GSOC POSIX Compliance: Stuck trying to build Newlib
Joel Sherrill
joel at rtems.org
Tue Jun 15 19:28:25 UTC 2021
@RTEMS_TOOLS_BIN@ should have been replaced with the real directory where
your RTEMS tools are located. Something like this:
$ export PATH=${HOME}/rtems-work/tools/6/bin:$PATH
And to check you have the PATH right, do something like this:
$ type sparc-rtems6-gcc
sparc-rtems6-gcc is /home/joel/rtems-work/tools/6/bin/sparc-rtems6-gcc
On Tue, Jun 15, 2021 at 1:23 PM Eshan Dhawan <eshandhawan51 at gmail.com>
wrote:
> Hi matt
> It would work if run inside newlib instead of newlib-cygwin
> run command inside of ../newlib-cygwin/newlib
> instead of ../newlib-cygwin
> On Tue, Jun 15, 2021 at 10:59 PM Matthew Joyce <mfjoyce2004 at gmail.com>
> wrote:
>> Ah, ok will do! Thank you for the tip.
>> On Tue, Jun 15, 2021 at 7:17 PM Gedare Bloom <gedare at rtems.org> wrote:
>> > Just a note, it's more efficient to capture your terminal dump into a
>> > text file and attach that, rather than put a screenshot up.
>> > On Tue, Jun 15, 2021 at 11:14 AM Matthew Joyce <mfjoyce2004 at gmail.com>
>> wrote:
>> > > Hi Gentlemen,
>> > > Thanks very much for your quick replies!
>> > > I just tried both, but perhaps I'm misinterpreting your suggestions.
>> > > (Could you please see the attached commands / errors!)
>> > > Eshan,
>> > > I did see that link, but it wasn't clear to me what the solution
>> was...Sorry!
>> > > Sincerely,
>> > > Matt
>> > > On Tue, Jun 15, 2021 at 6:52 PM Eshan Dhawan <eshandhawan51 at gmail.com>
>> wrote:
>> > > > Hi Matt,
>> > > > Try running the command with autoconf version 2.69 that's shipped
>> with RTEMS in the rtems bin
>> > > > That works as well.
>> > > > Also From a quick google search this is what I found :
>> https://superuser.com/questions/617872/cant-locate-autom4te-channeldefs-pm-in-inc-when-it-definitely-is-there
>> > > > On Tue, Jun 15, 2021 at 9:12 PM Matthew Joyce <
>> mfjoyce2004 at gmail.com> wrote:
>> > > >> Hello Dr. Joel and Eshan,
>> > > >> I have a patch ready to send to Newlib for the sig function
>> prototypes
>> > > >> and STR2SIG_MAX.
>> > > >> But to do that, I think I need to have Newlib built, which I must
>> > > >> still be doing wrong. The error that I am getting is attached
>> below.
>> > > >> I’ve been trying to follow the steps here:
>> https://medium.com/my-gsoc-2019-journey/apply-newlib-patch-to-rtems-source-builder-6873b0fb31b8
>> > > >> and
>> https://medium.com/my-gsoc-2019-journey/build-newlib-for-sparc-and-arm-architecture-6b3287d4c6f2
>> > > >> I even had rebuilt everything from scratch to see if that would
>> help,
>> > > >> but I still get the same error. Maybe I cloned the newlib source
>> into
>> > > >> the wrong directory?
>> > > >> I was hoping to get the patch off to Newlib for review as a first
>> step
>> > > >> while I work on writing the actual methods. When you get a moment,
>> > > >> could you please advise? Thank you very much!
>> > > >> Sincerely,
>> > > >> Matt
>> > > _______________________________________________
>> > > devel mailing list
>> > > devel at rtems.org
>> > > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210615/51f03635/attachment.html>
