[PATCH] bsps/irq: Change license to BSD-2-Clause
Thu Jun 17 15:17:34 UTC 2021
ok
On Thu, Jun 17, 2021 at 8:14 AM Sebastian Huber
> Change license to BSD-2-Clause according to file history and
> re-licensing agreement.
> Update #3053.
>  bsps/include/bsp/irq-default.h        |  6 ++--
>  bsps/include/bsp/irq-generic.h        | 42 ++++++++++++++++++---------
>  bsps/include/bsp/irq-info.h           | 35 +++++++++++++++-------
>  bsps/shared/irq/irq-default-handler.c | 40 +++++++++++++++++++------
>  bsps/shared/irq/irq-default.c         | 12 +++++---
>  bsps/shared/irq/irq-generic.c         | 36 +++++++++++++++--------
>  bsps/shared/irq/irq-info.c            | 35 +++++++++++++++-------
>  bsps/shared/irq/irq-legacy.c          | 35 +++++++++++++++-------
>  bsps/shared/irq/irq-lock.c            | 36 +++++++++++++++--------
>  bsps/shared/irq/irq-server.c          | 27 ++++++++++++++---
>  bsps/shared/irq/irq-shell.c           | 35 +++++++++++++++-------
>  11 files changed, 242 insertions(+), 97 deletions(-)
> diff --git a/bsps/include/bsp/irq-default.h b/bsps/include/bsp/irq-default.h
> index a94e045e0d..4d7beb189b 100644
> --- a/bsps/include/bsp/irq-default.h
> +++ b/bsps/include/bsp/irq-default.h
> @@ -1,3 +1,5 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
>   * @file
> @@ -5,9 +7,7 @@
> - * SPDX-License-Identifier: BSD-2-Clause
> - * Copyright (C) 2019 embedded brains GmbH
> + * Copyright (C) 2019 embedded brains GmbH (http://www.embedded-brains.de)
>   * Redistribution and use in source and binary forms, with or without
>   * modification, are permitted provided that the following conditions
> diff --git a/bsps/include/bsp/irq-generic.h b/bsps/include/bsp/irq-generic.h
> index 31835d07ba..4135aa518c 100644
> --- a/bsps/include/bsp/irq-generic.h
> +++ b/bsps/include/bsp/irq-generic.h
> @@ -1,27 +1,43 @@
>   * @file
>   * @ingroup bsp_interrupt
> - * @brief Generic BSP interrupt support API.
> + * @brief This header file provides interfaces of the generic interrupt
> + *   controller support.
> - * Based on concepts of Pavel Pisa, Till Straumann and Eric Valette.
> - * Copyright (c) 2008, 2017 embedded brains GmbH.
> + * Copyright (C) 2016 Chris Johns <chrisj at rtems.org>
> - *  embedded brains GmbH
> - *  Dornierstr. 4
> - *  82178 Puchheim
> - *  Germany
> - *  <rtems at embedded-brains.de>
> + * Copyright (C) 2008, 2017 embedded brains GmbH (http://www.embedded-brains.de)
> - * Copyright (c) 2016 Chris Johns <chrisj at rtems.org>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> - * The license and distribution terms for this file may be
> - * found in the file LICENSE in this distribution or at
> - * http://www.rtems.org/license/LICENSE.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> + * The API is based on concepts of Pavel Pisa, Till Straumann and Eric Valette.
>  #ifndef LIBBSP_SHARED_IRQ_GENERIC_H
> diff --git a/bsps/include/bsp/irq-info.h b/bsps/include/bsp/irq-info.h
> index ea6d629e76..25f05a9f69 100644
> --- a/bsps/include/bsp/irq-info.h
> +++ b/bsps/include/bsp/irq-info.h
> @@ -1,22 +1,37 @@
>   * @file
> - * @brief Generic BSP interrupt information API.
> + *   controller support for the RTEMS Shell.
> - * Copyright (c) 2008, 2009
> - * Obere Lagerstr. 30
> - * D-82178 Puchheim
> - * Germany
> + * Copyright (C) 2008, 2009 embedded brains GmbH (http://www.embedded-brains.de)
> + * are met:
>  #ifndef LIBBSP_SHARED_IRQ_INFO_H
> diff --git a/bsps/shared/irq/irq-default-handler.c b/bsps/shared/irq/irq-default-handler.c
> index 4f4b4be673..cfe91f4202 100644
> --- a/bsps/shared/irq/irq-default-handler.c
> +++ b/bsps/shared/irq/irq-default-handler.c
> @@ -1,15 +1,37 @@
> + * @file
> + * @ingroup bsp_interrupt
> + * @brief This source file contains the default implementation of
> + *   bsp_interrupt_handler_default().
> - * Copyright (c) 2008-2012 embedded brains GmbH.  All rights reserved.
> + * Copyright (C) 2008, 2012 embedded brains GmbH (http://www.embedded-brains.de)
> - *  82178 Puchheim
> - *  Germany
> + * are met:
>  #include <inttypes.h>
> diff --git a/bsps/shared/irq/irq-default.c b/bsps/shared/irq/irq-default.c
> index 9295f1fb44..943b4ea191 100644
> --- a/bsps/shared/irq/irq-default.c
> +++ b/bsps/shared/irq/irq-default.c
> @@ -1,13 +1,17 @@
>   * @file
> - * @ingroup RTEMSBSPsShared
> + *   bsp_interrupt_vector_enable(), bsp_interrupt_vector_disable(), and
> + *   bsp_interrupt_facility_initialize().
> diff --git a/bsps/shared/irq/irq-generic.c b/bsps/shared/irq/irq-generic.c
> index fd129333ba..1e83a6f249 100644
> --- a/bsps/shared/irq/irq-generic.c
> +++ b/bsps/shared/irq/irq-generic.c
> @@ -1,25 +1,37 @@
>   * @file
> - * @brief Generic BSP interrupt support implementation.
> + * @brief This source file contains the generic interrupt controller support
> + *   implementation.
> - * Copyright (c) 2008, 2018 embedded brains GmbH.
> + * Copyright (C) 2008, 2018 embedded brains GmbH (http://www.embedded-brains.de)
> - *  Dornierstr. 4
> - *  82178 Puchheim
> - *  Germany
> + * are met:
>  #include <bsp/irq-generic.h>
> diff --git a/bsps/shared/irq/irq-info.c b/bsps/shared/irq/irq-info.c
> index ef965d3d07..b1df3b2915 100644
> --- a/bsps/shared/irq/irq-info.c
> +++ b/bsps/shared/irq/irq-info.c
> @@ -1,22 +1,37 @@
>   * @file
> - * @brief Generic BSP interrupt information implementation.
> + * @brief This source file contains the implementation of
> + *   bsp_interrupt_report() and bsp_interrupt_report_with_plugin().
> - * Copyright (c) 2008, 2009, 2010
> - * Germany
> + * Copyright (C) 2008, 2010 embedded brains GmbH (http://www.embedded-brains.de)
> + * are met:
> diff --git a/bsps/shared/irq/irq-legacy.c b/bsps/shared/irq/irq-legacy.c
> index 64c324b472..649b850095 100644
> --- a/bsps/shared/irq/irq-legacy.c
> +++ b/bsps/shared/irq/irq-legacy.c
> @@ -1,22 +1,37 @@
>   * @file
> - * @brief Generic BSP interrupt support legacy implementation.
> + * @brief This source file contains the legacy interrupt controller support
> + *   implementation.
> - * Germany
> + * are met:
>  #include <string.h>
> diff --git a/bsps/shared/irq/irq-lock.c b/bsps/shared/irq/irq-lock.c
> index 1398aff3eb..58b7020a3b 100644
> --- a/bsps/shared/irq/irq-lock.c
> +++ b/bsps/shared/irq/irq-lock.c
> @@ -1,25 +1,37 @@
>   * @file
> - * @brief BSP interrupt support lock implementation.
> + *   bsp_interrupt_lock() and bsp_interrupt_unlock().
> - *  Dornierstr. 4
> - *  82178 Puchheim
> - *  Germany
> + * are met:
> diff --git a/bsps/shared/irq/irq-server.c b/bsps/shared/irq/irq-server.c
> index 2c8df4952c..fa2153fcb0 100644
> --- a/bsps/shared/irq/irq-server.c
> +++ b/bsps/shared/irq/irq-server.c
> @@ -1,17 +1,36 @@
>   * @file
> - * @brief Generic BSP interrupt server implementation.
> + * @brief This source file contains the interrupt server implementation.
>   * Copyright (C) 2009, 2020 embedded brains GmbH (http://www.embedded-brains.de)
> + * are met:
>  #include <stdlib.h>
> diff --git a/bsps/shared/irq/irq-shell.c b/bsps/shared/irq/irq-shell.c
> index ca936f8038..cf70f2ce1b 100644
> --- a/bsps/shared/irq/irq-shell.c
> +++ b/bsps/shared/irq/irq-shell.c
> @@ -1,22 +1,37 @@
>   * @file
> - * @brief Generic BSP interrupt shell implementation.
> + * @brief This source file contains the definition of
> + *   ::bsp_interrupt_shell_command.
> - * Copyright (c) 2009
> - * Germany
> + * Copyright (C) 2009 embedded brains GmbH (http://www.embedded-brains.de)
> + * are met:
>  #include <stdio.h>
> 2.26.2
> devel mailing list
> devel at rtems.org
