GSOC POSIX Compliance: Stuck trying to build Newlib
Matthew Joyce mfjoyce2004 at gmail.com
Tue Jun 15 17:14:40 UTC 2021
Hi Gentlemen,
Thanks very much for your quick replies!
I just tried both, but perhaps I'm misinterpreting your suggestions.
(Could you please see the attached commands / errors!)
Eshan,
I did see that link, but it wasn't clear to me what the solution was...Sorry!
Sincerely,
Matt
On Tue, Jun 15, 2021 at 6:52 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> Hi Matt,
> Try running the command with autoconf version 2.69 that's shipped with RTEMS in the rtems bin
> That works as well.
> Also From a quick google search this is what I found : https://superuser.com/questions/617872/cant-locate-autom4te-channeldefs-pm-in-inc-when-it-definitely-is-there
> On Tue, Jun 15, 2021 at 9:12 PM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>> Hello Dr. Joel and Eshan,
>> I have a patch ready to send to Newlib for the sig function prototypes
>> and STR2SIG_MAX.
>> But to do that, I think I need to have Newlib built, which I must
>> still be doing wrong. The error that I am getting is attached below.
>> I’ve been trying to follow the steps here:
>> https://medium.com/my-gsoc-2019-journey/apply-newlib-patch-to-rtems-source-builder-6873b0fb31b8
>> and https://medium.com/my-gsoc-2019-journey/build-newlib-for-sparc-and-arm-architecture-6b3287d4c6f2
>> I even had rebuilt everything from scratch to see if that would help,
>> but I still get the same error. Maybe I cloned the newlib source into
>> the wrong directory?
>> I was hoping to get the patch off to Newlib for review as a first step
>> while I work on writing the actual methods. When you get a moment,
>> could you please advise? Thank you very much!
>> Sincerely,
>> Matt
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210615/fee59a02/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210615/fee59a02/attachment-0003.png>
