Can't build minimal buildset for libbsd on IMXRT
Christian Mauderer oss at c-mauderer.de
Fri Jun 11 12:07:18 UTC 2021
Hello Peter,
On 11/06/2021 13:23, Peter Dufault wrote:
> I tried to build the "minimal" buildset for the IMXRT BSP and I get undefined INET6 references - _bsd_inet6_pfil_hook, _bsd_ip6stat, etc.  Only two executables are created - swi01.exe and timeout01.exe.  For "default" (almost) everything builds except for a few that won't fit in RAM but I don't currently have enough RAM to run anything so I figured my first step should be to build "minimal".
I just tried it with beagle bone black: The minimal buildset builds
fine. Can you tell from the output who is referencing the
inet6_pfil_hook and ip6stat?
> The configure command is:
> ./waf configure --rtems-tools=bla/rtems-6 --rtems=bla/rtems-6 --rtems-bsps=arm/imxrt1052 --buildset=buildset/minimal.ini
Looks OK.
> The libbsd is a recent 6-freebsd=12
> is "minimal" built regularly?  Any hints?
No it is not build regularly. I think the buildset are often forgotten
if someone works on libbsd. For example "everything" doesn't build at
the moment.
Best regards
Christian
> Peter
> Peter Dufault
> HD Associates, Inc.      Software and System Engineering
> This email is delivered through the public internet using protocols subject to interception and tampering.
> devel mailing list
> devel at rtems.org
