Minimum RAM for "libbsd"? Can't run in 8MB on "imxrt".
dufault at hda.com dufault at hda.com
Mon Jun 21 13:31:17 UTC 2021
> On Jun 21, 2021, at 08:52 , Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> What happens when you reduce the memory space for the mbufs to 4MiB? What is the "RTEMS work space"?
By "RTEMS work space" I mean the space between bsp_section_work_begin and bsp_section_work_end, which I assume is handed over to the unified work space.  I also assume allocated "libbsd" data structures come from there.
After reducing the space for the mbufs I still run out of RAM.  I've been patching rtems_bsd_allocator_domain_page_mbuf_size in the debugger for test.  I'll put it in at compile time but looking at the code that won't make a difference.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
Type: application/pgp-signature
Desc: Message signed with OpenPGP
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210621/4e6d25de/attachment.bin>
