[PATCH] libc: Added sig2str/str2sig prototypes
Matthew Joyce
mfjoyce2004 at gmail.com
Thu Jun 17 07:44:41 UTC 2021
Hi Eshan,
Thanks very much for this...It's really helpful!
Question on workflow:
So for this example, I just apply the patch to RSB. Do I understand correctly
that we need to rebuild the tool chain each and every time I make any
change? (Step 7 in
Vaibhav's Blog) This didn't compile, apparently because of the double
restricts. Do I need
to make a change, rebuild the tool chain (around 1.33 hours), and test
again? Hopefully
there are shortcuts around that!
Thanks again for your help.
Sincerely,
Matt
On Wed, Jun 16, 2021 at 10:40 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> Hi Matt,
> Since you are making changes only to a header file you don’t need to run autoreconf.
> You can directly apply the patch to RSB and it should work
> You need to run autoreconf when u make changes in makefile
> That is when u add a .c file
> > On 17-Jun-2021, at 1:53 AM, Matt Joyce <mfjoyce2004 at gmail.com> wrote:
> > ***As Requested: For Review Only. Does Not Compile***
> > Added definition of SIG2STR_MAX and function prototypes for sig2str
> > and str2sig in sys/signal.h in order to improve POSIX compliance.
> > newlib/libc/include/sys/signal.h | 12 ++++++++++++
> > 1 file changed, 12 insertions(+)
> > diff --git a/newlib/libc/include/sys/signal.h b/newlib/libc/include/sys/signal.h
> > index 45cc0366c..fd2b3c672 100644
> > --- a/newlib/libc/include/sys/signal.h
> > +++ b/newlib/libc/include/sys/signal.h
> > @@ -238,6 +238,18 @@ int sigqueue (pid_t, int, const union sigval);
> > #endif /* __POSIX_VISIBLE >= 199309 */
> > +#if __GNU_VISIBLE
> > +/* 202x_d2-POSIX-Issue-8, p. 327 adds SIG2STR_MAX, p. 332 adds sig2str()
> > + and str2sig(). */
> > +#define SIG2STR_MAX 4294967295
> > +int sig2str(int, char *);
> > +int str2sig(const char *restrict, int *restrict);
> > +#endif /* __GNU_VISIBLE */
> > #if defined(___AM29K__)
> > /* These all need to be defined for ANSI C, but I don't think they are
> > meaningful. */
> > 2.31.1
> > devel mailing list
> > devel at rtems.org
