Running SPARC/LEON3 in TSIM-LEON3 simulator
Jiri Gaisler
jiri at gaisler.se
Fri Jun 11 20:10:50 UTC 2021
On 6/11/21 12:37 PM, Đức Anh wrote:
> Hi Sebastian,
> Thank you. I didn't notice that.
> I recompile with SMP enabled, and the application doesn't run successfully in the TSIM-LEON3 simulator. Below is the error message:
> Initializing and starting from 0x40000000
> CPU 0 in error mode (tt=0x80, trap instruction)
> (In trap table for tt=0x02, illegal instruction)
> 70150 40000020 91d02000 ta 0 start + 0x20
> The thing is, the same code will work if I compile with SMP disabled. When the SMP is enabled, the simulator will crash like above, even with the simple hello world application.
> Have anyone here run into a similar issue? Or do you know any other leon3 (or sparc) simulator that I can try?
You can try with sis:
sparc-rtem6-sis -leon3 -m 4 hello.exe
Should work without problems. For SMP, you need the '-m 4' switch to enable 4 cores ...
Jiri.
> Best regards,
> Duc Anh
> On Wed, 9 Jun 2021 at 18:46, Sebastian Huber <sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 09/06/2021 18:39, Đức Anh wrote:
> > - Is there a way to enable SMP for SPARC/LEON3 in RTEMS 6?
> Just set "RTEMS_SMP = True" in your config.ini:
> https://docs.rtems.org/branches/master/user/bld/index.html#migration-from-autoconf-automake <https://docs.rtems.org/branches/master/user/bld/index.html#migration-from-autoconf-automake>
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/ <https://embedded-brains.de/datenschutzerklaerung/>
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210611/fd540057/attachment.html>
