[PATCH 4/4] Add test smpstrongapa03
Richi Dubey
richidubey at gmail.com
Wed Jun 9 07:39:51 UTC 2021
spec/build/testsuites/smptests/grp.yml | 2 +
.../testsuites/smptests/smpstrongapa03.yml | 21 +
testsuites/smptests/smpstrongapa03/init.c | 358 ++++++++++++++++++
.../smpstrongapa03/smpstrongapa03.doc | 11 +
.../smpstrongapa03/smpstrongapa03.scn | 2 +
5 files changed, 394 insertions(+)
create mode 100644 spec/build/testsuites/smptests/smpstrongapa03.yml
create mode 100644 testsuites/smptests/smpstrongapa03/init.c
create mode 100644 testsuites/smptests/smpstrongapa03/smpstrongapa03.doc
create mode 100644 testsuites/smptests/smpstrongapa03/smpstrongapa03.scn
diff --git a/spec/build/testsuites/smptests/grp.yml b/spec/build/testsuites/smptests/grp.yml
index 6bd58686b0..14b575e058 100644
--- a/spec/build/testsuites/smptests/grp.yml
+++ b/spec/build/testsuites/smptests/grp.yml
@@ -127,6 +127,8 @@ links:
uid: smpstrongapa01
- role: build-dependency
uid: smpstrongapa02
+- role: build-dependency
+ uid: smpstrongapa03
uid: smpswitchextension01
diff --git a/spec/build/testsuites/smptests/smpstrongapa03.yml b/spec/build/testsuites/smptests/smpstrongapa03.yml
new file mode 100644
index 0000000000..50d08216b8
--- /dev/null
+++ b/spec/build/testsuites/smptests/smpstrongapa03.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+- Copyright (C) 2020 Richi Dubey (richidubey at gmail.com)
+cppflags: []
+cxxflags: []
+enabled-by:
+- RTEMS_SMP
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/smptests/smpstrongapa03/init.c
+stlib: []
+target: testsuites/smptests/smpstrongapa03.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/smptests/smpstrongapa03/init.c b/testsuites/smptests/smpstrongapa03/init.c
index 0000000000..8683bbb28e
--- /dev/null
+++ b/testsuites/smptests/smpstrongapa03/init.c
@@ -0,0 +1,358 @@
+ * Copyright (c) 2020 Richi Dubey
+ * All rights reserved.
+ * richidubey at gmail.com
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <tmacros.h>
+#include <rtems.h>
+const char rtems_test_name[] = "SMPSTRONGAPA 3";
+#define CPU_COUNT 3
+#define TASK_COUNT 4
+#define P(i) (UINT32_C(2) + i)
+#define ALL ((UINT32_C(1) << CPU_COUNT) - 1)
+#define A(cpu0, cpu1, cpu2) ((cpu2 << 2) | (cpu1 << 1) | cpu0)
+typedef enum {
+ T0,
+ T1,
+ T2,
+ T3,
+ IDLE
+} task_index;
+typedef struct {
+ enum {
+ KIND_RESET,
+ KIND_SET_PRIORITY,
+ KIND_SET_AFFINITY,
+ KIND_BLOCK,
+ KIND_UNBLOCK
+ } kind;
+ task_index index;
+ struct {
+ rtems_task_priority priority;
+ uint32_t cpu_set;
+ } data;
+ uint8_t expected_cpu_allocations[CPU_COUNT];
+} test_action;
+typedef struct {
+ rtems_id timer_id;
+ rtems_id master_id;
+ rtems_id task_ids[TASK_COUNT];
+ size_t action_index;
+} test_context;
+#define RESET \
+ KIND_RESET, \
+ 0, \
+ { 0 }, \
+ { IDLE, IDLE, IDLE} \
+#define SET_PRIORITY(index, prio, cpu0, cpu1, cpu2) \
+ KIND_SET_PRIORITY, \
+ index, \
+ { .priority = prio }, \
+ { cpu0, cpu1, cpu2 } \
+#define SET_AFFINITY(index, aff, cpu0, cpu1, cpu2) \
+ KIND_SET_AFFINITY, \
+ index, \
+ { .cpu_set = aff }, \
+#define BLOCK(index, cpu0, cpu1, cpu2) \
+ KIND_BLOCK, \
+ index, \
+ { 0 }, \
+#define UNBLOCK(index, cpu0, cpu1, cpu2) \
+ KIND_UNBLOCK, \
+ index, \
+ { 0 }, \
+static const test_action test_actions[] = {
+ RESET,
+ UNBLOCK( T0, T0, IDLE, IDLE),
+ UNBLOCK( T1, T0, T1, IDLE),
+ UNBLOCK( T2, T0, T1, T2),
+ UNBLOCK( T3, T0, T1, T2),
+ SET_PRIORITY( T0, P(0), T0, T1, T2),
+ SET_PRIORITY( T1, P(1), T0, T1, T2),
+ SET_PRIORITY( T3, P(3), T0, T1, T2),
+ * Introduce Task 2 intially with lowest priority to imitate late arrival
+ SET_PRIORITY( T2, P(4), T0, T1, T3),
+ SET_AFFINITY( T0, ALL, T0, T1, T3),
+ SET_AFFINITY( T1, A(0, 1, 1), T0, T1, T3),
+ SET_AFFINITY( T2, A(1, 0, 0), T0, T1, T3),
+ SET_AFFINITY( T3, A(0, 1, 1), T0, T1, T3),
+ * Show that higher priority task gets dislodged from its processor
+ SET_PRIORITY( T2, P(2), T2, T1, T0),
+ RESET
+static test_context test_instance;
+static void set_priority(rtems_id id, rtems_task_priority prio)
+ rtems_status_code sc;
+ sc = rtems_task_set_priority(id, prio, &prio);
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+static void set_affinity(rtems_id id, uint32_t cpu_set_32)
+ cpu_set_t cpu_set;
+ size_t i;
+ CPU_ZERO(&cpu_set);
+ for (i = 0; i < CPU_COUNT; ++i) {
+ if ((cpu_set_32 & (UINT32_C(1) << i)) != 0) {
+ CPU_SET(i, &cpu_set);
+ sc = rtems_task_set_affinity(id, sizeof(cpu_set), &cpu_set);
+static void reset(test_context *ctx)
+ size_t i;
+ for (i = CPU_COUNT; i < TASK_COUNT; ++i) {
+ set_priority(ctx->task_ids[i], P(i));
+ set_affinity(ctx->task_ids[i], ALL);
+ sc = rtems_task_suspend(ctx->task_ids[i]);
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL || sc == RTEMS_ALREADY_SUSPENDED);
+ sc = rtems_task_resume(ctx->task_ids[i]);
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL || sc == RTEMS_INCORRECT_STATE);
+ /* Order the idle threads explicitly */
+ const Per_CPU_Control *c;
+ const Thread_Control *h;
+ c = _Per_CPU_Get_by_index(CPU_COUNT - 1 - i);
+ h = c->heir;
+ sc = rtems_task_suspend(h->Object.id);
+static void check_cpu_allocations(test_context *ctx, const test_action *action)
+ size_t i;
+ task_index e;
+ e = action->expected_cpu_allocations[i];
+ c = _Per_CPU_Get_by_index(i);
+ h = c->heir;
+ if (e != IDLE) {
+ rtems_test_assert(h->Object.id == ctx->task_ids[e]);
+ } else {
+ rtems_test_assert(h->is_idle);
+ * Use a timer to execute the actions, since it runs with thread dispatching
+ * disabled. This is necessary to check the expected processor allocations.
+static void timer(rtems_id id, void *arg)
+ test_context *ctx;
+ size_t i;
+ ctx = arg;
+ i = ctx->action_index;
+ if (i == 0) {
+ sc = rtems_task_suspend(ctx->master_id);
+ if (i < RTEMS_ARRAY_SIZE(test_actions)) {
+ const test_action *action = &test_actions[i];
+ rtems_id task;
+ ctx->action_index = i + 1;
+ task = ctx->task_ids[action->index];
+ switch (action->kind) {
+ case KIND_SET_PRIORITY:
+ set_priority(task, action->data.priority);
+ break;
+ case KIND_SET_AFFINITY:
+ set_affinity(task, action->data.cpu_set);
+ break;
+ case KIND_BLOCK:
+ sc = rtems_task_suspend(task);
+ break;
+ case KIND_UNBLOCK:
+ sc = rtems_task_resume(task);
+ break;
+ default:
+ rtems_test_assert(action->kind == KIND_RESET);
+ reset(ctx);
+ break;
+ check_cpu_allocations(ctx, action);
+ sc = rtems_timer_reset(id);
+ } else {
+ sc = rtems_task_resume(ctx->master_id);
+ sc = rtems_event_transient_send(ctx->master_id);
+static void do_nothing_task(rtems_task_argument arg)
+ (void) arg;
+ while (true) {
+ /* Do nothing */
+static void test(void)
+ size_t i;
+ ctx = &test_instance;
+ ctx->master_id = rtems_task_self();
+ for (i = 0; i < TASK_COUNT; ++i) {
+ sc = rtems_task_create(
+ rtems_build_name(' ', ' ', 'T', '0' + i),
+ P(i),
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &ctx->task_ids[i]
+ sc = rtems_task_start(ctx->task_ids[i], do_nothing_task, 0);
+ sc = rtems_timer_create(
+ rtems_build_name('A', 'C', 'T', 'N'),
+ &ctx->timer_id
+ sc = rtems_timer_fire_after(ctx->timer_id, 1, timer, ctx);
+ sc = rtems_event_transient_receive(RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ sc = rtems_task_delete(ctx->task_ids[i]);
+ sc = rtems_timer_delete(ctx->timer_id);
+static void Init(rtems_task_argument arg)
+ TEST_BEGIN();
+ if (rtems_scheduler_get_processor_maximum() == CPU_COUNT) {
+ test();
+ } else {
+ puts("warning: wrong processor count to run the test");
+ TEST_END();
+ rtems_test_exit(0);
+#define CONFIGURE_MICROSECONDS_PER_TICK 1000
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS (1 + TASK_COUNT)
+#define CONFIGURE_MAXIMUM_TIMERS 1
+#define CONFIGURE_MAXIMUM_PROCESSORS CPU_COUNT
+#define CONFIGURE_SCHEDULER_STRONG_APA
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smpstrongapa03/smpstrongapa03.doc b/testsuites/smptests/smpstrongapa03/smpstrongapa03.doc
index 0000000000..1bb5cfe69a
--- /dev/null
+++ b/testsuites/smptests/smpstrongapa03/smpstrongapa03.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smpstrongapa03
+directives:
+ TBD
+concepts:
+ TBD
diff --git a/testsuites/smptests/smpstrongapa03/smpstrongapa03.scn b/testsuites/smptests/smpstrongapa03/smpstrongapa03.scn
index 0000000000..996da1121f
--- /dev/null
+++ b/testsuites/smptests/smpstrongapa03/smpstrongapa03.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST SMPSTRONGAPA 3 ***
+*** END OF TEST SMPSTRONGAPA 3 ***
2.17.1
