[PATCH] libc: Added sig2str/str2sig prototypes
Eshan Dhawan eshandhawan51 at gmail.com
Thu Jun 17 15:57:01 UTC 2021
> On 17-Jun-2021, at 1:14 PM, Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
> Hi Eshan,
> Thanks very much for this...It's really helpful!
> Question on workflow:
> So for this example, I just apply the patch to RSB. Do I understand correctly
> that we need to rebuild the tool chain each and every time I make any
> change?
Yupp that’s one of the reasons it takes time to work on a patch.
> (Step 7 in
> Vaibhav's Blog) This didn't compile, apparently because of the double
> restricts. Do I need
> to make a change, rebuild the tool chain (around 1.33 hours), and test
> again? Hopefully
> there are shortcuts around that!
You can check for symbols that’s the only way we had
No shortcuts
If it builds for newlib you have to build the complete tool chain to see it doesn’t break the RSB.
Also you have to build the complete rtems Kernel
That’s the only way you can build the test and run on the kernel
Thanks
- Eshan
> Thanks again for your help.
> Sincerely,
> Matt
>> On Wed, Jun 16, 2021 at 10:40 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>> Hi Matt,
>> Since you are making changes only to a header file you don’t need to run autoreconf.
>> You can directly apply the patch to RSB and it should work
>> You need to run autoreconf when u make changes in makefile
>> That is when u add a .c file
>>>> On 17-Jun-2021, at 1:53 AM, Matt Joyce <mfjoyce2004 at gmail.com> wrote:
>>> ***As Requested: For Review Only. Does Not Compile***
>>> Added definition of SIG2STR_MAX and function prototypes for sig2str
>>> and str2sig in sys/signal.h in order to improve POSIX compliance.
>>> newlib/libc/include/sys/signal.h | 12 ++++++++++++
>>> 1 file changed, 12 insertions(+)
>>> diff --git a/newlib/libc/include/sys/signal.h b/newlib/libc/include/sys/signal.h
>>> index 45cc0366c..fd2b3c672 100644
>>> --- a/newlib/libc/include/sys/signal.h
>>> +++ b/newlib/libc/include/sys/signal.h
>>> @@ -238,6 +238,18 @@ int sigqueue (pid_t, int, const union sigval);
>>> #endif /* __POSIX_VISIBLE >= 199309 */
>>> +#if __GNU_VISIBLE
>>> +/* 202x_d2-POSIX-Issue-8, p. 327 adds SIG2STR_MAX, p. 332 adds sig2str()
>>> +   and str2sig(). */
>>> +#define SIG2STR_MAX 4294967295
>>> +int sig2str(int, char *);
>>> +int str2sig(const char *restrict, int *restrict);
>>> +#endif /* __GNU_VISIBLE  */
>>> #if defined(___AM29K__)
>>> /* These all need to be defined for ANSI C, but I don't think they are
>>>   meaningful.  */
>>> 2.31.1
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
