[PATCH rtems-libbsd 2/2] builder.py: Only disable tests if they are there
Christian Mauderer
oss at c-mauderer.de
Wed Jun 16 09:40:43 UTC 2021
On 15/06/2021 17:11, Gedare Bloom wrote:
> ok
Thanks.
> On Fri, Jun 11, 2021 at 6:20 AM Christian Mauderer <oss at c-mauderer.de> wrote:
>> For checking the dependencies, the tests are removed. But if the tests
>> are not enabled at all, that triggers a python exception.
>> builder.py | 3 ++-
>> 1 file changed, 2 insertions(+), 1 deletion(-)
>> diff --git a/builder.py b/builder.py
>> index cbe5dc59..a34a1518 100755
>> --- a/builder.py
>> +++ b/builder.py
>> @@ -1062,7 +1062,8 @@ class ModuleManager(object):
>> def _checkDependencies(self):
>> enabled_modules = self.getEnabledModules()
>> - enabled_modules.remove('tests')
>> + if 'tests' in enabled_modules:
>> + enabled_modules.remove('tests')
>> for mod in enabled_modules:
>> if mod not in self.modules:
>> raise KeyError('enabled module not found: %s' % (mod))
>> 2.32.0
>> devel mailing list
>> devel at rtems.org
