[PATCH] part of implimenting a monotonic clock in rtems part of this is not the final patch.
zack zakthertemsdev at outlook.com
Wed Jun 9 18:27:05 UTC 2021
From: zack <zack_on_the_speed_chanel at protonmail.ch>
 cpukit/include/rtems/posix/timer.h        |  6 ++-
 cpukit/posix/src/psxtimercreate.c         |  5 +-
 cpukit/posix/src/timergettime.c           | 61 ++++++++++++++++++++---
 testsuites/psxtests/psxtimer02/psxtimer.c | 26 +++++++---
 4 files changed, 81 insertions(+), 17 deletions(-)
diff --git a/cpukit/include/rtems/posix/timer.h b/cpukit/include/rtems/posix/timer.h
index bcbf07a65a..f8cf6115b2 100644
--- a/cpukit/include/rtems/posix/timer.h
+++ b/cpukit/include/rtems/posix/timer.h
@@ -21,7 +21,7 @@
 #include <rtems/score/objectdata.h>
+#include <time.h>
 #include <pthread.h>
 #ifdef __cplusplus
@@ -47,7 +47,9 @@ typedef struct {
   struct itimerspec timer_data; /* Timing data of the timer              */
   uint32_t          ticks;      /* Number of ticks of the initialization */
   uint32_t          overrun;    /* Number of expirations of the timer    */
-  struct timespec   time;       /* Time at which the timer was started   */
+  struct timespec   time;       /* Time at which the timer was started   */
+  clockid_t     clock_type;
 } POSIX_Timer_Control;
diff --git a/cpukit/posix/src/psxtimercreate.c b/cpukit/posix/src/psxtimercreate.c
index a63cf1d100..e78c359bd5 100644
--- a/cpukit/posix/src/psxtimercreate.c
+++ b/cpukit/posix/src/psxtimercreate.c
@@ -40,7 +40,7 @@ int timer_create(
   POSIX_Timer_Control *ptimer;
-  if ( clock_id != CLOCK_REALTIME )
+  if ( clock_id != CLOCK_REALTIME || clock_id != CLOCK_MONOTONIC  )
     rtems_set_errno_and_return_minus_one( EINVAL );
   if ( !timerid )
@@ -91,7 +91,8 @@ int timer_create(
   ptimer->timer_data.it_value.tv_nsec    = 0;
   ptimer->timer_data.it_interval.tv_sec  = 0;
   ptimer->timer_data.it_interval.tv_nsec = 0;
+  ptimer->clock_type=clock_id;
   _Watchdog_Preinitialize( &ptimer->Timer, _Per_CPU_Get_snapshot() );
   _Watchdog_Initialize( &ptimer->Timer, _POSIX_Timer_TSR );
   _Objects_Open_u32(&_POSIX_Timer_Information, &ptimer->Object, 0);
diff --git a/cpukit/posix/src/timergettime.c b/cpukit/posix/src/timergettime.c
index ee2a566f0e..62011cde58 100644
--- a/cpukit/posix/src/timergettime.c
+++ b/cpukit/posix/src/timergettime.c
@@ -28,6 +28,7 @@
 #include <rtems/seterr.h>
+#include <rtems/timespec.h>
  *          - When a timer is initialized, the value of the time in
@@ -43,21 +44,67 @@ int timer_gettime(
   ISR_lock_Context     lock_context;
-  uint64_t             now;
   uint32_t             remaining;
+     Per_CPU_Control *cpu;
+     struct  timespec * now; // get time now either with
+     struct  timespec * expire; // expire
+     struct  timespec * result;// get remaining time
   if ( !value )
-    rtems_set_errno_and_return_minus_one( EINVAL );
+    rtems_set_errno_and_return_minus_one( EINVAL );
   ptimer = _POSIX_Timer_Get( timerid, &lock_context );
-  if ( ptimer != NULL ) {
-    Per_CPU_Control *cpu;
+  if(ptimer== NULL ){
+if ( ptimer->clock_type ==CLOCK_REALTIME) {
+    cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
+          _TOD_Get(now); // get current time
+        rtems_timespec_from_ticks (ptimer->Timer.expire,expire ); // get the time to expire
+    if (now->tv_nsec+now->tv_sec > expire->tv_nsec+expire->tv_sec) { // check if the time expired
+        rtems_timespec_subtract (now ,expire , result); //
+      remaining = (uint32_t) result->tv_nsec+result->tv_sec;
+    } else {
+      remaining = 0;
+    _Timespec_From_ticks( remaining, &value->it_value );
+    value->it_interval = ptimer->timer_data.it_interval;
+    _POSIX_Timer_Release( cpu, &lock_context );
+    return 0;
+if ( ptimer->clock_type ==CLOCK_MONOTONIC) {
-    now = cpu->Watchdog.ticks;
+       _Timecounter_Nanouptime(now );
+        rtems_timespec_subtract (now, expire, result);
-    if ( now < ptimer->Timer.expire ) {
-      remaining = (uint32_t) ( ptimer->Timer.expire - now );
     } else {
       remaining = 0;
diff --git a/testsuites/psxtests/psxtimer02/psxtimer.c b/testsuites/psxtests/psxtimer02/psxtimer.c
index 9f79d33c42..029e638c76 100644
--- a/testsuites/psxtests/psxtimer02/psxtimer.c
+++ b/testsuites/psxtests/psxtimer02/psxtimer.c
@@ -59,17 +59,31 @@ void *POSIX_Init (
   fatal_posix_service_status_errno( status, EINVAL, "bad clock id" );
   puts( "timer_create - bad timer id pointer - EINVAL" );
-  status = timer_create( CLOCK_REALTIME, &event, NULL );
+  status = timer_create( CLOCK_MONOTONIC, &event, NULL );
   fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
   puts( "timer_create - OK" );
-  status = timer_create( CLOCK_REALTIME, NULL, &timer );
+  status = timer_create( CLOCK_MONOTONIC, NULL, &timer );
   posix_service_failed( status, "timer_create OK" );
   puts( "timer_create - too many - EAGAIN" );
-  status = timer_create( CLOCK_REALTIME, NULL, &timer1 );
+  status = timer_create( CLOCK_MONOTONIC, NULL, &timer1 );
   fatal_posix_service_status_errno( status, EAGAIN, "too many" );
+  puts( "timer_create (monotonic) - bad timer id pointer - EINVAL" );
+  fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
+  puts( "timer_create (Monotonic) - OK" );
+  posix_service_failed( status, "timer_create OK" );
+  puts( "timer_create (monotonic)- too many - EAGAIN" );
+  fatal_posix_service_status_errno( status, EAGAIN, "too many" );
   puts( "timer_delete - bad id - EINVAL" );
   status = timer_delete( timer1 + 1 );
   fatal_posix_service_status_errno( status, EINVAL, "bad id" );
@@ -100,14 +114,14 @@ void *POSIX_Init (
   status = timer_settime( timer, TIMER_ABSTIME, &itimer, NULL );
   fatal_posix_service_status_errno( status, EINVAL, "bad itimer value #2" );
-  clock_gettime( CLOCK_REALTIME, &now );
+  clock_gettime( CLOCK_MONOTONIC, &now );
   itimer.it_value = now;
   itimer.it_value.tv_sec = itimer.it_value.tv_sec - 1;
   puts( "timer_settime - bad itimer value - previous time - EINVAL" );
   fatal_posix_service_status_errno( status, EINVAL, "bad itimer value #3" );
   itimer.it_value.tv_sec = itimer.it_value.tv_sec + 1;
   puts( "timer_settime - bad id - EINVAL" );
@@ -129,4 +143,4 @@ void *POSIX_Init (
   TEST_END();
   rtems_test_exit (0);
\ No newline at end of file
2.31.1
