GSOC POSIX Compliance: Stuck trying to build Newlib
Eshan Dhawan eshandhawan51 at gmail.com
Tue Jun 15 16:52:19 UTC 2021
Hi Matt,
Try running the command with autoconf version 2.69 that's shipped with
RTEMS in the rtems bin
That works as well.
Also From a quick google search this is what I found :
https://superuser.com/questions/617872/cant-locate-autom4te-channeldefs-pm-in-inc-when-it-definitely-is-there
On Tue, Jun 15, 2021 at 9:12 PM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
> Hello Dr. Joel and Eshan,
> I have a patch ready to send to Newlib for the sig function prototypes
> and STR2SIG_MAX.
> But to do that, I think I need to have Newlib built, which I must
> still be doing wrong. The error that I am getting is attached below.
> I’ve been trying to follow the steps here:
> https://medium.com/my-gsoc-2019-journey/apply-newlib-patch-to-rtems-source-builder-6873b0fb31b8
> and
> https://medium.com/my-gsoc-2019-journey/build-newlib-for-sparc-and-arm-architecture-6b3287d4c6f2
> I even had rebuilt everything from scratch to see if that would help,
> but I still get the same error. Maybe I cloned the newlib source into
> the wrong directory?
> I was hoping to get the patch off to Newlib for review as a first step
> while I work on writing the actual methods. When you get a moment,
> could you please advise? Thank you very much!
> Sincerely,
> Matt
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210615/79e62630/attachment.html>
