[PATCH v2 2/2] i386: Remove unneeded include header files
Jan.Sommer at dlr.de
Wed Jun 9 18:03:19 UTC 2021
That`s the output I got.
Not sure if it is helpful:
$ git push upstream HEAD~:5-freebsd-12
Counting objects: 4, done.
Delta compression using up to 8 threads.
Compressing objects: 100% (4/4), done.
Writing objects: 100% (4/4), 658 bytes | 658.00 KiB/s, done.
Total 4 (delta 3), reused 0 (delta 0)
remote: 1: mail vc at rtems.org
remote: 2: update github
remote: 4: IRC
remote: usage: <file with rev-list> <repo name without .git>
remote: 5: Buildbot
To ssh://dispatch.rtems.org/data/git/rtems-libbsd.git
a2bc8eba46..9edb1201f6 HEAD~ -> 5-freebsd-12
$ git push upstream HEAD:5-freebsd-12
Counting objects: 7, done.
Compressing objects: 100% (6/6), done.
Writing objects: 100% (7/7), 567 bytes | 567.00 KiB/s, done.
Total 7 (delta 4), reused 0 (delta 0)
remote: 4: IRC
remote: 5: Buildbot
9edb1201f6..5c1b99e4d2 HEAD -> 5-freebsd-12
> -----Original Message-----
> From: Gedare Bloom <gedare at rtems.org>
> Sent: Wednesday, June 9, 2021 7:59 PM
> To: Sommer, Jan <Jan.Sommer at dlr.de>; Amar Takhar
> <verm at darkbeer.org>
> Cc: Chris Johns <chrisj at rtems.org>; devel at rtems.org
> Subject: Re: [PATCH v2 2/2] i386: Remove unneeded include header files
> On Wed, Jun 9, 2021 at 10:51 AM <Jan.Sommer at dlr.de> wrote:
> > Thanks. Pushed to master, 5-freebsd-12 and 6-freebsd-12.
> > Short question: Does the buildbot recognize the pushes to rtems-libbsd/5-
> freebsd-12 and update the ticket?
> > I added the ticket number to the commit description, but the ticket has not
> been updated.
> Do you still have the terminal output from running git-push?
> The git side looks ok, but I can't check the trac end.
> > Best regards,
> > Jan
> > > From: Chris Johns <chrisj at rtems.org>
> > > Sent: Wednesday, June 9, 2021 12:13 PM
> > > To: Sommer, Jan <Jan.Sommer at dlr.de>; gedare at rtems.org
> > > Cc: devel at rtems.org
> > > On 8/6/21 11:52 pm, Jan.Sommer at dlr.de wrote:
> > > > I would also like to backport this to 5-freebsd-12 to solve this issue
> there as
> > > well.
> > > > I created a corresponding ticket:
> > > https://devel.rtems.org/ticket/4452#ticket
> > > OK for 5.
> > > Chris
