[PATCH v2 2/2] i386: Remove unneeded include header files
Gedare Bloom
gedare at rtems.org
Wed Jun 9 18:27:51 UTC 2021
On Wed, Jun 9, 2021 at 12:21 PM Gedare Bloom <gedare at rtems.org> wrote:
> It is helpful. there should be
> remote: 3: update trac
ok, actually what's missing is
0: init
I think the hooks need to be updated for rtems-libbsd. without running
init, the TMP_REV is not generated, so there's nothing to send to
trac.
I'm going to update the hooks, and we'll see if it works next time.
You'll need to manually close the ticket(s) for 5.
> now we need to find out why. seems the problem really is on git side.
> On Wed, Jun 9, 2021 at 12:03 PM <Jan.Sommer at dlr.de> wrote:
> > That`s the output I got.
> > Not sure if it is helpful:
> > $ git push upstream HEAD~:5-freebsd-12
> > Counting objects: 4, done.
> > Delta compression using up to 8 threads.
> > Compressing objects: 100% (4/4), done.
> > Writing objects: 100% (4/4), 658 bytes | 658.00 KiB/s, done.
> > Total 4 (delta 3), reused 0 (delta 0)
> > remote: 1: mail vc at rtems.org
> > remote: 2: update github
> > remote: 4: IRC
> > remote: usage: <file with rev-list> <repo name without .git>
> > remote: 5: Buildbot
> > To ssh://dispatch.rtems.org/data/git/rtems-libbsd.git
> > a2bc8eba46..9edb1201f6 HEAD~ -> 5-freebsd-12
> > $ git push upstream HEAD:5-freebsd-12
> > Counting objects: 7, done.
> > Compressing objects: 100% (6/6), done.
> > Writing objects: 100% (7/7), 567 bytes | 567.00 KiB/s, done.
> > Total 7 (delta 4), reused 0 (delta 0)
> > remote: 4: IRC
> > remote: 5: Buildbot
> > 9edb1201f6..5c1b99e4d2 HEAD -> 5-freebsd-12
> > > -----Original Message-----
> > > From: Gedare Bloom <gedare at rtems.org>
> > > Sent: Wednesday, June 9, 2021 7:59 PM
> > > To: Sommer, Jan <Jan.Sommer at dlr.de>; Amar Takhar
> > > <verm at darkbeer.org>
> > > Cc: Chris Johns <chrisj at rtems.org>; devel at rtems.org
> > > Subject: Re: [PATCH v2 2/2] i386: Remove unneeded include header files
> > > On Wed, Jun 9, 2021 at 10:51 AM <Jan.Sommer at dlr.de> wrote:
> > > > Thanks. Pushed to master, 5-freebsd-12 and 6-freebsd-12.
> > > > Short question: Does the buildbot recognize the pushes to rtems-libbsd/5-
> > > freebsd-12 and update the ticket?
> > > > I added the ticket number to the commit description, but the ticket has not
> > > been updated.
> > > Do you still have the terminal output from running git-push?
> > > The git side looks ok, but I can't check the trac end.
> > > > Best regards,
> > > > Jan
> > > > > From: Chris Johns <chrisj at rtems.org>
> > > > > Sent: Wednesday, June 9, 2021 12:13 PM
> > > > > To: Sommer, Jan <Jan.Sommer at dlr.de>; gedare at rtems.org
> > > > > Cc: devel at rtems.org
> > > > > On 8/6/21 11:52 pm, Jan.Sommer at dlr.de wrote:
> > > > > > I would also like to backport this to 5-freebsd-12 to solve this issue
> > > there as
> > > > > well.
> > > > > > I created a corresponding ticket:
> > > > > https://devel.rtems.org/ticket/4452#ticket
> > > > > OK for 5.
> > > > > Chris
