[PATCH rtems] i2c: Add non blocking read / write
Christian MAUDERER
christian.mauderer at embedded-brains.de
Tue Jun 22 11:52:37 UTC 2021
Thanks.
Am 21.06.21 um 20:02 schrieb Gedare Bloom:
> it looks ok
> On Mon, Jun 21, 2021 at 8:08 AM Christian MAUDERER
> <christian.mauderer at embedded-brains.de> wrote:
>> Ping.
>> Am 26.05.21 um 16:39 schrieb Christian Mauderer:
>>> This adds the possibility to open an I2C bus with O_NONBLOCK (or set it
>>> later via fcntl) to get non-blocking transmissions. This means that if
>>> the bus is busy, a read, write or transfer ioctl will return with a
>>> EAGAIN errno.
>>> NOTE: This patch needs
>>> https://lists.rtems.org/pipermail/devel/2021-May/067462.html applied too.
>>> cpukit/dev/i2c/i2c-bus.c | 45 ++++++++++--
>>> cpukit/include/dev/i2c/i2c.h | 44 ++++++++++-
>>> testsuites/libtests/i2c01/init.c | 121 ++++++++++++++++++++++++++++++-
>>> 3 files changed, 203 insertions(+), 7 deletions(-)
>>> diff --git a/cpukit/dev/i2c/i2c-bus.c b/cpukit/dev/i2c/i2c-bus.c
>>> index 472222c4ab..618a817b1a 100644
>>> --- a/cpukit/dev/i2c/i2c-bus.c
>>> +++ b/cpukit/dev/i2c/i2c-bus.c
>>> @@ -31,6 +31,11 @@
>>> #include <stdlib.h>
>>> #include <string.h>
>>> +int i2c_bus_try_obtain(i2c_bus *bus)
>>> + return rtems_recursive_mutex_try_lock(&bus->mutex);
>>> void i2c_bus_obtain(i2c_bus *bus)
>>> rtems_recursive_mutex_lock(&bus->mutex);
>>> @@ -41,7 +46,12 @@ void i2c_bus_release(i2c_bus *bus)
>>> rtems_recursive_mutex_unlock(&bus->mutex);
>>> -int i2c_bus_transfer(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count)
>>> +int i2c_bus_do_transfer(
>>> + i2c_bus *bus,
>>> + i2c_msg *msgs,
>>> + uint32_t msg_count,
>>> + uint32_t flags
>>> int err;
>>> uint32_t i;
>>> @@ -63,13 +73,24 @@ int i2c_bus_transfer(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count)
>>> - i2c_bus_obtain(bus);
>>> + if ((flags & I2C_BUS_NOBLOCK) != 0) {
>>> + if (i2c_bus_try_obtain(bus) != 0) {
>>> + return -EAGAIN;
>>> + } else {
>>> + i2c_bus_obtain(bus);
>>> err = (*bus->transfer)(bus, msgs, msg_count);
>>> i2c_bus_release(bus);
>>> return err;
>>> +int i2c_bus_transfer(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count)
>>> + return i2c_bus_do_transfer(bus, msgs, msg_count, 0);
>>> static ssize_t i2c_bus_read(
>>> rtems_libio_t *iop,
>>> void *buffer,
>>> @@ -84,12 +105,17 @@ static ssize_t i2c_bus_read(
>>> .buf = buffer
>>> int err;
>>> + unsigned flags = 0;
>>> if (bus->ten_bit_address) {
>>> msg.flags |= I2C_M_TEN;
>>> - err = i2c_bus_transfer(bus, &msg, 1);
>>> + if (rtems_libio_iop_is_no_delay(iop)) {
>>> + flags |= I2C_BUS_NOBLOCK;
>>> + err = i2c_bus_do_transfer(bus, &msg, 1, flags);
>>> if (err == 0) {
>>> return msg.len;
>>> } else {
>>> @@ -111,12 +137,17 @@ static ssize_t i2c_bus_write(
>>> .buf = RTEMS_DECONST(void *, buffer)
>>> int err;
>>> if (err == 0) {
>>> return msg.len;
>>> } else {
>>> @@ -133,12 +164,16 @@ static int i2c_bus_ioctl(
>>> i2c_bus *bus = IMFS_generic_get_context_by_iop(iop);
>>> i2c_rdwr_ioctl_data *rdwr;
>>> int err;
>>> switch (command) {
>>> case I2C_RDWR:
>>> rdwr = arg;
>>> if (rdwr->nmsgs > 0) {
>>> - err = i2c_bus_transfer(bus, rdwr->msgs, rdwr->nmsgs);
>>> + err = i2c_bus_do_transfer(bus, rdwr->msgs, rdwr->nmsgs, flags);
>>> } else {
>>> err = 0;
>>> diff --git a/cpukit/include/dev/i2c/i2c.h b/cpukit/include/dev/i2c/i2c.h
>>> index ac2c369785..5aa45e390c 100644
>>> --- a/cpukit/include/dev/i2c/i2c.h
>>> +++ b/cpukit/include/dev/i2c/i2c.h
>>> @@ -242,6 +242,16 @@ int i2c_bus_register(
>>> const char *bus_path
>>> + * @brief Try to obtain the bus.
>>> + * @param[in] bus The bus control.
>>> + * @retval 0 Successful operation.
>>> + * @retval EBUSY if mutex is already locked.
>>> +int i2c_bus_try_obtain(i2c_bus *bus);
>>> * @brief Obtains the bus.
>>> @@ -259,7 +269,8 @@ void i2c_bus_release(i2c_bus *bus);
>>> * @brief Transfers I2C messages.
>>> - * The bus is obtained before the transfer and released afterwards.
>>> + * The bus is obtained before the transfer and released afterwards. This is the
>>> + * same like calling @ref i2c_bus_do_transfer with flags set to 0.
>>> * @param[in] msgs The messages to transfer.
>>> @@ -271,6 +282,37 @@ void i2c_bus_release(i2c_bus *bus);
>>> int i2c_bus_transfer(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count);
>>> + * @brief Transfers I2C messages with optional flags.
>>> + * The bus is obtained before the transfer and released afterwards. If the flag
>>> + * I2C_BUS_NOBLOCK is set and the bus is already obtained, nothing will be
>>> + * transfered and the function returns with an -EAGAIN.
>>> + * @param[in] msgs The messages to transfer.
>>> + * @param[in] msg_count The count of messages to transfer. It must be
>>> + * positive.
>>> + * @param[in] flags Options for the whole transfer.
>>> + * @retval -EAGAIN if @ref I2C_BUS_NOBLOCK is set and the bus is already
>>> + * obtained.
>>> + * @retval negative Negative error number in case of an error.
>>> + i2c_bus *bus,
>>> + i2c_msg *msgs,
>>> + uint32_t flags
>>> + * @brief I2C bus transfer flag to indicate that the task should not block if
>>> + * the bus is busy on a new transfer.
>>> +#define I2C_BUS_NOBLOCK (1u << 0)
>>> diff --git a/testsuites/libtests/i2c01/init.c b/testsuites/libtests/i2c01/init.c
>>> index 83027ed548..c71b78c275 100644
>>> --- a/testsuites/libtests/i2c01/init.c
>>> +++ b/testsuites/libtests/i2c01/init.c
>>> @@ -336,6 +336,124 @@ static void test_simple_read_write(test_bus *bus, int fd)
>>> rtems_test_assert(memcmp(&buf[0], &abc[0], sizeof(buf)) == 0);
>>> +typedef struct {
>>> + rtems_id caller;
>>> + int fd;
>>> +} bus_obtainer_ctx;
>>> +static void bus_obtainer_task(rtems_task_argument arg)
>>> + rtems_event_set e = 0;
>>> + bus_obtainer_ctx *c = (bus_obtainer_ctx *) arg;
>>> + int rv;
>>> + rtems_status_code sc;
>>> + rv = ioctl(c->fd, I2C_BUS_OBTAIN);
>>> + rtems_test_assert(rv == 0);
>>> + sc = rtems_event_send(c->caller, RTEMS_EVENT_1);
>>> + rtems_test_assert(sc == RTEMS_SUCCESSFUL);
>>> + sc = rtems_event_receive(
>>> + RTEMS_EVENT_1,
>>> + RTEMS_EVENT_ANY | RTEMS_WAIT,
>>> + 100,
>>> + &e
>>> + rv = ioctl(c->fd, I2C_BUS_RELEASE);
>>> +static void test_nonblock_read_write(test_bus *bus, int fd)
>>> + int flags;
>>> + int rv;
>>> + char buf[3];
>>> + ssize_t n;
>>> + i2c_msg msgs[] = {{
>>> + .addr = 1,
>>> + .flags = I2C_M_STOP,
>>> + .len = sizeof(buf),
>>> + .buf = (uint8_t *) buf,
>>> + struct i2c_rdwr_ioctl_data payload = {
>>> + .msgs = msgs,
>>> + .nmsgs = sizeof(msgs)/sizeof(msgs[0]),
>>> + rtems_id id;
>>> + bus_obtainer_ctx ctx = {
>>> + .caller = rtems_task_self(),
>>> + .fd = fd,
>>> + flags = fcntl(fd, F_GETFL, 0);
>>> + rtems_test_assert(flags > 0);
>>> + rv = fcntl(fd, F_SETFL, flags | O_NONBLOCK);
>>> + rtems_test_assert(rv != -1);
>>> + sc = rtems_task_create(
>>> + rtems_build_name('O', 'B', 'T', 'A'),
>>> + 2,
>>> + RTEMS_MINIMUM_STACK_SIZE,
>>> + RTEMS_DEFAULT_MODES,
>>> + RTEMS_DEFAULT_ATTRIBUTES,
>>> + &id
>>> + sc = rtems_task_start(
>>> + id,
>>> + bus_obtainer_task,
>>> + (rtems_task_argument) &ctx
>>> + RTEMS_EVENT_1,
>>> + 100,
>>> + &e
>>> + errno = 0;
>>> + n = read(fd, &buf[0], sizeof(buf));
>>> + rtems_test_assert(n == -1);
>>> + rtems_test_assert(errno == EAGAIN);
>>> + errno = 0;
>>> + n = write(fd, &buf[0], sizeof(buf));
>>> + errno = 0;
>>> + rv = ioctl(fd, I2C_RDWR, &payload);
>>> + rtems_test_assert(rv == -1);
>>> + sc = rtems_event_send(id, RTEMS_EVENT_1);
>>> + RTEMS_EVENT_1,
>>> + 100,
>>> + &e
>>> + sc = rtems_task_delete(id);
>>> + rv = fcntl(fd, F_SETFL, flags);
>>> static void test_gpio_nxp_pca9535(void)
>>> int rv;
>>> @@ -627,6 +745,7 @@ static void test(void)
>>> rtems_test_assert(bus->base.timeout == 0);
>>> test_simple_read_write(bus, fd);
>>> + test_nonblock_read_write(bus, fd);
>>> test_eeprom(bus);
>>> test_gpio_nxp_pca9535();
>>> test_switch_nxp_pca9548a();
>>> @@ -657,7 +776,7 @@ static void Init(rtems_task_argument arg)
>>> #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 7
>>> -#define CONFIGURE_MAXIMUM_TASKS 1
>>> +#define CONFIGURE_MAXIMUM_TASKS 2
>>> #define CONFIGURE_MAXIMUM_SEMAPHORES 1
>> embedded brains GmbH
>> Herr Christian MAUDERER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: christian.mauderer at embedded-brains.de
>> phone: +49-89-18 94 741 - 18
>> fax: +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
>> devel mailing list
>> devel at rtems.org
Dornierstr. 4
82178 Puchheim
Germany
