsps/aarch64/a72/include/tm27.h
@@ -0,0 +1,46 @@
+ * @file
+ * @brief BSP tm27 header
+ * are met:
+#ifndef _RTEMS_TMTEST27
+#error "This is an RTEMS internal file you must not include directly."
+#endif
+#ifndef __tm27_h
+#define __tm27_h
+#include <dev/irq/arm-gic-tm27.h>
+#endif /* __tm27_h */
diff --git a/bsps/aarch64/a72/start/bspstart.c b/bsps/aarch64/a72/start/bspstart.c
index 0000000000..2a8a4ac8d8
--- /dev/null
+++ b/bsps/aarch64/a72/start/bspstart.c
@@ -0,0 +1,49 @@
+ * @file
+ * @ingroup RTEMSBSPsAArch64A53
+ * @brief BSP Startup
+ * are met:
+#include <bsp.h>
+#include <bsp/bootcard.h>
+#include <bsp/irq-generic.h>
+#include <bsp/linker-symbols.h>
+void bsp_start( void )
+ bsp_interrupt_initialize();
+ rtems_cache_coherent_add_area(
+ bsp_section_nocacheheap_begin,
+ (uintptr_t) bsp_section_nocacheheap_size
diff --git a/bsps/aarch64/a72/start/bspstarthooks.c b/bsps/aarch64/a72/start/bspstarthooks.c
index 0000000000..20d3bc6e70
--- /dev/null
+++ b/bsps/aarch64/a72/start/bspstarthooks.c
@@ -0,0 +1,50 @@
+ * @file
+ * @brief BSP Startup Hooks
+ * are met:
+#include <bsp.h>
+BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
+ /* Do nothing */
+BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
+ AArch64_start_set_vector_base();
+ bsp_start_copy_sections();
+ bsp_start_clear_bss();
diff --git a/spec/build/bsps/aarch64/a72/abi.yml b/spec/build/bsps/aarch64/a72/abi.yml
index 0000000000..9b9438648c
--- /dev/null
+++ b/spec/build/bsps/aarch64/a72/abi.yml
@@ -0,0 +1,22 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-string: null
+- split: null
+- env-append: null
+build-type: option
+copyrights:
+- Copyright (C) 2020 On-Line Applications Research (OAR)
+default:
+- -mcpu=cortex-a72
+default-by-variant:
+- value:
+ - -mcpu=cortex-a72
+ - -mabi=ilp32
+ variants:
+ - aarch64/a72_ilp32_qemu
+description: |
+ ABI flags
+enabled-by: true
+links: []
+name: ABI_FLAGS
+type: build
diff --git a/spec/build/bsps/aarch64/a72/bspa72ilp32qemu.yml b/spec/build/bsps/aarch64/a72/bspa72ilp32qemu.yml
index 0000000000..2fe1857701
--- /dev/null
+++ b/spec/build/bsps/aarch64/a72/bspa72ilp32qemu.yml
@@ -0,0 +1,19 @@
+arch: aarch64
+bsp: a72_ilp32_qemu
+build-type: bsp
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+family: a72
+includes: []
+install: []
+links:
+- role: build-dependency
+ uid: grp
+ uid: linkcmds_ilp32
+source: []
+type: build
diff --git a/spec/build/bsps/aarch64/a72/bspa72lp64qemu.yml b/spec/build/bsps/aarch64/a72/bspa72lp64qemu.yml
index 0000000000..ccfca87d2e
--- /dev/null
+++ b/spec/build/bsps/aarch64/a72/bspa72lp64qemu.yml
@@ -0,0 +1,19 @@
+arch: aarch64
+bsp: a72_lp64_qemu
+build-type: bsp
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+family: a72
+includes: []
+install: []
+links:
+ uid: grp
+ uid: linkcmds_lp64
+source: []
+type: build
diff --git a/spec/build/bsps/aarch64/a72/grp.yml b/spec/build/bsps/aarch64/a72/grp.yml
index 0000000000..0f3e717a94
--- /dev/null
+++ b/spec/build/bsps/aarch64/a72/grp.yml
@@ -0,0 +1,42 @@
+build-type: group
+copyrights:
+enabled-by: true
+includes: []
+install: []
+ldflags: []
+links:
+ uid: ../grp
+ uid: ../start
+ uid: abi
+ uid: obj
+ uid: optloadoff
+ uid: optnocachelen
+ uid: optramlen
+ uid: optramori
+ uid: tsta72
+ uid: ../../obj
+ uid: ../../objirq
+ uid: ../../optcachedata
+ uid: ../../optcacheinst
+ uid: ../../opto2
+ uid: ../../bspopts
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/bsps/aarch64/a72/linkcmds_ilp32.yml b/spec/build/bsps/aarch64/a72/linkcmds_ilp32.yml
index 0000000000..13ff5021db
--- /dev/null
+++ b/spec/build/bsps/aarch64/a72/linkcmds_ilp32.yml
@@ -0,0 +1,71 @@
+build-type: config-file
+content: |
+ /* SPDX-License-Identifier: BSD-2-Clause */
+ * are met:
+ MEMORY {
+ RAM : ORIGIN = ${BSP_A72_RAM_BASE} + ${BSP_A72_LOAD_OFFSET}, LENGTH = ${BSP_A72_RAM_LENGTH} - ${BSP_A72_LOAD_OFFSET} - ${BSP_A72_NOCACHE_LENGTH}
+ NOCACHE : ORIGIN = ${BSP_A72_RAM_BASE} + ${BSP_A72_RAM_LENGTH} - ${BSP_A72_NOCACHE_LENGTH}, LENGTH = ${BSP_A72_NOCACHE_LENGTH}
+ REGION_ALIAS ("REGION_START", RAM);
+ REGION_ALIAS ("REGION_VECTOR", RAM);
+ REGION_ALIAS ("REGION_TEXT", RAM);
+ REGION_ALIAS ("REGION_TEXT_LOAD", RAM);
+ REGION_ALIAS ("REGION_RODATA", RAM);
+ REGION_ALIAS ("REGION_RODATA_LOAD", RAM);
+ REGION_ALIAS ("REGION_DATA", RAM);
+ REGION_ALIAS ("REGION_DATA_LOAD", RAM);
+ REGION_ALIAS ("REGION_FAST_TEXT", RAM);
+ REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
+ REGION_ALIAS ("REGION_FAST_DATA", RAM);
+ REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
+ REGION_ALIAS ("REGION_BSS", RAM);
+ REGION_ALIAS ("REGION_WORK", RAM);
+ REGION_ALIAS ("REGION_STACK", RAM);
+ REGION_ALIAS ("REGION_NOCACHE", NOCACHE);
+ REGION_ALIAS ("REGION_NOCACHE_LOAD", NOCACHE);
+ bsp_stack_exception_size = DEFINED (bsp_stack_exception_size) ? bsp_stack_exception_size : 1024;
+ bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1M;
+ bsp_vector_table_in_start_section = 1;
+ OUTPUT_FORMAT ("elf32-littleaarch64")
+ OUTPUT_ARCH (aarch64:ilp32)
+ INCLUDE linkcmds.base
+copyrights:
+enabled-by: true
+install-path: ${BSP_LIBDIR}
+links: []
+target: linkcmds
+type: build
diff --git a/spec/build/bsps/aarch64/a72/linkcmds_lp64.yml b/spec/build/bsps/aarch64/a72/linkcmds_lp64.yml
index 0000000000..05daa739ce
--- /dev/null
+++ b/spec/build/bsps/aarch64/a72/linkcmds_lp64.yml
@@ -0,0 +1,71 @@
+content: |
+ * are met:
+ MEMORY {
+ OUTPUT_FORMAT ("elf64-littleaarch64")
+ OUTPUT_ARCH (aarch64)
+copyrights:
+enabled-by: true
+links: []
+target: linkcmds
+type: build
diff --git a/spec/build/bsps/aarch64/a72/obj.yml b/spec/build/bsps/aarch64/a72/obj.yml
index 0000000000..812b21be67
--- /dev/null
+++ b/spec/build/bsps/aarch64/a72/obj.yml
@@ -0,0 +1,37 @@
+build-type: objects
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+install:
+- destination: ${BSP_INCLUDEDIR}
+ source:
+ - bsps/aarch64/a72/include/bsp.h
+ - bsps/aarch64/a72/include/tm27.h
+- destination: ${BSP_INCLUDEDIR}/bsp
+ source:
+ - bsps/aarch64/a72/include/bsp/irq.h
+links: []
+source:
+- bsps/aarch64/a72/console/console.c
+- bsps/aarch64/a72/start/bspstart.c
+- bsps/aarch64/a72/start/bspstarthooks.c
+- bsps/aarch64/shared/cache/cache.c
+- bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
+- bsps/shared/dev/btimer/btimer-cpucounter.c
+- bsps/shared/dev/clock/arm-generic-timer.c
+- bsps/shared/dev/getentropy/getentropy-cpucounter.c
+- bsps/shared/dev/irq/arm-gicv3.c
+- bsps/shared/dev/serial/console-termios-init.c
+- bsps/shared/dev/serial/console-termios.c
+- bsps/shared/irq/irq-default-handler.c
+- bsps/shared/start/bspfatal-default.c
+- bsps/shared/start/bspgetworkarea-default.c
+- bsps/shared/start/bspreset-arm-psci.c
+- bsps/shared/start/gettargethash-default.c
+- bsps/shared/start/sbrk.c
+type: build
diff --git a/spec/build/bsps/aarch64/a72/optloadoff.yml b/spec/build/bsps/aarch64/a72/optloadoff.yml
index 0000000000..cbe390c2f6
--- /dev/null
+++ b/spec/build/bsps/aarch64/a72/optloadoff.yml
@@ -0,0 +1,18 @@
+actions:
+- get-integer: null
+- assert-uint32: null
+- env-assign: null
+- format-and-define: null
+build-type: option
+copyrights:
+default: 32768
+default-by-variant: []
+description: |
+ offset of RAM region from memory area base
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_A72_LOAD_OFFSET
+type: build
diff --git a/spec/build/bsps/aarch64/a72/optnocachelen.yml b/spec/build/bsps/aarch64/a72/optnocachelen.yml
index 0000000000..47d55be601
--- /dev/null
+++ b/spec/build/bsps/aarch64/a72/optnocachelen.yml
@@ -0,0 +1,18 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default: 1048576
+description: |
+ length of nocache RAM region
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_A72_NOCACHE_LENGTH
+type: build
diff --git a/spec/build/bsps/aarch64/a72/optramlen.yml b/spec/build/bsps/aarch64/a72/optramlen.yml
index 0000000000..b18ef2ff08
--- /dev/null
+++ b/spec/build/bsps/aarch64/a72/optramlen.yml
@@ -0,0 +1,18 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default: 0x8000000
+description: |
+ length of memory area available to the BSP
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_A72_RAM_LENGTH
+type: build
diff --git a/spec/build/bsps/aarch64/a72/optramori.yml b/spec/build/bsps/aarch64/a72/optramori.yml
index 0000000000..be92685f83
--- /dev/null
+++ b/spec/build/bsps/aarch64/a72/optramori.yml
@@ -0,0 +1,18 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default: 1073741824
+description: |
+ base address of memory area available to the BSP
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_A72_RAM_BASE
+type: build
diff --git a/spec/build/bsps/aarch64/a72/tsta72.yml b/spec/build/bsps/aarch64/a72/tsta72.yml
index 0000000000..6876d23f56
--- /dev/null
+++ b/spec/build/bsps/aarch64/a72/tsta72.yml
@@ -0,0 +1,41 @@
+actions:
+- set-test-state:
+ # expected to fail, don't compile these
+ minimum: exclude
+ # don't compile due to toolchain issues
+ spconfig01: exclude
+ spmisc01: exclude
+ # tests that are passing intermittently
+ spcpucounter01: indeterminate
+ rtmonuse: indeterminate
+ sp68: indeterminate
+ sp04: indeterminate
+ sp20: indeterminate
+ sp69: indeterminate
+ rtmonusxtimes01: indeterminate
+ spedfsched02: indeterminate
+ spedfsched04: indeterminate
+ psxtimes01: indeterminate
+ sprmsched01: indeterminate
+ sptimecounter02: indeterminate
+ sptimecounter04: indeterminate
+ ttest02: indeterminate
+ # tests that pass nominally, but fail under Qemu when the host is under
+ # heavy load
+ psx12: indeterminate
+ spintrcritical03: indeterminate
+ spintrcritical04: indeterminate
+ spintrcritical05: indeterminate
+build-type: option
+copyrights:
+default: null
+description: ''
+enabled-by: true
+links: []
+type: build
2.25.1
