[PATCH rtems-docs 2/2] user: add bsps/aarch64/a72.rst
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Jun 9 02:39:45 UTC 2021
Looks good.
On 6/8/2021 15:44, Gedare Bloom wrote:
> user/bsps/aarch64/a72.rst | 35 +++++++++++++++++++++++++++++++++++
> user/bsps/bsps-aarch64.rst | 1 +
> 2 files changed, 36 insertions(+)
> create mode 100644 user/bsps/aarch64/a72.rst
> diff --git a/user/bsps/aarch64/a72.rst b/user/bsps/aarch64/a72.rst
> new file mode 100644
> index 0000000..e8e4b3d
> --- /dev/null
> +++ b/user/bsps/aarch64/a72.rst
> @@ -0,0 +1,35 @@
> +.. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
> +.. _BSP_aarch64_qemu_a72_ilp32:
> +.. _BSP_aarch64_qemu_a72_lp64:
> +Qemu A72
> +This BSP supports two variants, `qemu_a72_ilp32` and `qemu_a72_lp64`. The basic
> +hardware initialization is performed by the BSP. These BSPs support the GICv3
> +interrupt controller.
> +Boot via ELF
> +The executable image is booted by Qemu in ELF format.
> +Clock Driver
> +The clock driver uses the `ARM Generic Timer`.
> +Console Driver
> +The console driver supports the default Qemu emulated ARM PL011 PrimeCell UART.
> +Running Executables
> +Executables generated by these BSPs can be run using the following command::
> +qemu-system-aarch64 -no-reboot -nographic -serial mon:stdio \
> + -machine virt,gic-version=3 -cpu cortex-a72 -m 4096 -kernel example.exe
> diff --git a/user/bsps/bsps-aarch64.rst b/user/bsps/bsps-aarch64.rst
> index 0d4b23c..566a750 100644
> --- a/user/bsps/bsps-aarch64.rst
> +++ b/user/bsps/bsps-aarch64.rst
> @@ -6,4 +6,5 @@ aarch64 (AArch64)
> .. include:: aarch64/a53.rst
> +.. include:: aarch64/a72.rst
> .. include:: aarch64/xilinx-zynqmp.rst
