[PATCH v2 2/2] i386: Remove unneeded include header files
Gedare Bloom
gedare at rtems.org
Wed Jun 9 18:21:48 UTC 2021
It is helpful. there should be
remote: 3: update trac
now we need to find out why. seems the problem really is on git side.
On Wed, Jun 9, 2021 at 12:03 PM <Jan.Sommer at dlr.de> wrote:
> That`s the output I got.
> Not sure if it is helpful:
> $ git push upstream HEAD~:5-freebsd-12
> Counting objects: 4, done.
> Delta compression using up to 8 threads.
> Compressing objects: 100% (4/4), done.
> Writing objects: 100% (4/4), 658 bytes | 658.00 KiB/s, done.
> Total 4 (delta 3), reused 0 (delta 0)
> remote: 1: mail vc at rtems.org
> remote: 2: update github
> remote: 4: IRC
> remote: usage: <file with rev-list> <repo name without .git>
> remote: 5: Buildbot
> To ssh://dispatch.rtems.org/data/git/rtems-libbsd.git
> a2bc8eba46..9edb1201f6 HEAD~ -> 5-freebsd-12
> $ git push upstream HEAD:5-freebsd-12
> Counting objects: 7, done.
> Compressing objects: 100% (6/6), done.
> Writing objects: 100% (7/7), 567 bytes | 567.00 KiB/s, done.
> Total 7 (delta 4), reused 0 (delta 0)
> remote: 4: IRC
> remote: 5: Buildbot
> 9edb1201f6..5c1b99e4d2 HEAD -> 5-freebsd-12
> > -----Original Message-----
> > From: Gedare Bloom <gedare at rtems.org>
> > Sent: Wednesday, June 9, 2021 7:59 PM
> > To: Sommer, Jan <Jan.Sommer at dlr.de>; Amar Takhar
> > <verm at darkbeer.org>
> > Cc: Chris Johns <chrisj at rtems.org>; devel at rtems.org
> > Subject: Re: [PATCH v2 2/2] i386: Remove unneeded include header files
> > On Wed, Jun 9, 2021 at 10:51 AM <Jan.Sommer at dlr.de> wrote:
> > > Thanks. Pushed to master, 5-freebsd-12 and 6-freebsd-12.
> > > Short question: Does the buildbot recognize the pushes to rtems-libbsd/5-
> > freebsd-12 and update the ticket?
> > > I added the ticket number to the commit description, but the ticket has not
> > been updated.
> > Do you still have the terminal output from running git-push?
> > The git side looks ok, but I can't check the trac end.
> > > Best regards,
> > > Jan
> > > > From: Chris Johns <chrisj at rtems.org>
> > > > Sent: Wednesday, June 9, 2021 12:13 PM
> > > > To: Sommer, Jan <Jan.Sommer at dlr.de>; gedare at rtems.org
> > > > Cc: devel at rtems.org
> > > > On 8/6/21 11:52 pm, Jan.Sommer at dlr.de wrote:
> > > > > I would also like to backport this to 5-freebsd-12 to solve this issue
> > there as
> > > > well.
> > > > > I created a corresponding ticket:
> > > > https://devel.rtems.org/ticket/4452#ticket
> > > > OK for 5.
> > > > Chris
