GSOC POSIX Compliance: Stuck trying to build Newlib
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Wed Jun 16 02:35:25 UTC 2021
Hello Matthew,
On Wed, Jun 16, 2021 at 12:58 AM Joel Sherrill <joel at rtems.org> wrote:
> @RTEMS_TOOLS_BIN@ should have been replaced with the real directory where your RTEMS tools are located. Something like this:
Exactly. I was wondering the same when I saw his output of 'echo $PATH'.
Matthew, the newlib and autoconf relationship is a bit messy. But you
can simplify it if you use $PATH carefully.
Have a look at this
https://medium.com/my-gsoc-2019-journey/how-to-handle-two-versions-of-autoconf-b1e28de8617b,
the path should expand and should point to the correct binaries.
The blog should give you an idea of how the $PATH works and how it
should be modified.
-- Vaibhav Gupta
> $ export PATH=${HOME}/rtems-work/tools/6/bin:$PATH
> And to check you have the PATH right, do something like this:
> $ type sparc-rtems6-gcc
> sparc-rtems6-gcc is /home/joel/rtems-work/tools/6/bin/sparc-rtems6-gcc
> On Tue, Jun 15, 2021 at 1:23 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>> Hi matt
>> It would work if run inside newlib instead of newlib-cygwin
>> run command inside of ../newlib-cygwin/newlib
>> instead of ../newlib-cygwin
>> On Tue, Jun 15, 2021 at 10:59 PM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>>> Ah, ok will do! Thank you for the tip.
>>> On Tue, Jun 15, 2021 at 7:17 PM Gedare Bloom <gedare at rtems.org> wrote:
>>> > Just a note, it's more efficient to capture your terminal dump into a
>>> > text file and attach that, rather than put a screenshot up.
>>> > On Tue, Jun 15, 2021 at 11:14 AM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>>> > > Hi Gentlemen,
>>> > > Thanks very much for your quick replies!
>>> > > I just tried both, but perhaps I'm misinterpreting your suggestions.
>>> > > (Could you please see the attached commands / errors!)
>>> > > Eshan,
>>> > > I did see that link, but it wasn't clear to me what the solution was...Sorry!
>>> > > Sincerely,
>>> > > Matt
>>> > > On Tue, Jun 15, 2021 at 6:52 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>>> > > > Hi Matt,
>>> > > > Try running the command with autoconf version 2.69 that's shipped with RTEMS in the rtems bin
>>> > > > That works as well.
>>> > > > Also From a quick google search this is what I found : https://superuser.com/questions/617872/cant-locate-autom4te-channeldefs-pm-in-inc-when-it-definitely-is-there
>>> > > > On Tue, Jun 15, 2021 at 9:12 PM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>>> > > >> Hello Dr. Joel and Eshan,
>>> > > >> I have a patch ready to send to Newlib for the sig function prototypes
>>> > > >> and STR2SIG_MAX.
>>> > > >> But to do that, I think I need to have Newlib built, which I must
>>> > > >> still be doing wrong. The error that I am getting is attached below.
>>> > > >> I’ve been trying to follow the steps here:
>>> > > >> https://medium.com/my-gsoc-2019-journey/apply-newlib-patch-to-rtems-source-builder-6873b0fb31b8
>>> > > >> and https://medium.com/my-gsoc-2019-journey/build-newlib-for-sparc-and-arm-architecture-6b3287d4c6f2
>>> > > >> I even had rebuilt everything from scratch to see if that would help,
>>> > > >> but I still get the same error. Maybe I cloned the newlib source into
>>> > > >> the wrong directory?
>>> > > >> I was hoping to get the patch off to Newlib for review as a first step
>>> > > >> while I work on writing the actual methods. When you get a moment,
>>> > > >> could you please advise? Thank you very much!
>>> > > >> Sincerely,
>>> > > >> Matt
>>> > > _______________________________________________
>>> > > devel mailing list
>>> > > devel at rtems.org
>>> > > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
