[PATCH] part of implimenting a monotonic clock in rtems part of this is not the final patch.
zack_on_the_speed_chanel zack_on_the_speed_chanel at protonmail.ch
Fri Jun 11 15:20:16 UTC 2021
ping
Sent with ProtonMail Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Wednesday, June 9th, 2021 at 6:27 PM, zack <zakthertemsdev at outlook.com> wrote:
> From: zack zack_on_the_speed_chanel at protonmail.ch
> cpukit/include/rtems/posix/timer.h | 6 ++-
> cpukit/posix/src/psxtimercreate.c | 5 +-
> cpukit/posix/src/timergettime.c | 61 ++++++++++++++++++++---
> testsuites/psxtests/psxtimer02/psxtimer.c | 26 +++++++---
> 4 files changed, 81 insertions(+), 17 deletions(-)
> diff --git a/cpukit/include/rtems/posix/timer.h b/cpukit/include/rtems/posix/timer.h
> index bcbf07a65a..f8cf6115b2 100644
> --- a/cpukit/include/rtems/posix/timer.h
> +++ b/cpukit/include/rtems/posix/timer.h
> @@ -21,7 +21,7 @@
> #include <rtems/score/objectdata.h>
> #include <rtems/score/watchdog.h>
> +#include <time.h>
> #include <pthread.h>
> #ifdef __cplusplus
> @@ -47,7 +47,9 @@ typedef struct {
> struct itimerspec timer_data; /* Timing data of the timer /
> uint32_t ticks; / Number of ticks of the initialization /
> uint32_t overrun; / Number of expirations of the timer */
> -   struct timespec time; /* Time at which the timer was started */
> -   clockid_t clock_type;
> } POSIX_Timer_Control;
> diff --git a/cpukit/posix/src/psxtimercreate.c b/cpukit/posix/src/psxtimercreate.c
> index a63cf1d100..e78c359bd5 100644
> --- a/cpukit/posix/src/psxtimercreate.c
> +++ b/cpukit/posix/src/psxtimercreate.c
> @@ -40,7 +40,7 @@ int timer_create(
> POSIX_Timer_Control *ptimer;
> -   if ( clock_id != CLOCK_REALTIME )
> -   if ( clock_id != CLOCK_REALTIME || clock_id != CLOCK_MONOTONIC )
>     rtems_set_errno_and_return_minus_one( EINVAL );
>     if ( !timerid )
>     @@ -91,7 +91,8 @@ int timer_create(
>     ptimer->timer_data.it_value.tv_nsec = 0;
>     ptimer->timer_data.it_interval.tv_sec = 0;
>     ptimer->timer_data.it_interval.tv_nsec = 0;
> -   ptimer->clock_type=clock_id;
> -   _Watchdog_Preinitialize( &ptimer->Timer, _Per_CPU_Get_snapshot() );
>     _Watchdog_Initialize( &ptimer->Timer, _POSIX_Timer_TSR );
>     _Objects_Open_u32(&_POSIX_Timer_Information, &ptimer->Object, 0);
> diff --git a/cpukit/posix/src/timergettime.c b/cpukit/posix/src/timergettime.c
> index ee2a566f0e..62011cde58 100644
> --- a/cpukit/posix/src/timergettime.c
> +++ b/cpukit/posix/src/timergettime.c
> @@ -28,6 +28,7 @@
> #include <rtems/score/todimpl.h>
> #include <rtems/score/watchdogimpl.h>
> #include <rtems/seterr.h>
> +#include <rtems/timespec.h>
> -            - When a timer is initialized, the value of the time in
> @@ -43,21 +44,67 @@ int timer_gettime(
> ISR_lock_Context lock_context;
> -   uint64_t now;
>     uint32_t remaining;
> -       Per_CPU_Control *cpu;
> -       struct  timespec * now; // get time now either with
> -       struct  timespec * expire; // expire
> -       struct  timespec * result;// get remaining time
> if ( !value )
> -   rtems_set_errno_and_return_minus_one( EINVAL );
>     ptimer = _POSIX_Timer_Get( timerid, &lock_context );
> -   if ( ptimer != NULL ) {
> -   if(ptimer== NULL ){
> +if ( ptimer->clock_type ==CLOCK_REALTIME) {
> -   cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
> -            _TOD_Get(now); // get current time
> -          rtems_timespec_from_ticks (ptimer->Timer.expire,expire ); // get the time to expire
> -   if (now->tv_nsec+now->tv_sec > expire->tv_nsec+expire->tv_sec) { // check if the time expired
> -          rtems_timespec_subtract (now ,expire , result); //
> -        remaining = (uint32_t) result->tv_nsec+result->tv_sec;
> -   } else {
> -        remaining = 0;
> -   _Timespec_From_ticks( remaining, &value->it_value );
> -   value->it_interval = ptimer->timer_data.it_interval;
> -   _POSIX_Timer_Release( cpu, &lock_context );
> -   return 0;
> +if ( ptimer->clock_type ==CLOCK_MONOTONIC) {
> -   now = cpu->Watchdog.ticks;
> -         _Timecounter_Nanouptime(now );
> -          rtems_timespec_subtract (now, expire, result);
> -   if ( now < ptimer->Timer.expire ) {
> -        remaining = (uint32_t) ( ptimer->Timer.expire - now );
>     } else {
>     remaining = 0;
>     diff --git a/testsuites/psxtests/psxtimer02/psxtimer.c b/testsuites/psxtests/psxtimer02/psxtimer.c
>     index 9f79d33c42..029e638c76 100644
>     --- a/testsuites/psxtests/psxtimer02/psxtimer.c
>     +++ b/testsuites/psxtests/psxtimer02/psxtimer.c
>     @@ -59,17 +59,31 @@ void *POSIX_Init (
>     fatal_posix_service_status_errno( status, EINVAL, "bad clock id" );
>     puts( "timer_create - bad timer id pointer - EINVAL" );
> -   status = timer_create( CLOCK_REALTIME, &event, NULL );
> -   status = timer_create( CLOCK_MONOTONIC, &event, NULL );
>     fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
>     puts( "timer_create - OK" );
> -   status = timer_create( CLOCK_REALTIME, NULL, &timer );
> -   status = timer_create( CLOCK_MONOTONIC, NULL, &timer );
>     posix_service_failed( status, "timer_create OK" );
>     puts( "timer_create - too many - EAGAIN" );
> -   status = timer_create( CLOCK_REALTIME, NULL, &timer1 );
> -   status = timer_create( CLOCK_MONOTONIC, NULL, &timer1 );
>     fatal_posix_service_status_errno( status, EAGAIN, "too many" );
> -   puts( "timer_create (monotonic) - bad timer id pointer - EINVAL" );
> -   fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
> -   puts( "timer_create (Monotonic) - OK" );
> -   posix_service_failed( status, "timer_create OK" );
> -   puts( "timer_create (monotonic)- too many - EAGAIN" );
> -   fatal_posix_service_status_errno( status, EAGAIN, "too many" );
> -   puts( "timer_delete - bad id - EINVAL" );
>     status = timer_delete( timer1 + 1 );
>     fatal_posix_service_status_errno( status, EINVAL, "bad id" );
>     @@ -100,14 +114,14 @@ void *POSIX_Init (
>     status = timer_settime( timer, TIMER_ABSTIME, &itimer, NULL );
>     fatal_posix_service_status_errno( status, EINVAL, "bad itimer value #2" );
> -   clock_gettime( CLOCK_REALTIME, &now );
> -   clock_gettime( CLOCK_MONOTONIC, &now );
>     itimer.it_value = now;
>     itimer.it_value.tv_sec = itimer.it_value.tv_sec - 1;
>     puts( "timer_settime - bad itimer value - previous time - EINVAL" );
>     fatal_posix_service_status_errno( status, EINVAL, "bad itimer value #3" );
>     itimer.it_value.tv_sec = itimer.it_value.tv_sec + 1;
>     puts( "timer_settime - bad id - EINVAL" );
>     @@ -129,4 +143,4 @@ void *POSIX_Init (
>     TEST_END();
>     rtems_test_exit (0);
>     \ No newline at end of file
>     2.31.1
