BBB hello does not run...
Chris Johns
chrisj at rtems.org
Wed Jun 23 05:24:36 UTC 2021
I have bisect'ed the failure and this is the commit that is the problem:
https://git.rtems.org/rtems/commit/?id=56074644a733ecc984722da2a1b61736275270c0
Hmmmmm.... Is there a new requirement on the needed FDT for a beagleboneblack.
On 23/6/21 2:52 pm, Chris Johns wrote:
> Hi,
> hello.exe is not running. Any hints?
> master at ...
> https://git.rtems.org/rtems/commit/?id=b47dbbc5f7c8518634c7c5fccd57d78c65444f2d
> config.ini:
> [DEFAULT]
> BUILD_TESTS = False
> RTEMS_DEBUG = True
> RTEMS_POSIX_API = True
> [arm/beagleboneblack]
> BUILD_TESTS = True
> output:
> RTEMS Beagleboard: am335x-based
> ARM Debug: 0x4b141000
> *** FATAL ***
> fatal source: 1 (INTERNAL_ERROR_RTEMS_API)
> fatal code: 22 (0x00000016)
> RTEMS version: 6.0.0.4977dc74c60e75b90fe8dd72e4dedafd55d70c73
> RTEMS tools: 10.3.1 20210409 (RTEMS 6, RSB
> 4e6dc6431435821a534da6307e72ecbd7e42b82a, Newlib 0c0f3df)
> executing thread ID: 0x089010001
> executing thread name: IDLE
> Chris
> devel mailing list
> devel at rtems.org
