[PATCH rtems-libbsd v3 4/4] rtemsbsd: Added a test for the TTCP command.
Stephen Clark stephen.clark at oarcorp.com
Wed Jun 16 17:46:14 UTC 2021
Added a new test for the TTCP command. Modified default-network-init.h
to conditionally build the shell with TTCP. Modified libbsd.py to build
the new TTCP test.
 libbsd.py                                     |  1 +
 .../rtems/bsd/test/default-network-init.h     |  7 +++
 testsuite/ttcpshell01/test_main.c             | 55 +++++++++++++++++++
 3 files changed, 63 insertions(+)
 create mode 100644 testsuite/ttcpshell01/test_main.c
diff --git a/libbsd.py b/libbsd.py
index 2badfdee..cb310770 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -5189,6 +5189,7 @@ class tests(builder.Module):
     def generate(self):
         mm = self.manager
+        self.addTest(mm.generator['test']('ttcpshell01', ['test_main'], netTest = True, runTest = False))
         self.addTest(mm.generator['test']('epoch01', ['test_main'], extraLibs = ['rtemstest']))
         self.addTest(mm.generator['test']('nfs01', ['test_main'],
                                           netTest = True, modules = ['nfsv2']))
diff --git a/testsuite/include/rtems/bsd/test/default-network-init.h b/testsuite/include/rtems/bsd/test/default-network-init.h
index b367d956..20c0b2e7 100644
--- a/testsuite/include/rtems/bsd/test/default-network-init.h
+++ b/testsuite/include/rtems/bsd/test/default-network-init.h
@@ -318,9 +318,16 @@ Init(rtems_task_argument arg)
   #define SHELL_WPA_SUPPLICANT_COMMAND
 #endif
+#ifdef SHELL_TTCP_COMMAND_ENABLE
+  #define SHELL_TTCP_COMMAND &rtems_shell_TTCP_Command,
+#else
+#endif
 #define CONFIGURE_SHELL_USER_COMMANDS \
   SHELL_WLANSTATS_COMMAND \
   SHELL_WPA_SUPPLICANT_COMMAND \
+  SHELL_TTCP_COMMAND \
   &bsp_interrupt_shell_command, \
   &rtems_shell_ARP_Command, \
   &rtems_shell_HOSTNAME_Command, \
diff --git a/testsuite/ttcpshell01/test_main.c b/testsuite/ttcpshell01/test_main.c
new file mode 100644
index 00000000..c7631d14
--- /dev/null
+++ b/testsuite/ttcpshell01/test_main.c
@@ -0,0 +1,55 @@
+ * @file
+ * @brief RTEMS shell is started with DHCP client. It is possible to run TTCP.
+ * COPYRIGHT (c) 2021. On-Line Applications Research Corporation (OAR).
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <assert.h>
+#include <rtems.h>
+#include <rtems/shell.h>
+#include <rtems/console.h>
+#define TEST_NAME "LIBBSD TTCP 1"
+#define TEST_STATE_USER_INPUT 1
+static void
+test_main(void)
+	rtems_task_delete(RTEMS_SELF);
+	assert(0);
+#define SHELL_TTCP_COMMAND_ENABLE
+#define DEFAULT_NETWORK_DHCPCD_ENABLE
+#define DEFAULT_NETWORK_SHELL
+#include <rtems/bsd/test/default-network-init.h>
2.27.0
