GSOC POSIX Compliance: Stuck trying to build Newlib
Matthew Joyce
mfjoyce2004 at gmail.com
Wed Jun 16 16:50:12 UTC 2021
Ok, thanks!
I'm about to sign off for dinner, but I'll send the patch (with
disclaimer) tonight. So since the code fails to compile, I need to
start making some changes. Do I need to rebuild the rtems tool chain
each time? I'm averaging about 1.33 hours on that :-( . Is that where
some of the scripts you sent help out?
Sorry we didn't connect tonight, but please let me know if there's
another day this week you could chat!
Thanks so much for everybody's patience and support!
Sincerely,
Matt
On Wed, Jun 16, 2021 at 6:43 PM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Jun 16, 2021 at 11:37 AM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>> I hate to ask, but where should the build binaries be if "make all"
>> was actually successful?
> For newlib, there should be various libc.a and libm.a files in the build directory.
> Use find to locate them: find . -name libc.a
> And use "nm" to find out if the symbol is there.
> sparc-rtems6-nm .../libc.a
> You can save that output or pipe it to less.
> Note: paths need to be adjusted to the files.
> --joel
>> Thanks!
>> Matt
>> On Wed, Jun 16, 2021 at 6:16 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>> > Hi Matt,
>> > > On 16-Jun-2021, at 9:27 PM, Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>> > > Hi Dr. Joel,
>> > > I tried that in newlib/libc and there were at least no errors.
>> > > (Nothing leading me to believe it was successful either!)
>> > > However I still got the same error when I sudo make install.
>> > > (sparc-rtems-ranlib: command not found) (among others!)
>> > I make works then there is no need to run make install it just copies the build binaries to the root folders.
>> > If make is build with the changes u made and the symbols that you added appear in the binaries you generated.
>> > Then congratulations :)
>> > Now you just need to test those changes in the RSB to test they don’t break anything in the RTEMS ecosystem.
>> > > Thanks again!
>> > > Sincerely,
>> > > Matt
>> > >> On Wed, Jun 16, 2021 at 3:06 PM Joel Sherrill <joel at rtems.org> wrote:
>> > >> Does adding --no-recursive and running it only from the directory you touched a build system file in help?
>> > >> It is regenerating a lot you don't want to touch anyway.
>> > >> --joel
>> > >>> On Wed, Jun 16, 2021, 5:32 AM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>> > >>> Hi Eshan,
>> > >>> Thanks very much for your follow up! Ok, I see now that if I go into
>> > >>> development/newlib/newlib-cygwin/newlib and run autoreconf -fvi with
>> > >>> the v2.69 using the PATH that Dr. Joel just showed, it starts to run.
>> > >>> It always eventually exits with an error though. (please see attached
>> > >>> .txt). I hope you can read that...I used the command "script" to
>> > >>> output everything to a text file.
>> > >>> Do you have any idea where I might be going wrong?
>> > >>> Thank you!
>> > >>> Sincerely,
>> > >>> Matt
>> > >>> On Tue, Jun 15, 2021 at 8:23 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>> > >>>> Hi matt
>> > >>>> It would work if run inside newlib instead of newlib-cygwin
>> > >>>> run command inside of ../newlib-cygwin/newlib
>> > >>>> instead of ../newlib-cygwin
>> > >>>> On Tue, Jun 15, 2021 at 10:59 PM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>> > >>>>> Ah, ok will do! Thank you for the tip.
>> > >>>>> On Tue, Jun 15, 2021 at 7:17 PM Gedare Bloom <gedare at rtems.org> wrote:
>> > >>>>>> Just a note, it's more efficient to capture your terminal dump into a
>> > >>>>>> text file and attach that, rather than put a screenshot up.
>> > >>>>>> On Tue, Jun 15, 2021 at 11:14 AM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>> > >>>>>>> Hi Gentlemen,
>> > >>>>>>> Thanks very much for your quick replies!
>> > >>>>>>> I just tried both, but perhaps I'm misinterpreting your suggestions.
>> > >>>>>>> (Could you please see the attached commands / errors!)
>> > >>>>>>> Eshan,
>> > >>>>>>> I did see that link, but it wasn't clear to me what the solution was...Sorry!
>> > >>>>>>> Sincerely,
>> > >>>>>>> Matt
>> > >>>>>>> On Tue, Jun 15, 2021 at 6:52 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>> > >>>>>>>> Hi Matt,
>> > >>>>>>>> Try running the command with autoconf version 2.69 that's shipped with RTEMS in the rtems bin
>> > >>>>>>>> That works as well.
>> > >>>>>>>> Also From a quick google search this is what I found : https://superuser.com/questions/617872/cant-locate-autom4te-channeldefs-pm-in-inc-when-it-definitely-is-there
>> > >>>>>>>> On Tue, Jun 15, 2021 at 9:12 PM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
>> > >>>>>>>>> Hello Dr. Joel and Eshan,
>> > >>>>>>>>> I have a patch ready to send to Newlib for the sig function prototypes
>> > >>>>>>>>> and STR2SIG_MAX.
>> > >>>>>>>>> But to do that, I think I need to have Newlib built, which I must
>> > >>>>>>>>> still be doing wrong. The error that I am getting is attached below.
>> > >>>>>>>>> I’ve been trying to follow the steps here:
>> > >>>>>>>>> https://medium.com/my-gsoc-2019-journey/apply-newlib-patch-to-rtems-source-builder-6873b0fb31b8
>> > >>>>>>>>> and https://medium.com/my-gsoc-2019-journey/build-newlib-for-sparc-and-arm-architecture-6b3287d4c6f2
>> > >>>>>>>>> I even had rebuilt everything from scratch to see if that would help,
>> > >>>>>>>>> but I still get the same error. Maybe I cloned the newlib source into
>> > >>>>>>>>> the wrong directory?
>> > >>>>>>>>> I was hoping to get the patch off to Newlib for review as a first step
>> > >>>>>>>>> while I work on writing the actual methods. When you get a moment,
>> > >>>>>>>>> could you please advise? Thank you very much!
>> > >>>>>>>>> Sincerely,
>> > >>>>>>>>> Matt
>> > >>>>>>> _______________________________________________
>> > >>>>>>> devel mailing list
>> > >>>>>>> devel at rtems.org
>> > >>>>>>> http://lists.rtems.org/mailman/listinfo/devel
