Minimum RAM for "libbsd"? Can't run in 8MB on "imxrt".
Sebastian Huber
Wed Jun 23 05:17:25 UTC 2021
On 21/06/2021 15:31, dufault at hda.com wrote:
>> On Jun 21, 2021, at 08:52 , Sebastian Huber<sebastian.huber at embedded-brains.de> wrote:
>> What happens when you reduce the memory space for the mbufs to 4MiB? What is the "RTEMS work space"?
> By "RTEMS work space" I mean the space between bsp_section_work_begin and bsp_section_work_end, which I assume is handed over to the unified work space. I also assume allocated "libbsd" data structures come from there.
Yes, the space between bsp_section_work_begin and bsp_section_work_end
is used for the heap which is used by libbsd.
> After reducing the space for the mbufs I still run out of RAM. I've been patching rtems_bsd_allocator_domain_page_mbuf_size in the debugger for test. I'll put it in at compile time but looking at the code that won't make a difference.
Which memory allocation fails? Is it in the libbsd initialization or
afterwards?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
