[PATCH v2 1/1] bsps/i386: Update calibration of TSC to be more accurate
Wed Jun 16 18:06:10 UTC 2021
Me too. Just needs separate tickets for 5 and 6 so the release notes are
generated correctly.
On Wed, Jun 16, 2021 at 12:51 PM Gedare Bloom <gedare at rtems.org> wrote:
> I'm good with it for master and 5.
> On Wed, Jun 16, 2021 at 4:18 AM Jan Sommer <jan.sommer at dlr.de> wrote:
> > Closes #4455
> >  bsps/i386/pc386/clock/ckinit.c | 71 ++++++++++++++++++----------------
> >  1 file changed, 38 insertions(+), 33 deletions(-)
> > diff --git a/bsps/i386/pc386/clock/ckinit.c
> b/bsps/i386/pc386/clock/ckinit.c
> > index 09afe73cde..2df1818dd3 100644
> > --- a/bsps/i386/pc386/clock/ckinit.c
> > +++ b/bsps/i386/pc386/clock/ckinit.c
> > @@ -104,48 +104,60 @@ static uint32_t pc386_get_timecount_i8254(struct
> timecounter *tc)
> >   * Calibrate CPU cycles per tick. Interrupts should be disabled.
> > + * Will also set the PIT, so call this before registering the
> > + * periodic timer for rtems tick generation
> >  static void calibrate_tsc(void)
> >    uint64_t              begin_time;
> > -  uint8_t               then_lsb, then_msb, now_lsb, now_msb;
> > -  uint32_t              i;
> > -   * We just reset the timer, so we know we're at the beginning of a
> tick.
> > -   * Count cycles. Watching the timer introduces a several microsecond
> > -   * uncertaintity, so let it cook for a while and divide by the number
> of
> > -   * ticks actually executed.
> > +  uint8_t               lsb, msb;
> > +  uint32_t              max_timer_value;
> > +  uint32_t              last_tick, cur_tick;
> > +  int32_t               diff, remaining;
> > +  /* Set the timer to free running mode */
> > +  outport_byte(TIMER_MODE, TIMER_SEL0 | TIMER_16BIT | TIMER_INTTC);
> > +  /* Reset the 16 timer reload value, first LSB, then MSB */
> > +  outport_byte(TIMER_CNTR0, 0);
> > +  /* We use the full 16 bit */
> > +  max_timer_value = 0xffff;
> > +  /* Calibrate for 1s, i.e. TIMER_TICK PIT ticks */
> > +  remaining = TIMER_TICK;
> >    begin_time = rdtsc();
> > -  for (i = rtems_clock_get_ticks_per_second() * pc386_isrs_per_tick;
> > -       i != 0; --i ) {
> > -    /* We know we've just completed a tick when timer goes from low to
> high */
> > -    then_lsb = then_msb = 0xff;
> > -    do {
> > -      READ_8254(now_lsb, now_msb);
> > -      if ((then_msb < now_msb) ||
> > -          ((then_msb == now_msb) && (then_lsb < now_lsb)))
> > -        break;
> > -      then_lsb = now_lsb;
> > -      then_msb = now_msb;
> > -    } while (1);
> > +  READ_8254(lsb, msb);
> > +  last_tick = (msb << 8) | lsb;
> > +  while(remaining > 0) {
> > +    cur_tick = (msb << 8) | lsb;
> > +    /* PIT counts down, so subtract cur from last */
> > +    diff = last_tick - cur_tick;
> > +    last_tick = cur_tick;
> > +    if (diff < 0) {
> > +        diff += max_timer_value;
> > +    remaining -= diff;
> >    pc586_tsc_frequency = rdtsc() - begin_time;
> >  #if 0
> > -  printk( "CPU clock at %u MHz\n", (uint32_t)(pc586_tsc_frequency /
> 1000000));
> > +  printk( "CPU clock at %u Hz\n", (uint32_t)(pc586_tsc_frequency ));
> >  #endif
> >  static void clockOn(void)
> > +   * First calibrate the TSC. Do this every time we
> > +   * turn the clock on in case the CPU clock speed has changed.
> > +  if ( x86_has_tsc() ) {
> > +    calibrate_tsc();
> >    rtems_interrupt_lock_context lock_context;
> >    pc386_isrs_per_tick        = 1;
> >    pc386_microseconds_per_isr =
> rtems_configuration_get_microseconds_per_tick();
> > @@ -171,13 +183,6 @@ static void clockOn(void)
> >    rtems_interrupt_lock_release(&rtems_i386_i8254_access_lock,
> &lock_context);
> >    bsp_interrupt_vector_enable( BSP_PERIODIC_TIMER );
> > -   * Now calibrate cycles per tick. Do this every time we
> > -   * turn the clock on in case the CPU clock speed has changed.
> > -  if ( x86_has_tsc() )
> > -    calibrate_tsc();
> >  bool Clock_isr_enabled = false;
> > 2.17.1
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210616/58c3b733/attachment.html>
