[PATCH rtems-libbsd 1/2] racoon: Fix build with current toolchain
Christian Mauderer oss at c-mauderer.de
Fri Jun 11 12:19:52 UTC 2021
During some newlib version, the _types_fd_set has been replaced with
just fd_set.
 ipsec-tools/src/racoon/rtems-bsd-racoon-session-data.h | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/ipsec-tools/src/racoon/rtems-bsd-racoon-session-data.h b/ipsec-tools/src/racoon/rtems-bsd-racoon-session-data.h
index 196107a3..cdf8a74d 100644
--- a/ipsec-tools/src/racoon/rtems-bsd-racoon-session-data.h
+++ b/ipsec-tools/src/racoon/rtems-bsd-racoon-session-data.h
@@ -2,8 +2,8 @@
 #include <rtems/linkersets.h>
 #include "rtems-bsd-racoon-data.h"
 /* session.c */
-RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static _types_fd_set *allocated_active_mask);
-RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static _types_fd_set *allocated_preset_mask);
+RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static fd_set *allocated_active_mask);
+RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static fd_set *allocated_preset_mask);
 RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static int nfds);
 RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static int signals[]);
 RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static sig_atomic_t volatile volatile sigreq[]);
2.32.0
