BBB hello does not run...
Christian Mauderer oss at c-mauderer.de
Wed Jun 23 07:10:09 UTC 2021
Hello Chris,
there is no new requirement that I know of. The driver should parse the
same FDT fields that have been parsed by libbsd earlier. It only want's
to avoid the double initialization that had been done by RTEMS and libbsd.
But there is a simple method how we can find out whether it's FDT
related: Please try the dtb that I normally use:
     https://nc.c-mauderer.de/index.php/s/JntMtLrE2GpH2Xf
That FDT is build from the FreeBSD sources from that revision:
https://github.com/freebsd/freebsd-src/tree/19a6ceb89dbacf74697d493e48c388767126d418
Note: I don't think that using that FDT is a solution. It's just to find
out whether it's the problem. A solution would be to find a method how
we can distribute matching FDTs with various licenses.
Best regards
Christian
On 23/06/2021 07:24, Chris Johns wrote:
> I have bisect'ed the failure and this is the commit that is the problem:
> https://git.rtems.org/rtems/commit/?id=56074644a733ecc984722da2a1b61736275270c0
> Hmmmmm.... Is there a new requirement on the needed FDT for a beagleboneblack.
> Chris
> On 23/6/21 2:52 pm, Chris Johns wrote:
>> Hi,
>> hello.exe is not running. Any hints?
>> master at ...
>> https://git.rtems.org/rtems/commit/?id=b47dbbc5f7c8518634c7c5fccd57d78c65444f2d
>> config.ini:
>> [DEFAULT]
>> BUILD_TESTS = False
>> RTEMS_DEBUG = True
>> RTEMS_POSIX_API = True
>> [arm/beagleboneblack]
>> BUILD_TESTS = True
>> output:
>> RTEMS Beagleboard: am335x-based
>>          ARM Debug: 0x4b141000
>> *** FATAL ***
>> fatal source: 1 (INTERNAL_ERROR_RTEMS_API)
>> fatal code: 22 (0x00000016)
>> RTEMS version: 6.0.0.4977dc74c60e75b90fe8dd72e4dedafd55d70c73
>> RTEMS tools: 10.3.1 20210409 (RTEMS 6, RSB
>> 4e6dc6431435821a534da6307e72ecbd7e42b82a, Newlib 0c0f3df)
>> executing thread ID: 0x089010001
>> executing thread name: IDLE
>> Chris
>> devel mailing list
>> devel at rtems.org
