[PATCH] bsps/irq: Change license to BSD-2-Clause
Thu Jun 17 14:14:22 UTC 2021
Change license to BSD-2-Clause according to file history and
re-licensing agreement.
Update #3053.
 bsps/include/bsp/irq-default.h        |  6 ++--
 bsps/include/bsp/irq-generic.h        | 42 ++++++++++++++++++---------
 bsps/include/bsp/irq-info.h           | 35 +++++++++++++++-------
 bsps/shared/irq/irq-default-handler.c | 40 +++++++++++++++++++------
 bsps/shared/irq/irq-default.c         | 12 +++++---
 bsps/shared/irq/irq-generic.c         | 36 +++++++++++++++--------
 bsps/shared/irq/irq-info.c            | 35 +++++++++++++++-------
 bsps/shared/irq/irq-legacy.c          | 35 +++++++++++++++-------
 bsps/shared/irq/irq-lock.c            | 36 +++++++++++++++--------
 bsps/shared/irq/irq-server.c          | 27 ++++++++++++++---
 bsps/shared/irq/irq-shell.c           | 35 +++++++++++++++-------
 11 files changed, 242 insertions(+), 97 deletions(-)
diff --git a/bsps/include/bsp/irq-default.h b/bsps/include/bsp/irq-default.h
index a94e045e0d..4d7beb189b 100644
--- a/bsps/include/bsp/irq-default.h
+++ b/bsps/include/bsp/irq-default.h
@@ -1,3 +1,5 @@
  * @file
@@ -5,9 +7,7 @@
- * SPDX-License-Identifier: BSD-2-Clause
- * Copyright (C) 2019 embedded brains GmbH
+ * Copyright (C) 2019 embedded brains GmbH (http://www.embedded-brains.de)
  * modification, are permitted provided that the following conditions
diff --git a/bsps/include/bsp/irq-generic.h b/bsps/include/bsp/irq-generic.h
index 31835d07ba..4135aa518c 100644
--- a/bsps/include/bsp/irq-generic.h
+++ b/bsps/include/bsp/irq-generic.h
@@ -1,27 +1,43 @@
  * @file
  * @ingroup bsp_interrupt
- * @brief Generic BSP interrupt support API.
+ * @brief This header file provides interfaces of the generic interrupt
+ *   controller support.
- * Based on concepts of Pavel Pisa, Till Straumann and Eric Valette.
- * Copyright (c) 2008, 2017 embedded brains GmbH.
+ * Copyright (C) 2016 Chris Johns <chrisj at rtems.org>
- *  embedded brains GmbH
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
+ * Copyright (C) 2008, 2017 embedded brains GmbH (http://www.embedded-brains.de)
- * Copyright (c) 2016 Chris Johns <chrisj at rtems.org>
+ * are met:
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * The API is based on concepts of Pavel Pisa, Till Straumann and Eric Valette.
 #ifndef LIBBSP_SHARED_IRQ_GENERIC_H
diff --git a/bsps/include/bsp/irq-info.h b/bsps/include/bsp/irq-info.h
index ea6d629e76..25f05a9f69 100644
--- a/bsps/include/bsp/irq-info.h
+++ b/bsps/include/bsp/irq-info.h
@@ -1,22 +1,37 @@
  * @file
- * @brief Generic BSP interrupt information API.
+ *   controller support for the RTEMS Shell.
- * Copyright (c) 2008, 2009
- * Obere Lagerstr. 30
- * D-82178 Puchheim
- * Germany
+ * Copyright (C) 2008, 2009 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
 #ifndef LIBBSP_SHARED_IRQ_INFO_H
diff --git a/bsps/shared/irq/irq-default-handler.c b/bsps/shared/irq/irq-default-handler.c
index 4f4b4be673..cfe91f4202 100644
--- a/bsps/shared/irq/irq-default-handler.c
+++ b/bsps/shared/irq/irq-default-handler.c
@@ -1,15 +1,37 @@
+ * @file
+ * @ingroup bsp_interrupt
+ * @brief This source file contains the default implementation of
+ *   bsp_interrupt_handler_default().
- * Copyright (c) 2008-2012 embedded brains GmbH.  All rights reserved.
+ * Copyright (C) 2008, 2012 embedded brains GmbH (http://www.embedded-brains.de)
- *  82178 Puchheim
- *  Germany
+ * are met:
 #include <inttypes.h>
diff --git a/bsps/shared/irq/irq-default.c b/bsps/shared/irq/irq-default.c
index 9295f1fb44..943b4ea191 100644
--- a/bsps/shared/irq/irq-default.c
+++ b/bsps/shared/irq/irq-default.c
@@ -1,13 +1,17 @@
  * @file
- * @ingroup RTEMSBSPsShared
+ *   bsp_interrupt_vector_enable(), bsp_interrupt_vector_disable(), and
+ *   bsp_interrupt_facility_initialize().
diff --git a/bsps/shared/irq/irq-generic.c b/bsps/shared/irq/irq-generic.c
index fd129333ba..1e83a6f249 100644
--- a/bsps/shared/irq/irq-generic.c
+++ b/bsps/shared/irq/irq-generic.c
@@ -1,25 +1,37 @@
  * @file
- * @brief Generic BSP interrupt support implementation.
+ * @brief This source file contains the generic interrupt controller support
+ *   implementation.
- * Copyright (c) 2008, 2018 embedded brains GmbH.
+ * Copyright (C) 2008, 2018 embedded brains GmbH (http://www.embedded-brains.de)
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
+ * are met:
 #include <bsp/irq-generic.h>
diff --git a/bsps/shared/irq/irq-info.c b/bsps/shared/irq/irq-info.c
index ef965d3d07..b1df3b2915 100644
--- a/bsps/shared/irq/irq-info.c
+++ b/bsps/shared/irq/irq-info.c
@@ -1,22 +1,37 @@
  * @file
- * @brief Generic BSP interrupt information implementation.
+ * @brief This source file contains the implementation of
+ *   bsp_interrupt_report() and bsp_interrupt_report_with_plugin().
- * Copyright (c) 2008, 2009, 2010
- * Germany
+ * Copyright (C) 2008, 2010 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
diff --git a/bsps/shared/irq/irq-legacy.c b/bsps/shared/irq/irq-legacy.c
index 64c324b472..649b850095 100644
--- a/bsps/shared/irq/irq-legacy.c
+++ b/bsps/shared/irq/irq-legacy.c
@@ -1,22 +1,37 @@
  * @file
- * @brief Generic BSP interrupt support legacy implementation.
+ * @brief This source file contains the legacy interrupt controller support
+ *   implementation.
- * Germany
+ * are met:
diff --git a/bsps/shared/irq/irq-lock.c b/bsps/shared/irq/irq-lock.c
index 1398aff3eb..58b7020a3b 100644
--- a/bsps/shared/irq/irq-lock.c
+++ b/bsps/shared/irq/irq-lock.c
@@ -1,25 +1,37 @@
  * @file
- * @brief BSP interrupt support lock implementation.
+ *   bsp_interrupt_lock() and bsp_interrupt_unlock().
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
+ * are met:
diff --git a/bsps/shared/irq/irq-server.c b/bsps/shared/irq/irq-server.c
index 2c8df4952c..fa2153fcb0 100644
--- a/bsps/shared/irq/irq-server.c
+++ b/bsps/shared/irq/irq-server.c
@@ -1,17 +1,36 @@
  * @file
- * @brief Generic BSP interrupt server implementation.
+ * @brief This source file contains the interrupt server implementation.
  * Copyright (C) 2009, 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
diff --git a/bsps/shared/irq/irq-shell.c b/bsps/shared/irq/irq-shell.c
index ca936f8038..cf70f2ce1b 100644
--- a/bsps/shared/irq/irq-shell.c
+++ b/bsps/shared/irq/irq-shell.c
@@ -1,22 +1,37 @@
  * @file
- * @brief Generic BSP interrupt shell implementation.
+ * @brief This source file contains the definition of
+ *   ::bsp_interrupt_shell_command.
- * Copyright (c) 2009
- * Germany
+ * Copyright (C) 2009 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
