GSOC POSIX Compliance: Stuck trying to build Newlib
Wed Jun 16 16:42:59 UTC 2021
On Wed, Jun 16, 2021 at 11:37 AM Matthew Joyce <mfjoyce2004 at gmail.com>
wrote:
> I hate to ask, but where should the build binaries be if "make all"
> was actually successful?
For newlib, there should be various libc.a and libm.a files in the build
directory.
Use find to locate them: find . -name libc.a
And use "nm" to find out if the symbol is there.
sparc-rtems6-nm .../libc.a
You can save that output or pipe it to less.
Note: paths need to be adjusted to the files.
--joel
> Thanks!
> Matt
> On Wed, Jun 16, 2021 at 6:16 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
> > Hi Matt,
> > > On 16-Jun-2021, at 9:27 PM, Matthew Joyce <mfjoyce2004 at gmail.com>
> wrote:
> > > Hi Dr. Joel,
> > > I tried that in newlib/libc and there were at least no errors.
> > > (Nothing leading me to believe it was successful either!)
> > > However I still got the same error when I sudo make install.
> > > (sparc-rtems-ranlib: command not found) (among others!)
> > I make works then there is no need to run make install it just copies
> the build binaries to the root folders.
> > If make is build with the changes u made and the symbols that you added
> appear in the binaries you generated.
> > Then congratulations :)
> > Now you just need to test those changes in the RSB to test they don’t
> break anything in the RTEMS ecosystem.
> > > Thanks again!
> > > Sincerely,
> > > Matt
> > >> On Wed, Jun 16, 2021 at 3:06 PM Joel Sherrill <joel at rtems.org> wrote:
> > >> Does adding --no-recursive and running it only from the directory you
> touched a build system file in help?
> > >> It is regenerating a lot you don't want to touch anyway.
> > >> --joel
> > >>> On Wed, Jun 16, 2021, 5:32 AM Matthew Joyce <mfjoyce2004 at gmail.com>
> wrote:
> > >>> Hi Eshan,
> > >>> Thanks very much for your follow up! Ok, I see now that if I go into
> > >>> development/newlib/newlib-cygwin/newlib and run autoreconf -fvi with
> > >>> the v2.69 using the PATH that Dr. Joel just showed, it starts to run.
> > >>> It always eventually exits with an error though. (please see attached
> > >>> .txt). I hope you can read that...I used the command "script" to
> > >>> output everything to a text file.
> > >>> Do you have any idea where I might be going wrong?
> > >>> Thank you!
> > >>> Sincerely,
> > >>> Matt
> > >>> On Tue, Jun 15, 2021 at 8:23 PM Eshan Dhawan <
> eshandhawan51 at gmail.com> wrote:
> > >>>> Hi matt
> > >>>> It would work if run inside newlib instead of newlib-cygwin
> > >>>> run command inside of ../newlib-cygwin/newlib
> > >>>> instead of ../newlib-cygwin
> > >>>> On Tue, Jun 15, 2021 at 10:59 PM Matthew Joyce <
> mfjoyce2004 at gmail.com> wrote:
> > >>>>> Ah, ok will do! Thank you for the tip.
> > >>>>> On Tue, Jun 15, 2021 at 7:17 PM Gedare Bloom <gedare at rtems.org>
> wrote:
> > >>>>>> Just a note, it's more efficient to capture your terminal dump
> into a
> > >>>>>> text file and attach that, rather than put a screenshot up.
> > >>>>>> On Tue, Jun 15, 2021 at 11:14 AM Matthew Joyce <
> > >>>>>>> Hi Gentlemen,
> > >>>>>>> Thanks very much for your quick replies!
> > >>>>>>> I just tried both, but perhaps I'm misinterpreting your
> suggestions.
> > >>>>>>> (Could you please see the attached commands / errors!)
> > >>>>>>> Eshan,
> > >>>>>>> I did see that link, but it wasn't clear to me what the solution
> was...Sorry!
> > >>>>>>> Sincerely,
> > >>>>>>> Matt
> > >>>>>>> On Tue, Jun 15, 2021 at 6:52 PM Eshan Dhawan <
> > >>>>>>>> Hi Matt,
> > >>>>>>>> Try running the command with autoconf version 2.69 that's
> shipped with RTEMS in the rtems bin
> > >>>>>>>> That works as well.
> > >>>>>>>> Also From a quick google search this is what I found :
> https://superuser.com/questions/617872/cant-locate-autom4te-channeldefs-pm-in-inc-when-it-definitely-is-there
> > >>>>>>>> On Tue, Jun 15, 2021 at 9:12 PM Matthew Joyce <
> > >>>>>>>>> Hello Dr. Joel and Eshan,
> > >>>>>>>>> I have a patch ready to send to Newlib for the sig function
> prototypes
> > >>>>>>>>> and STR2SIG_MAX.
> > >>>>>>>>> But to do that, I think I need to have Newlib built, which I
> must
> > >>>>>>>>> still be doing wrong. The error that I am getting is attached
> below.
> > >>>>>>>>> I’ve been trying to follow the steps here:
> https://medium.com/my-gsoc-2019-journey/apply-newlib-patch-to-rtems-source-builder-6873b0fb31b8
> > >>>>>>>>> and
> https://medium.com/my-gsoc-2019-journey/build-newlib-for-sparc-and-arm-architecture-6b3287d4c6f2
> > >>>>>>>>> I even had rebuilt everything from scratch to see if that
> would help,
> > >>>>>>>>> but I still get the same error. Maybe I cloned the newlib
> source into
> > >>>>>>>>> the wrong directory?
> > >>>>>>>>> I was hoping to get the patch off to Newlib for review as a
> first step
> > >>>>>>>>> while I work on writing the actual methods. When you get a
> moment,
> > >>>>>>>>> could you please advise? Thank you very much!
> > >>>>>>>>> Sincerely,
> > >>>>>>>>> Matt
> > >>>>>>> _______________________________________________
> > >>>>>>> devel mailing list
> > >>>>>>> devel at rtems.org
> > >>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210616/42c63542/attachment.html>
