[PATCH rtems-docs 2/2] user: add bsps/aarch64/a72.rst
Tue Jun 8 20:44:21 UTC 2021
 user/bsps/aarch64/a72.rst  | 35 +++++++++++++++++++++++++++++++++++
 user/bsps/bsps-aarch64.rst |  1 +
 2 files changed, 36 insertions(+)
 create mode 100644 user/bsps/aarch64/a72.rst
diff --git a/user/bsps/aarch64/a72.rst b/user/bsps/aarch64/a72.rst
new file mode 100644
index 0000000..e8e4b3d
--- /dev/null
+++ b/user/bsps/aarch64/a72.rst
@@ -0,0 +1,35 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
+.. _BSP_aarch64_qemu_a72_ilp32:
+.. _BSP_aarch64_qemu_a72_lp64:
+Qemu A72
+This BSP supports two variants, `qemu_a72_ilp32` and `qemu_a72_lp64`. The basic
+hardware initialization is performed by the BSP. These BSPs support the GICv3
+interrupt controller.
+Boot via ELF
+The executable image is booted by Qemu in ELF format.
+Clock Driver
+The clock driver uses the `ARM Generic Timer`.
+Console Driver
+The console driver supports the default Qemu emulated ARM PL011 PrimeCell UART.
+Running Executables
+Executables generated by these BSPs can be run using the following command::
+qemu-system-aarch64 -no-reboot -nographic -serial mon:stdio \
+ -machine virt,gic-version=3 -cpu cortex-a72 -m 4096 -kernel example.exe
diff --git a/user/bsps/bsps-aarch64.rst b/user/bsps/bsps-aarch64.rst
index 0d4b23c..566a750 100644
--- a/user/bsps/bsps-aarch64.rst
+++ b/user/bsps/bsps-aarch64.rst
@@ -6,4 +6,5 @@ aarch64 (AArch64)
 .. include:: aarch64/a53.rst
+.. include:: aarch64/a72.rst
 .. include:: aarch64/xilinx-zynqmp.rst
2.25.1
