Running SPARC/LEON3 in TSIM-LEON3 simulator
Đức Anh dauto98 at gmail.com
Fri Jun 11 10:37:55 UTC 2021
Hi Sebastian,
Thank you. I didn't notice that.
I recompile with SMP enabled, and the application doesn't run successfully
in the TSIM-LEON3 simulator. Below is the error message:
Initializing and starting from 0x40000000
>   CPU 0 in error mode (tt=0x80, trap instruction)
>   (In trap table for tt=0x02, illegal instruction)
>       70150  40000020  91d02000   ta        0                        start
> + 0x20
The thing is, the same code will work if I compile with SMP disabled. When
the SMP is enabled, the simulator will crash like above, even with the
simple hello world application.
Have anyone here run into a similar issue? Or do you know any other leon3
(or sparc) simulator that I can try?
Best regards,
Duc Anh
On Wed, 9 Jun 2021 at 18:46, Sebastian Huber <
> On 09/06/2021 18:39, Đức Anh wrote:
> > - Is there a way to enable SMP for SPARC/LEON3 in RTEMS 6?
> Just set "RTEMS_SMP = True" in your config.ini:
> https://docs.rtems.org/branches/master/user/bld/index.html#migration-from-autoconf-automake
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210611/3f591db8/attachment.html>
