[PATCH] part of implimenting a monotonic clock in rtems part of this is not the final patch.
Christian Mauderer oss at c-mauderer.de
Fri Jun 11 16:01:05 UTC 2021
Hello Zack,
you say: "part of this is not the final patch" in the subject. So what
is the intention of this patch? Do you need a complete review? Is it
some kind of preview and you need input? If yes: For what parts do you
need input?
Best regards
Christian
On 11/06/2021 17:20, zack_on_the_speed_chanel wrote:
> ping
> Sent with ProtonMail Secure Email.
> ‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
> On Wednesday, June 9th, 2021 at 6:27 PM, zack <zakthertemsdev at outlook.com> wrote:
>> From: zack zack_on_the_speed_chanel at protonmail.ch
>> cpukit/include/rtems/posix/timer.h | 6 ++-
>> cpukit/posix/src/psxtimercreate.c | 5 +-
>> cpukit/posix/src/timergettime.c | 61 ++++++++++++++++++++---
>> testsuites/psxtests/psxtimer02/psxtimer.c | 26 +++++++---
>> 4 files changed, 81 insertions(+), 17 deletions(-)
>> diff --git a/cpukit/include/rtems/posix/timer.h b/cpukit/include/rtems/posix/timer.h
>> index bcbf07a65a..f8cf6115b2 100644
>> --- a/cpukit/include/rtems/posix/timer.h
>> +++ b/cpukit/include/rtems/posix/timer.h
>> @@ -21,7 +21,7 @@
>> #include <rtems/score/objectdata.h>
>> #include <rtems/score/watchdog.h>
>> +#include <time.h>
>> #include <pthread.h>
>> #ifdef __cplusplus
>> @@ -47,7 +47,9 @@ typedef struct {
>> struct itimerspec timer_data; /* Timing data of the timer /
>> uint32_t ticks; / Number of ticks of the initialization /
>> uint32_t overrun; / Number of expirations of the timer */
>> -   struct timespec time; /* Time at which the timer was started */
>> -   clockid_t clock_type;
>> } POSIX_Timer_Control;
>> diff --git a/cpukit/posix/src/psxtimercreate.c b/cpukit/posix/src/psxtimercreate.c
>> index a63cf1d100..e78c359bd5 100644
>> --- a/cpukit/posix/src/psxtimercreate.c
>> +++ b/cpukit/posix/src/psxtimercreate.c
>> @@ -40,7 +40,7 @@ int timer_create(
>> POSIX_Timer_Control *ptimer;
>> -   if ( clock_id != CLOCK_REALTIME )
>> -   if ( clock_id != CLOCK_REALTIME || clock_id != CLOCK_MONOTONIC )
>>      rtems_set_errno_and_return_minus_one( EINVAL );
>>      if ( !timerid )
>>      @@ -91,7 +91,8 @@ int timer_create(
>>      ptimer->timer_data.it_value.tv_nsec = 0;
>>      ptimer->timer_data.it_interval.tv_sec = 0;
>>      ptimer->timer_data.it_interval.tv_nsec = 0;
>> -   ptimer->clock_type=clock_id;
>> -   _Watchdog_Preinitialize( &ptimer->Timer, _Per_CPU_Get_snapshot() );
>>      _Watchdog_Initialize( &ptimer->Timer, _POSIX_Timer_TSR );
>>      _Objects_Open_u32(&_POSIX_Timer_Information, &ptimer->Object, 0);
>> diff --git a/cpukit/posix/src/timergettime.c b/cpukit/posix/src/timergettime.c
>> index ee2a566f0e..62011cde58 100644
>> --- a/cpukit/posix/src/timergettime.c
>> +++ b/cpukit/posix/src/timergettime.c
>> @@ -28,6 +28,7 @@
>> #include <rtems/score/todimpl.h>
>> #include <rtems/score/watchdogimpl.h>
>> #include <rtems/seterr.h>
>> +#include <rtems/timespec.h>
>> -            - When a timer is initialized, the value of the time in
>> @@ -43,21 +44,67 @@ int timer_gettime(
>> ISR_lock_Context lock_context;
>> -   uint64_t now;
>>      uint32_t remaining;
>> -       Per_CPU_Control *cpu;
>> -       struct  timespec * now; // get time now either with
>> -       struct  timespec * expire; // expire
>> -       struct  timespec * result;// get remaining time
>> if ( !value )
>> -   rtems_set_errno_and_return_minus_one( EINVAL );
>>      ptimer = _POSIX_Timer_Get( timerid, &lock_context );
>> -   if ( ptimer != NULL ) {
>> -   if(ptimer== NULL ){
>> +if ( ptimer->clock_type ==CLOCK_REALTIME) {
>> -   cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
>> -            _TOD_Get(now); // get current time
>> -          rtems_timespec_from_ticks (ptimer->Timer.expire,expire ); // get the time to expire
>> -   if (now->tv_nsec+now->tv_sec > expire->tv_nsec+expire->tv_sec) { // check if the time expired
>> -          rtems_timespec_subtract (now ,expire , result); //
>> -        remaining = (uint32_t) result->tv_nsec+result->tv_sec;
>> -   } else {
>> -        remaining = 0;
>> -   _Timespec_From_ticks( remaining, &value->it_value );
>> -   value->it_interval = ptimer->timer_data.it_interval;
>> -   _POSIX_Timer_Release( cpu, &lock_context );
>> -   return 0;
>> +if ( ptimer->clock_type ==CLOCK_MONOTONIC) {
>> -   now = cpu->Watchdog.ticks;
>> -         _Timecounter_Nanouptime(now );
>> -          rtems_timespec_subtract (now, expire, result);
>> -   if ( now < ptimer->Timer.expire ) {
>> -        remaining = (uint32_t) ( ptimer->Timer.expire - now );
>>      } else {
>>      remaining = 0;
>>      diff --git a/testsuites/psxtests/psxtimer02/psxtimer.c b/testsuites/psxtests/psxtimer02/psxtimer.c
>>      index 9f79d33c42..029e638c76 100644
>>      --- a/testsuites/psxtests/psxtimer02/psxtimer.c
>>      +++ b/testsuites/psxtests/psxtimer02/psxtimer.c
>>      @@ -59,17 +59,31 @@ void *POSIX_Init (
>>      fatal_posix_service_status_errno( status, EINVAL, "bad clock id" );
>>      puts( "timer_create - bad timer id pointer - EINVAL" );
>> -   status = timer_create( CLOCK_REALTIME, &event, NULL );
>> -   status = timer_create( CLOCK_MONOTONIC, &event, NULL );
>>      fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
>>      puts( "timer_create - OK" );
>> -   status = timer_create( CLOCK_REALTIME, NULL, &timer );
>> -   status = timer_create( CLOCK_MONOTONIC, NULL, &timer );
>>      posix_service_failed( status, "timer_create OK" );
>>      puts( "timer_create - too many - EAGAIN" );
>> -   status = timer_create( CLOCK_REALTIME, NULL, &timer1 );
>> -   status = timer_create( CLOCK_MONOTONIC, NULL, &timer1 );
>>      fatal_posix_service_status_errno( status, EAGAIN, "too many" );
>> -   puts( "timer_create (monotonic) - bad timer id pointer - EINVAL" );
>> -   fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
>> -   puts( "timer_create (Monotonic) - OK" );
>> -   posix_service_failed( status, "timer_create OK" );
>> -   puts( "timer_create (monotonic)- too many - EAGAIN" );
>> -   fatal_posix_service_status_errno( status, EAGAIN, "too many" );
>> -   puts( "timer_delete - bad id - EINVAL" );
>>      status = timer_delete( timer1 + 1 );
>>      fatal_posix_service_status_errno( status, EINVAL, "bad id" );
>>      @@ -100,14 +114,14 @@ void *POSIX_Init (
>>      status = timer_settime( timer, TIMER_ABSTIME, &itimer, NULL );
>>      fatal_posix_service_status_errno( status, EINVAL, "bad itimer value #2" );
>> -   clock_gettime( CLOCK_REALTIME, &now );
>> -   clock_gettime( CLOCK_MONOTONIC, &now );
>>      itimer.it_value = now;
>>      itimer.it_value.tv_sec = itimer.it_value.tv_sec - 1;
>>      puts( "timer_settime - bad itimer value - previous time - EINVAL" );
>>      fatal_posix_service_status_errno( status, EINVAL, "bad itimer value #3" );
>>      itimer.it_value.tv_sec = itimer.it_value.tv_sec + 1;
>>      puts( "timer_settime - bad id - EINVAL" );
>>      @@ -129,4 +143,4 @@ void *POSIX_Init (
>>      TEST_END();
>>      rtems_test_exit (0);
>>      \ No newline at end of file
>>      2.31.1
> devel mailing list
> devel at rtems.org
