[PATCH rtems-libbsd v3 2/4] rtemsbsd:Updated TTCP code with network demo code
Stephen Clark
stephen.clark at oarcorp.com
Wed Jun 16 17:46:12 UTC 2021
Updated the TTCP code to match the ttcp.c in RTEMS network-demos
repository (https://git.rtems.org/network-demos/).
rtemsbsd/ttcp/ttcp.c | 91 +++++++++++++++++++++++++++++++-------------
1 file changed, 65 insertions(+), 26 deletions(-)
diff --git a/rtemsbsd/ttcp/ttcp.c b/rtemsbsd/ttcp/ttcp.c
index 305a7c7d..dc62c64b 100644
--- a/rtemsbsd/ttcp/ttcp.c
+++ b/rtemsbsd/ttcp/ttcp.c
@@ -35,8 +35,9 @@
* Distribution Status -
* Public Domain. Distribution Unlimited.
#ifndef lint
-static char RCSid[] = "ttcp.c $Revision$";
+/* static char RCSid[] = "ttcp.c $Revision$"; */
#endif
#define BSD43
@@ -44,6 +45,8 @@ static char RCSid[] = "ttcp.c $Revision$";
/* #define BSD41a */
/* #define SYSV */ /* required on SGI IRIX releases before 3.3 */
+#define ENABLE_NANOSLEEP_DELAY
#include <signal.h>
#include <ctype.h>
@@ -54,8 +57,12 @@ static char RCSid[] = "ttcp.c $Revision$";
#include <netinet/tcp.h>
#include <arpa/inet.h>
#include <netdb.h>
+#include <string.h>
#include <sys/time.h> /* struct timeval */
+#include <unistd.h>
+#include <stdlib.h>
#if defined(SYSV)
#include <sys/times.h>
#include <sys/param.h>
@@ -71,7 +78,13 @@ struct sockaddr_in sinme;
struct sockaddr_in sinhim;
struct sockaddr_in frominet;
-int domain, fromlen;
+/* these make it easier to avoid warnings */
+struct sockaddr *sinhim_p = (struct sockaddr *) &sinhim;
+struct sockaddr *sinme_p = (struct sockaddr *) &sinme;
+struct sockaddr *frominet_p = (struct sockaddr *) &frominet;
+int domain;
+socklen_t fromlen;
int fd; /* fd of network socket */
int buflen = 8 * 1024; /* length of buffer */
@@ -97,6 +110,7 @@ char fmt = 'K'; /* output format: k = kilobits, K = kilobytes,
* m = megabits, M = megabytes,
* g = gigabits, G = gigabytes */
int touchdata = 0; /* access data after reading */
+long milliseconds = 0; /* delay in milliseconds */
struct hostent *addr;
extern int errno;
@@ -124,6 +138,7 @@ Options specific to -t:\n\
Options specific to -r:\n\
-B for -s, only output full blocks as specified by -l (for TAR)\n\
-T \"touch\": access each byte as it's read\n\
+ -m ## delay for specified milliseconds between each write\n\
char stats[128];
@@ -133,7 +148,7 @@ double cput, realt; /* user, real time (seconds) */
void err();
void mes();
-int pattern();
+void pattern();
void prep_timer();
double read_timer();
int Nread();
@@ -147,7 +162,18 @@ sigpipe()
-main(argc,argv)
+void millisleep(long msec)
+#if defined(ENABLE_NANOSLEEP_DELAY)
+ struct timespec req;
+ req.tv_sec = msec / 1000;
+ req.tv_nsec = (msec % 1000) * 1000000;
+ nanosleep( &req, NULL );
+#endif
+int main(argc,argv)
int argc;
char **argv;
@@ -156,7 +182,7 @@ char **argv;
if (argc < 2) goto usage;
- while ((c = getopt(argc, argv, "drstuvBDTb:f:l:n:p:A:O:")) != -1) {
+ while ((c = getopt(argc, argv, "drstuvBDTb:f:l:m:n:p:A:O:")) != -1) {
switch (c) {
case 'B':
@@ -179,6 +205,12 @@ char **argv;
"ttcp: -D option ignored: TCP_NODELAY socket option not supported\n");
#endif
break;
+ case 'm':
+ milliseconds = atoi(optarg);
+ #if !defined(ENABLE_NANOSLEEP_DELAY)
+ fprintf(stderr, "millisecond delay disabled\n");
+ #endif
+ break;
case 'n':
nbuf = atoi(optarg);
break;
@@ -285,7 +317,7 @@ char **argv;
err("socket");
mes("socket");
- if (bind(fd, &sinme, sizeof(sinme)) < 0)
+ if (bind(fd, sinme_p, sizeof(sinme)) < 0)
err("bind");
#if defined(SO_SNDBUF) || defined(SO_RCVBUF)
@@ -305,7 +337,9 @@ char **argv;
#endif
if (!udp) {
+#if !defined(__rtems__)
signal(SIGPIPE, sigpipe);
+#endif
if (trans) {
/* We are the client if transmitting */
if (options) {
@@ -326,7 +360,7 @@ char **argv;
mes("nodelay");
#endif
- if(connect(fd, &sinhim, sizeof(sinhim) ) < 0)
+ if(connect(fd, sinhim_p, sizeof(sinhim) ) < 0)
err("connect");
mes("connect");
} else {
@@ -348,11 +382,11 @@ char **argv;
fromlen = sizeof(frominet);
domain = AF_INET;
- if((fd=accept(fd, &frominet, &fromlen) ) < 0)
+ if((fd=accept(fd, frominet_p, &fromlen) ) < 0)
err("accept");
{ struct sockaddr_in peer;
- int peerlen = sizeof(peer);
- if (getpeername(fd, (struct sockaddr_in *) &peer,
+ socklen_t peerlen = sizeof(peer);
+ if (getpeername(fd, (struct sockaddr *) &peer,
&peerlen) < 0) {
err("getpeername");
@@ -368,8 +402,10 @@ char **argv;
if (trans) {
pattern( buf, buflen );
if(udp) (void)Nwrite( fd, buf, 4 ); /* rcvr start */
- while (nbuf-- && Nwrite(fd,buf,buflen) == buflen)
+ while (nbuf-- && Nwrite(fd,buf,buflen) == buflen) {
nbytes += buflen;
+ millisleep( milliseconds );
if(udp) (void)Nwrite( fd, buf, 4 ); /* rcvr end */
} else {
if (udp) {
@@ -423,7 +459,7 @@ char **argv;
nbytes, cput, outfmt(nbytes/cput));
fprintf(stdout,
- "ttcp%s: %d I/O calls, msec/call = %.2f, calls/sec = %.2f\n",
+ "ttcp%s: %ld I/O calls, msec/call = %.2f, calls/sec = %.2f\n",
trans?"-t":"-r",
numCalls,
1024.0 * realt/((double)numCalls),
@@ -431,7 +467,7 @@ char **argv;
fprintf(stdout,"ttcp%s: %s\n", trans?"-t":"-r", stats);
if (verbose) {
fprintf(stdout,
- "ttcp%s: buffer address %#x\n",
+ "ttcp%s: buffer address %p\n",
trans?"-t":"-r",
buf);
@@ -440,6 +476,7 @@ char **argv;
usage:
fprintf(stderr,Usage);
exit(1);
+ return 0;
void
@@ -459,7 +496,7 @@ char *s;
fprintf(stderr,"ttcp%s: %s\n", trans?"-t":"-r", s);
-pattern( cp, cnt )
+void pattern( cp, cnt )
register char *cp;
register int cnt;
@@ -554,6 +591,7 @@ prep_timer()
double
read_timer(str,len)
char *str;
+int len;
struct timeval timedol;
struct rusage ru1;
@@ -614,13 +652,13 @@ prusage(r0, r1, e, b, outp)
case 'U':
tvsub(&tdiff, &r1->ru_utime, &r0->ru_utime);
- sprintf(outp,"%d.%01d", tdiff.tv_sec, tdiff.tv_usec/100000);
+ sprintf(outp,"%ld.%01ld", tdiff.tv_sec, tdiff.tv_usec/100000);
END(outp);
break;
case 'S':
tvsub(&tdiff, &r1->ru_stime, &r0->ru_stime);
END(outp);
break;
@@ -642,18 +680,18 @@ prusage(r0, r1, e, b, outp)
break;
case 'X':
- sprintf(outp,"%d", t == 0 ? 0 : (r1->ru_ixrss-r0->ru_ixrss)/t);
+ sprintf(outp,"%ld", t == 0 ? 0 : (r1->ru_ixrss-r0->ru_ixrss)/t);
END(outp);
break;
case 'D':
(r1->ru_idrss+r1->ru_isrss-(r0->ru_idrss+r0->ru_isrss))/t);
END(outp);
break;
case 'K':
((r1->ru_ixrss+r1->ru_isrss+r1->ru_idrss) -
(r0->ru_ixrss+r0->ru_idrss+r0->ru_isrss))/t);
END(outp);
@@ -743,16 +781,16 @@ register char *cp;
* N R E A D
-Nread( fd, buf, count )
+int Nread( fd, buf, count )
int fd;
void *buf;
int count;
struct sockaddr_in from;
- int len = sizeof(from);
+ socklen_t len = sizeof(from);
register int cnt;
if( udp ) {
- cnt = recvfrom( fd, buf, count, 0, &from, &len );
+ cnt = recvfrom( fd, buf, count, 0, (struct sockaddr *)&from, &len );
numCalls++;
} else {
if( b_flag )
@@ -774,7 +812,7 @@ int count;
* N W R I T E
-Nwrite( fd, buf, count )
+int Nwrite( fd, buf, count )
int fd;
void *buf;
int count;
@@ -782,9 +820,10 @@ int count;
register int cnt;
if( udp ) {
again:
- cnt = sendto( fd, buf, count, 0, &sinhim, sizeof(sinhim) );
+ cnt = sendto( fd, buf, count, 0, sinhim_p, sizeof(sinhim) );
numCalls++;
if( cnt<0 && errno == ENOBUFS ) {
+ printf("ttcp: out of buffers -- delaying\n"); /*JRS*/
delay(18000);
errno = 0;
goto again;
@@ -797,13 +836,13 @@ again:
void
-delay(us)
+delay(int us)
struct timeval tv;
tv.tv_sec = 0;
tv.tv_usec = us;
- (void)select( 1, (char *)0, (char *)0, (char *)0, &tv );
+ (void)select( 1, (fd_set *)0, (fd_set *)0, (fd_set *)0, &tv );
2.27.0
