[PATCH rtems-docs 1/1] user/bsps/arm/raspberrypi: Changed the link to the Raspberry Pi Firmware to point to Firmware Version 1.20200601
Mon Jun 14 14:53:18 UTC 2021
On Mon, Jun 14, 2021 at 3:02 AM pranav <dangipranav at gmail.com> wrote:
> Updated the link to the Raspberry Pi Firmware in RTEMS 5 docs, since the BSP works with an older version of the firmware currently.
>  user/bsps/arm/raspberrypi.rst | 7 ++++---
>  1 file changed, 4 insertions(+), 3 deletions(-)
> diff --git a/user/bsps/arm/raspberrypi.rst b/user/bsps/arm/raspberrypi.rst
> index c26f4b5..84e45b9 100644
> --- a/user/bsps/arm/raspberrypi.rst
> +++ b/user/bsps/arm/raspberrypi.rst
> @@ -19,9 +19,10 @@ The bootloader looks for a kernel image, by default the kernel images must
>  have a name of the form ``kernel*.img`` but this can be changed by adding
>  `kernel=<img_name>` to ``config.txt``.
> -You must provide the required files for the GPU to proceed. These files
> -can be downloaded from
> -`the Raspberry Pi Firmware Repository <https://github.com/raspberrypi/firmware/tree/master/boot>`_.
> +You must provide the required files for the GPU to proceed. The BSP
> +currently boots with an older version of the official Raspberry Pi Firmware.
Can you please expand on this sentence to explain why / that newer
versions don't work?
> +These files can be downloaded from
> +`the Raspberry Pi Firmware Repository <https://github.com/raspberrypi/firmware/tree/1.20200601/boot>`_.
>  You can remove the ``kernel*.img`` files if you want too, but don't touch
>  the other files.
> 2.27.0
> devel mailing list
> devel at rtems.org
