[PATCH v2 1/1] bsps/i386: Update calibration of TSC to be more accurate
Jan.Sommer at dlr.de
Thu Jun 17 13:52:15 UTC 2021
Thanks, I prepared tickets for master and 5.
I will make sure that the link in the commit message fits the right ticket of the corresponding branch.
My plan is to push that on Monday, when I am back in the office
Best regards,
Jan
Sent: Wednesday, June 16, 2021 8:06 PM
To: Gedare Bloom <gedare at rtems.org>
Cc: Sommer, Jan <Jan.Sommer at dlr.de>; devel at rtems.org
Subject: Re: [PATCH v2 1/1] bsps/i386: Update calibration of TSC to be more accurate
Me too. Just needs separate tickets for 5 and 6 so the release notes are generated correctly.
On Wed, Jun 16, 2021 at 12:51 PM Gedare Bloom <gedare at rtems.org<mailto:gedare at rtems.org>> wrote:
I'm good with it for master and 5.
On Wed, Jun 16, 2021 at 4:18 AM Jan Sommer <jan.sommer at dlr.de<mailto:jan.sommer at dlr.de>> wrote:
> Closes #4455
> bsps/i386/pc386/clock/ckinit.c | 71 ++++++++++++++++++----------------
> 1 file changed, 38 insertions(+), 33 deletions(-)
> diff --git a/bsps/i386/pc386/clock/ckinit.c b/bsps/i386/pc386/clock/ckinit.c
> index 09afe73cde..2df1818dd3 100644
> --- a/bsps/i386/pc386/clock/ckinit.c
> +++ b/bsps/i386/pc386/clock/ckinit.c
> @@ -104,48 +104,60 @@ static uint32_t pc386_get_timecount_i8254(struct timecounter *tc)
> * Calibrate CPU cycles per tick. Interrupts should be disabled.
> + * Will also set the PIT, so call this before registering the
> + * periodic timer for rtems tick generation
> static void calibrate_tsc(void)
> uint64_t begin_time;
> - uint8_t then_lsb, then_msb, now_lsb, now_msb;
> - uint32_t i;
> - * We just reset the timer, so we know we're at the beginning of a tick.
> - * Count cycles. Watching the timer introduces a several microsecond
> - * uncertaintity, so let it cook for a while and divide by the number of
> - * ticks actually executed.
> + uint8_t lsb, msb;
> + uint32_t max_timer_value;
> + uint32_t last_tick, cur_tick;
> + int32_t diff, remaining;
> + /* Set the timer to free running mode */
> + outport_byte(TIMER_MODE, TIMER_SEL0 | TIMER_16BIT | TIMER_INTTC);
> + /* Reset the 16 timer reload value, first LSB, then MSB */
> + outport_byte(TIMER_CNTR0, 0);
> + /* We use the full 16 bit */
> + max_timer_value = 0xffff;
> + /* Calibrate for 1s, i.e. TIMER_TICK PIT ticks */
> + remaining = TIMER_TICK;
> begin_time = rdtsc();
> - for (i = rtems_clock_get_ticks_per_second() * pc386_isrs_per_tick;
> - i != 0; --i ) {
> - /* We know we've just completed a tick when timer goes from low to high */
> - then_lsb = then_msb = 0xff;
> - do {
> - READ_8254(now_lsb, now_msb);
> - if ((then_msb < now_msb) ||
> - ((then_msb == now_msb) && (then_lsb < now_lsb)))
> - break;
> - then_lsb = now_lsb;
> - then_msb = now_msb;
> - } while (1);
> + READ_8254(lsb, msb);
> + last_tick = (msb << 8) | lsb;
> + while(remaining > 0) {
> + cur_tick = (msb << 8) | lsb;
> + /* PIT counts down, so subtract cur from last */
> + diff = last_tick - cur_tick;
> + last_tick = cur_tick;
> + if (diff < 0) {
> + diff += max_timer_value;
> + remaining -= diff;
> pc586_tsc_frequency = rdtsc() - begin_time;
> #if 0
> - printk( "CPU clock at %u MHz\n", (uint32_t)(pc586_tsc_frequency / 1000000));
> + printk( "CPU clock at %u Hz\n", (uint32_t)(pc586_tsc_frequency ));
> #endif
> static void clockOn(void)
> + * First calibrate the TSC. Do this every time we
> + * turn the clock on in case the CPU clock speed has changed.
> + if ( x86_has_tsc() ) {
> + calibrate_tsc();
> rtems_interrupt_lock_context lock_context;
> pc386_isrs_per_tick = 1;
> pc386_microseconds_per_isr = rtems_configuration_get_microseconds_per_tick();
> @@ -171,13 +183,6 @@ static void clockOn(void)
> rtems_interrupt_lock_release(&rtems_i386_i8254_access_lock, &lock_context);
> bsp_interrupt_vector_enable( BSP_PERIODIC_TIMER );
> - * Now calibrate cycles per tick. Do this every time we
> - * turn the clock on in case the CPU clock speed has changed.
> - if ( x86_has_tsc() )
> - calibrate_tsc();
> bool Clock_isr_enabled = false;
> 2.17.1
> devel mailing list
> devel at rtems.org<mailto:devel at rtems.org>
devel mailing list
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210617/1f7bd26b/attachment.html>
