[PATCH rtems-libbsd 2/2] builder.py: Only disable tests if they are there
Gedare Bloom
gedare at rtems.org
Tue Jun 15 15:11:08 UTC 2021
ok
On Fri, Jun 11, 2021 at 6:20 AM Christian Mauderer <oss at c-mauderer.de> wrote:
> For checking the dependencies, the tests are removed. But if the tests
> are not enabled at all, that triggers a python exception.
> builder.py | 3 ++-
> 1 file changed, 2 insertions(+), 1 deletion(-)
> diff --git a/builder.py b/builder.py
> index cbe5dc59..a34a1518 100755
> --- a/builder.py
> +++ b/builder.py
> @@ -1062,7 +1062,8 @@ class ModuleManager(object):
> def _checkDependencies(self):
> enabled_modules = self.getEnabledModules()
> - enabled_modules.remove('tests')
> + if 'tests' in enabled_modules:
> + enabled_modules.remove('tests')
> for mod in enabled_modules:
> if mod not in self.modules:
> raise KeyError('enabled module not found: %s' % (mod))
> 2.32.0
> devel mailing list
> devel at rtems.org
