Can't build minimal buildset for libbsd on IMXRT
Peter Dufault dufault at hda.com
Fri Jun 11 11:23:36 UTC 2021
I tried to build the "minimal" buildset for the IMXRT BSP and I get undefined INET6 references - _bsd_inet6_pfil_hook, _bsd_ip6stat, etc.  Only two executables are created - swi01.exe and timeout01.exe.  For "default" (almost) everything builds except for a few that won't fit in RAM but I don't currently have enough RAM to run anything so I figured my first step should be to build "minimal".
The configure command is:
./waf configure --rtems-tools=bla/rtems-6 --rtems=bla/rtems-6 --rtems-bsps=arm/imxrt1052 --buildset=buildset/minimal.ini
The libbsd is a recent 6-freebsd=12
is "minimal" built regularly?  Any hints?
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
Type: application/pgp-signature
Desc: Message signed with OpenPGP
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210611/98a7939c/attachment.bin>
