[PATCH rtems-docs 1/1] user/bsps/arm/raspberrypi: Changed the link to the Raspberry Pi Firmware to point to Firmware Version 1.20200601
Pranav Dangi dangipranav at gmail.com
Tue Jun 15 14:57:20 UTC 2021
I tried debugging by adding printk() statements to the start-up code but
couldn't find anything conclusive. I am stuck there and am still trying to
figure out what broke the BSP after that particular version of the
firmware. If not, I will try to see if using u-boot we can fix this.
Meanwhile, this update to the docs temporarily ensures using of the older
firmware to boot the BSP.
On Mon, 14 Jun 2021, 20:23 Gedare Bloom, <gedare at rtems.org> wrote:
> On Mon, Jun 14, 2021 at 3:02 AM pranav <dangipranav at gmail.com> wrote:
> > Updated the link to the Raspberry Pi Firmware in RTEMS 5 docs, since the
> BSP works with an older version of the firmware currently.
> >  user/bsps/arm/raspberrypi.rst | 7 ++++---
> >  1 file changed, 4 insertions(+), 3 deletions(-)
> > diff --git a/user/bsps/arm/raspberrypi.rst
> b/user/bsps/arm/raspberrypi.rst
> > index c26f4b5..84e45b9 100644
> > --- a/user/bsps/arm/raspberrypi.rst
> > +++ b/user/bsps/arm/raspberrypi.rst
> > @@ -19,9 +19,10 @@ The bootloader looks for a kernel image, by default
> the kernel images must
> >  have a name of the form ``kernel*.img`` but this can be changed by
> adding
> >  `kernel=<img_name>` to ``config.txt``.
> > -You must provide the required files for the GPU to proceed. These files
> > -can be downloaded from
> > -`the Raspberry Pi Firmware Repository <
> https://github.com/raspberrypi/firmware/tree/master/boot>`_.
> > +You must provide the required files for the GPU to proceed. The BSP
> > +currently boots with an older version of the official Raspberry Pi
> Firmware.
> Can you please expand on this sentence to explain why / that newer
> versions don't work?
> > +These files can be downloaded from
> > +`the Raspberry Pi Firmware Repository <
> https://github.com/raspberrypi/firmware/tree/1.20200601/boot>`_.
> >  You can remove the ``kernel*.img`` files if you want too, but don't
> touch
> >  the other files.
> > 2.27.0
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210615/81d9bca0/attachment.html>
