Can't build minimal buildset for libbsd on IMXRT
Christian Mauderer
oss at c-mauderer.de
Fri Jun 11 13:52:37 UTC 2021
Hello Peter,
On 11/06/2021 15:47, dufault at hda.com wrote:
>> On Jun 11, 2021, at 09:36 , <dufault at hda.com> <dufault at hda.com> wrote:
>> I *do* have a previously installed libbsd in my prefix. I don't understand the workflow properly.
>> I figured that if I did "./waf distclean" in rtems-libbsd between switching build sets the build woiuld bootstrap properly but evidently not.
>> Do you need to use multiple prefixes to support multiple build sets? I wanted to try the minimal one first before installing.
> I removed the installed "imxrt1052" BSP and then it worked.
I think that is a bug in our current build system. For some reason it
can happen that an installed header takes precedence over the ones in
the sources. I haven't seen that problem often and I didn't really
investigate it enough. Therefore there is still no bug report regarding
that.
Best regards
Christian
> Peter
> Peter Dufault
> HD Associates, Inc. Software and System Engineering
> This email is delivered through the public internet using protocols subject to interception and tampering.
