[PATCH rtems] i2c: Add non blocking read / write
Christian MAUDERER christian.mauderer at embedded-brains.de
Mon Jun 21 14:07:53 UTC 2021
Ping.
Am 26.05.21 um 16:39 schrieb Christian Mauderer:
> This adds the possibility to open an I2C bus with O_NONBLOCK (or set it
> later via fcntl) to get non-blocking transmissions. This means that if
> the bus is busy, a read, write or transfer ioctl will return with a
> EAGAIN errno.
> NOTE: This patch needs
> https://lists.rtems.org/pipermail/devel/2021-May/067462.html applied too.
>   cpukit/dev/i2c/i2c-bus.c         |  45 ++++++++++--
>   cpukit/include/dev/i2c/i2c.h     |  44 ++++++++++-
>   testsuites/libtests/i2c01/init.c | 121 ++++++++++++++++++++++++++++++-
>   3 files changed, 203 insertions(+), 7 deletions(-)
> diff --git a/cpukit/dev/i2c/i2c-bus.c b/cpukit/dev/i2c/i2c-bus.c
> index 472222c4ab..618a817b1a 100644
> --- a/cpukit/dev/i2c/i2c-bus.c
> +++ b/cpukit/dev/i2c/i2c-bus.c
> @@ -31,6 +31,11 @@
>   #include <stdlib.h>
>   #include <string.h>
> +int i2c_bus_try_obtain(i2c_bus *bus)
> +  return rtems_recursive_mutex_try_lock(&bus->mutex);
>   void i2c_bus_obtain(i2c_bus *bus)
>     rtems_recursive_mutex_lock(&bus->mutex);
> @@ -41,7 +46,12 @@ void i2c_bus_release(i2c_bus *bus)
>     rtems_recursive_mutex_unlock(&bus->mutex);
> -int i2c_bus_transfer(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count)
> +int i2c_bus_do_transfer(
> +  i2c_bus *bus,
> +  i2c_msg *msgs,
> +  uint32_t msg_count,
> +  uint32_t flags
>     int err;
>     uint32_t i;
> @@ -63,13 +73,24 @@ int i2c_bus_transfer(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count)
> -  i2c_bus_obtain(bus);
> +  if ((flags & I2C_BUS_NOBLOCK) != 0) {
> +    if (i2c_bus_try_obtain(bus) != 0) {
> +      return -EAGAIN;
> +  } else {
> +    i2c_bus_obtain(bus);
>     err = (*bus->transfer)(bus, msgs, msg_count);
>     i2c_bus_release(bus);
>     return err;
> +int i2c_bus_transfer(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count)
> +  return i2c_bus_do_transfer(bus, msgs, msg_count, 0);
>   static ssize_t i2c_bus_read(
>     rtems_libio_t *iop,
>     void *buffer,
> @@ -84,12 +105,17 @@ static ssize_t i2c_bus_read(
>       .buf = buffer
>     int err;
> +  unsigned flags = 0;
>     if (bus->ten_bit_address) {
>       msg.flags |= I2C_M_TEN;
> -  err = i2c_bus_transfer(bus, &msg, 1);
> +  if (rtems_libio_iop_is_no_delay(iop)) {
> +    flags |= I2C_BUS_NOBLOCK;
> +  err = i2c_bus_do_transfer(bus, &msg, 1, flags);
>     if (err == 0) {
>       return msg.len;
>     } else {
> @@ -111,12 +137,17 @@ static ssize_t i2c_bus_write(
>       .buf = RTEMS_DECONST(void *, buffer)
>     int err;
>     if (err == 0) {
>       return msg.len;
>     } else {
> @@ -133,12 +164,16 @@ static int i2c_bus_ioctl(
>     i2c_bus *bus = IMFS_generic_get_context_by_iop(iop);
>     i2c_rdwr_ioctl_data *rdwr;
>     int err;
>     switch (command) {
>       case I2C_RDWR:
>         rdwr = arg;
>         if (rdwr->nmsgs > 0) {
> -        err = i2c_bus_transfer(bus, rdwr->msgs, rdwr->nmsgs);
> +        err = i2c_bus_do_transfer(bus, rdwr->msgs, rdwr->nmsgs, flags);
>         } else {
>           err = 0;
> diff --git a/cpukit/include/dev/i2c/i2c.h b/cpukit/include/dev/i2c/i2c.h
> index ac2c369785..5aa45e390c 100644
> --- a/cpukit/include/dev/i2c/i2c.h
> +++ b/cpukit/include/dev/i2c/i2c.h
> @@ -242,6 +242,16 @@ int i2c_bus_register(
>     const char *bus_path
> + * @brief Try to obtain the bus.
> + * @param[in] bus The bus control.
> + * @retval 0 Successful operation.
> + * @retval EBUSY if mutex is already locked.
> +int i2c_bus_try_obtain(i2c_bus *bus);
>    * @brief Obtains the bus.
> @@ -259,7 +269,8 @@ void i2c_bus_release(i2c_bus *bus);
>    * @brief Transfers I2C messages.
> - * The bus is obtained before the transfer and released afterwards.
> + * The bus is obtained before the transfer and released afterwards. This is the
> + * same like calling @ref i2c_bus_do_transfer with flags set to 0.
>    * @param[in] msgs The messages to transfer.
> @@ -271,6 +282,37 @@ void i2c_bus_release(i2c_bus *bus);
>   int i2c_bus_transfer(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count);
> + * @brief Transfers I2C messages with optional flags.
> + * The bus is obtained before the transfer and released afterwards. If the flag
> + * I2C_BUS_NOBLOCK is set and the bus is already obtained, nothing will be
> + * transfered and the function returns with an -EAGAIN.
> + * @param[in] msgs The messages to transfer.
> + * @param[in] msg_count The count of messages to transfer.  It must be
> + * positive.
> + * @param[in] flags Options for the whole transfer.
> + * @retval -EAGAIN if @ref I2C_BUS_NOBLOCK is set and the bus is already
> + * obtained.
> + * @retval negative Negative error number in case of an error.
> +  i2c_bus *bus,
> +  i2c_msg *msgs,
> +  uint32_t flags
> + * @brief I2C bus transfer flag to indicate that the task should not block if
> + * the bus is busy on a new transfer.
> +#define I2C_BUS_NOBLOCK (1u << 0)
> diff --git a/testsuites/libtests/i2c01/init.c b/testsuites/libtests/i2c01/init.c
> index 83027ed548..c71b78c275 100644
> --- a/testsuites/libtests/i2c01/init.c
> +++ b/testsuites/libtests/i2c01/init.c
> @@ -336,6 +336,124 @@ static void test_simple_read_write(test_bus *bus, int fd)
>     rtems_test_assert(memcmp(&buf[0], &abc[0], sizeof(buf)) == 0);
> +typedef struct {
> +  rtems_id caller;
> +  int fd;
> +} bus_obtainer_ctx;
> +static void bus_obtainer_task(rtems_task_argument arg)
> +  rtems_event_set e = 0;
> +  bus_obtainer_ctx *c = (bus_obtainer_ctx *) arg;
> +  int rv;
> +  rtems_status_code sc;
> +  rv = ioctl(c->fd, I2C_BUS_OBTAIN);
> +  rtems_test_assert(rv == 0);
> +  sc = rtems_event_send(c->caller, RTEMS_EVENT_1);
> +  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> +  sc = rtems_event_receive(
> +    RTEMS_EVENT_1,
> +    RTEMS_EVENT_ANY | RTEMS_WAIT,
> +    100,
> +    &e
> +  rv = ioctl(c->fd, I2C_BUS_RELEASE);
> +static void test_nonblock_read_write(test_bus *bus, int fd)
> +  int flags;
> +  int rv;
> +  char buf[3];
> +  ssize_t n;
> +  i2c_msg msgs[] = {{
> +    .addr = 1,
> +    .flags = I2C_M_STOP,
> +    .len = sizeof(buf),
> +    .buf = (uint8_t *) buf,
> +  struct i2c_rdwr_ioctl_data payload = {
> +    .msgs = msgs,
> +    .nmsgs = sizeof(msgs)/sizeof(msgs[0]),
> +  rtems_id id;
> +  bus_obtainer_ctx ctx = {
> +    .caller = rtems_task_self(),
> +    .fd = fd,
> +  flags = fcntl(fd, F_GETFL, 0);
> +  rtems_test_assert(flags > 0);
> +  rv = fcntl(fd, F_SETFL, flags | O_NONBLOCK);
> +  rtems_test_assert(rv != -1);
> +  sc = rtems_task_create(
> +    rtems_build_name('O', 'B', 'T', 'A'),
> +    2,
> +    RTEMS_MINIMUM_STACK_SIZE,
> +    RTEMS_DEFAULT_MODES,
> +    RTEMS_DEFAULT_ATTRIBUTES,
> +    &id
> +  sc = rtems_task_start(
> +    id,
> +    bus_obtainer_task,
> +    (rtems_task_argument) &ctx
> +    RTEMS_EVENT_1,
> +    100,
> +    &e
> +  errno = 0;
> +  n = read(fd, &buf[0], sizeof(buf));
> +  rtems_test_assert(n == -1);
> +  rtems_test_assert(errno == EAGAIN);
> +  errno = 0;
> +  n = write(fd, &buf[0], sizeof(buf));
> +  errno = 0;
> +  rv = ioctl(fd, I2C_RDWR, &payload);
> +  rtems_test_assert(rv == -1);
> +  sc = rtems_event_send(id, RTEMS_EVENT_1);
> +    RTEMS_EVENT_1,
> +    100,
> +    &e
> +  sc = rtems_task_delete(id);
> +  rv = fcntl(fd, F_SETFL, flags);
>   static void test_gpio_nxp_pca9535(void)
>     int rv;
> @@ -627,6 +745,7 @@ static void test(void)
>     rtems_test_assert(bus->base.timeout == 0);
>     test_simple_read_write(bus, fd);
> +  test_nonblock_read_write(bus, fd);
>     test_eeprom(bus);
>     test_gpio_nxp_pca9535();
>     test_switch_nxp_pca9548a();
> @@ -657,7 +776,7 @@ static void Init(rtems_task_argument arg)
>   #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 7
> -#define CONFIGURE_MAXIMUM_TASKS 1
> +#define CONFIGURE_MAXIMUM_TASKS 2
>   #define CONFIGURE_MAXIMUM_SEMAPHORES 1
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
