[PATCH 10/10] sparc: Simplify trap table initialization
Sebastian Huber
Wed Jun 23 06:49:36 UTC 2021
Move _ISR_Handler() to a separate file since it is now only used if a handler
is installed by _CPU_ISR_install_raw_handler().
Statically initialize the traps for external interrupts to use the new
_SPARC_Interrupt_trap() which directly dispatches the interrupt handlers
installed by rtems_interrupt_handler_install() via the BSP-provided
_SPARC_Interrupt_dispatch().
Since the trap table is now fully statically initialized, there is no longer a
dependency on the Cache Manager in the default configuration.
Update #4458.
bsps/sparc/erc32/include/bsp.h | 6 -
bsps/sparc/erc32/start/bspstart.c | 15 +-
bsps/sparc/leon2/include/bsp.h | 6 -
bsps/sparc/leon2/start/bspstart.c | 2 +-
bsps/sparc/leon3/include/bsp.h | 6 -
bsps/sparc/leon3/start/bspsmp.c | 24 +-
bsps/sparc/leon3/start/bspstart.c | 34 +-
bsps/sparc/shared/irq/bsp_isr_handler.c | 27 +-
bsps/sparc/shared/irq/irq-shared.c | 21 -
bsps/sparc/shared/start/start.S | 39 +-
cpukit/Makefile.am | 1 +
cpukit/score/cpu/sparc/cpu_asm.S | 64 +-
.../score/cpu/sparc/include/rtems/score/cpu.h | 8 +-
cpukit/score/cpu/sparc/sparc-isr-handler.S | 620 ++++++++++++++++++
spec/build/cpukit/cpusparc.yml | 1 +
15 files changed, 704 insertions(+), 170 deletions(-)
create mode 100644 cpukit/score/cpu/sparc/sparc-isr-handler.S
diff --git a/bsps/sparc/erc32/include/bsp.h b/bsps/sparc/erc32/include/bsp.h
index 7fb2fa9d72..fd453fb6c2 100644
--- a/bsps/sparc/erc32/include/bsp.h
+++ b/bsps/sparc/erc32/include/bsp.h
@@ -95,12 +95,6 @@ void BSP_fatal_exit(uint32_t error);
/* Interrupt Service Routine (ISR) pointer */
typedef void (*bsp_shared_isr)(void *arg);
-/* Initializes the Shared System Interrupt service */
-extern void BSP_shared_interrupt_init(void);
-/* Called directly from IRQ trap handler TRAP[0x10..0x1F] = IRQ[0..15] */
-void bsp_isr_handler(rtems_vector_number vector);
/* Registers a shared IRQ handler, and enable it at IRQ controller. Multiple
* interrupt handlers may use the same IRQ number, all ISRs will be called
* when an interrupt on that line is fired.
diff --git a/bsps/sparc/erc32/start/bspstart.c b/bsps/sparc/erc32/start/bspstart.c
index d56d3b2ff2..1979c68308 100644
--- a/bsps/sparc/erc32/start/bspstart.c
+++ b/bsps/sparc/erc32/start/bspstart.c
@@ -12,22 +12,15 @@
#include <bsp.h>
#include <bsp/bootcard.h>
+#include <bsp/irq-generic.h>
#include <rtems/sysinit.h>
- * Called just before drivers are initialized. Is used to initialize shared
- * interrupt handling.
+ * Initialize shared interrupt handling, must be done after IRQ controller has
+ * been found and initialized.
-static void erc32_pre_driver_hook( void )
- /* Initialize shared interrupt handling, must be done after IRQ
- * controller has been found and initialized.
- BSP_shared_interrupt_init();
RTEMS_SYSINIT_ITEM(
- erc32_pre_driver_hook,
+ bsp_interrupt_initialize,
RTEMS_SYSINIT_BSP_PRE_DRIVERS,
RTEMS_SYSINIT_ORDER_MIDDLE
diff --git a/bsps/sparc/leon2/include/bsp.h b/bsps/sparc/leon2/include/bsp.h
index bdd9c1ca70..510262206b 100644
--- a/bsps/sparc/leon2/include/bsp.h
+++ b/bsps/sparc/leon2/include/bsp.h
@@ -119,12 +119,6 @@ void BSP_fatal_exit(uint32_t error);
diff --git a/bsps/sparc/leon2/start/bspstart.c b/bsps/sparc/leon2/start/bspstart.c
index 8ffd0aa2e7..e90cfad5a8 100644
--- a/bsps/sparc/leon2/start/bspstart.c
+++ b/bsps/sparc/leon2/start/bspstart.c
@@ -111,7 +111,7 @@ static void leon2_pre_driver_hook( void )
+ bsp_interrupt_initialize();
#ifdef RTEMS_DRVMGR_STARTUP
leon2_root_register(&leon2_bus_config, &leon2_amba_res);
diff --git a/bsps/sparc/leon3/include/bsp.h b/bsps/sparc/leon3/include/bsp.h
index 82f1f9f8ac..cb08764eae 100644
--- a/bsps/sparc/leon3/include/bsp.h
+++ b/bsps/sparc/leon3/include/bsp.h
@@ -139,12 +139,6 @@ void rtems_bsp_delay(int usecs);
diff --git a/bsps/sparc/leon3/start/bspsmp.c b/bsps/sparc/leon3/start/bspsmp.c
index c73c3fd5d0..f2749bfa06 100644
--- a/bsps/sparc/leon3/start/bspsmp.c
+++ b/bsps/sparc/leon3/start/bspsmp.c
@@ -18,6 +18,7 @@
#include <bsp/fatal.h>
#include <leon.h>
#include <rtems/bspIo.h>
+#include <rtems/sysinit.h>
#include <rtems/score/smpimpl.h>
@@ -55,13 +56,10 @@ void bsp_start_on_secondary_processor(Per_CPU_Control *cpu_self)
_SMP_Start_multitasking_on_secondary_processor(cpu_self);
-uint32_t _CPU_SMP_Initialize( void )
+static void leon3_install_inter_processor_interrupt( void )
rtems_status_code sc;
- if ( !leon3_data_cache_snooping_enabled() )
- bsp_fatal( LEON3_FATAL_INVALID_CACHE_CONFIG_MAIN_PROCESSOR );
sc = rtems_interrupt_handler_install(
LEON3_mp_irq,
"IPI",
@@ -70,6 +68,16 @@ uint32_t _CPU_SMP_Initialize( void )
NULL
_Assert_Unused_variable_equals( sc, RTEMS_SUCCESSFUL );
+uint32_t _CPU_SMP_Initialize( void )
+ if ( !leon3_data_cache_snooping_enabled() )
+ bsp_fatal( LEON3_FATAL_INVALID_CACHE_CONFIG_MAIN_PROCESSOR );
+#if !defined(RTEMS_DRVMGR_STARTUP)
+ leon3_install_inter_processor_interrupt();
+#endif
return leon3_get_cpu_count(LEON3_IrqCtrl_Regs);
@@ -102,3 +110,11 @@ void _CPU_SMP_Send_interrupt(uint32_t target_processor_index)
/* send interrupt to destination CPU */
LEON3_IrqCtrl_Regs->force[target_processor_index] = 1 << LEON3_mp_irq;
+#if defined(RTEMS_DRVMGR_STARTUP)
+RTEMS_SYSINIT_ITEM(
+ leon3_install_inter_processor_interrupt,
+ RTEMS_SYSINIT_DRVMGR_LEVEL_1,
+ RTEMS_SYSINIT_ORDER_LAST_BUT_4
+#endif
diff --git a/bsps/sparc/leon3/start/bspstart.c b/bsps/sparc/leon3/start/bspstart.c
index 69ff519189..75042e4c20 100644
--- a/bsps/sparc/leon3/start/bspstart.c
+++ b/bsps/sparc/leon3/start/bspstart.c
@@ -20,6 +20,7 @@
#include <bsp.h>
#include <leon.h>
@@ -66,6 +67,10 @@ static inline int set_snooping(void)
void bsp_start( void )
CPU_SPARC_HAS_SNOOPING = set_snooping();
+#ifndef RTEMS_DRVMGR_STARTUP
+#endif
static void leon3_cpu_index_init(void)
@@ -84,38 +89,13 @@ RTEMS_SYSINIT_ITEM(
RTEMS_SYSINIT_ORDER_FIRST
-static void leon3_interrupt_common_init( void )
-static void leon3_pre_driver_hook( void )
-#ifndef RTEMS_DRVMGR_STARTUP
- leon3_interrupt_common_init();
-#endif
-RTEMS_SYSINIT_ITEM(
- leon3_pre_driver_hook,
- RTEMS_SYSINIT_BSP_PRE_DRIVERS,
- RTEMS_SYSINIT_ORDER_MIDDLE
-#ifdef RTEMS_DRVMGR_STARTUP
+#ifdef RTEMS_DRVMGR_STARTUP
RTEMS_SYSINIT_ITEM(
- leon3_interrupt_common_init,
RTEMS_SYSINIT_ORDER_LAST_BUT_5
diff --git a/bsps/sparc/shared/irq/bsp_isr_handler.c b/bsps/sparc/shared/irq/bsp_isr_handler.c
index a4d33b0932..2616b5caae 100644
--- a/bsps/sparc/shared/irq/bsp_isr_handler.c
+++ b/bsps/sparc/shared/irq/bsp_isr_handler.c
@@ -8,28 +8,19 @@
-#include <rtems.h>
#include <bsp.h>
-static inline void bsp_dispatch_irq(int irq)
- bsp_interrupt_handler_entry *e =
- &bsp_interrupt_handler_table[bsp_interrupt_handler_index(irq)];
- while (e != NULL) {
- (*e->handler)(e->arg);
- e = e->next;
+ * This function is called directly from _SPARC_Interrupt_trap() for
+ * traps 0x10 to 0x1F which correspond to IRQ 0 to 15 respectively.
+void _SPARC_Interrupt_dispatch( uint32_t irq )
- int irq = vector - 0x10;
+ bsp_interrupt_assert( irq < BSP_INTERRUPT_VECTOR_COUNT );
- /* Let BSP fixup and/or handle incomming IRQ */
- irq = bsp_irq_fixup(irq);
+ /* Let BSP fixup and/or handle incoming IRQ */
+ irq = bsp_irq_fixup( irq );
- bsp_dispatch_irq(irq);
+ bsp_interrupt_handler_dispatch_unchecked( irq );
diff --git a/bsps/sparc/shared/irq/irq-shared.c b/bsps/sparc/shared/irq/irq-shared.c
index e0ac7d7f06..a127ab64c2 100644
--- a/bsps/sparc/shared/irq/irq-shared.c
+++ b/bsps/sparc/shared/irq/irq-shared.c
@@ -37,27 +37,6 @@ static inline int bsp_irq_cpu(int irq)
#endif
-/* Initialize interrupts */
-void BSP_shared_interrupt_init(void)
- rtems_vector_number vector;
- rtems_isr_entry previous_isr;
- int i;
- for (i=0; i <= BSP_INTERRUPT_VECTOR_MAX_STD; i++) {
-#if defined(LEON3) && (defined(RTEMS_SMP) || defined(RTEMS_MULTIPROCESSING))
- /* Don't install IRQ handler on IPI interrupt */
- if (i == LEON3_mp_irq)
- continue;
-#endif
- vector = SPARC_ASYNCHRONOUS_TRAP(i) + 0x10;
- rtems_interrupt_catch(bsp_isr_handler, vector, &previous_isr);
- /* Initalize interrupt support */
- bsp_interrupt_initialize();
/* Callback from bsp_interrupt_initialize() */
rtems_status_code bsp_interrupt_facility_initialize(void)
diff --git a/bsps/sparc/shared/start/start.S b/bsps/sparc/shared/start/start.S
index cd43f08f01..45bd145d4a 100644
--- a/bsps/sparc/shared/start/start.S
+++ b/bsps/sparc/shared/start/start.S
@@ -32,6 +32,13 @@
TRAP_SYM(_vector):; \
TRAP(_vector, _SPARC_Bad_trap)
+ * External interrupt trap
+#define ISR_TRAP(_vector) \
+ TRAP_SYM(_vector):; \
+ TRAP(_vector - 0x10, _SPARC_Interrupt_trap)
* System call optimized trap table entry
@@ -128,27 +135,27 @@ TRAP_SYM(0x06):
BAD_TRAP(0x0d) ! 0D undefined
BAD_TRAP(0x0e) ! 0E undefined
BAD_TRAP(0x0f) ! 0F undefined
- BAD_TRAP(0x10) ! 10 undefined
* External interrupt traps
- BAD_TRAP(0x11) ! 11 external interrupt 1
- BAD_TRAP(0x12) ! 12 external interrupt 2
- BAD_TRAP(0x13) ! 13 external interrupt 3
- BAD_TRAP(0x14) ! 14 external interrupt 4
- BAD_TRAP(0x15) ! 15 external interrupt 5
- BAD_TRAP(0x16) ! 16 external interrupt 6
- BAD_TRAP(0x17) ! 17 external interrupt 7
- BAD_TRAP(0x18) ! 18 external interrupt 8
- BAD_TRAP(0x19) ! 19 external interrupt 9
- BAD_TRAP(0x1a) ! 1A external interrupt 10
- BAD_TRAP(0x1b) ! 1B external interrupt 11
- BAD_TRAP(0x1c) ! 1C external interrupt 12
- BAD_TRAP(0x1d) ! 1D external interrupt 13
- BAD_TRAP(0x1e) ! 1E external interrupt 14
- BAD_TRAP(0x1f) ! 1F external interrupt 15
+ ISR_TRAP(0x10) ! 10 undefined
+ ISR_TRAP(0x11) ! 11 external interrupt 1
+ ISR_TRAP(0x12) ! 12 external interrupt 2
+ ISR_TRAP(0x13) ! 13 external interrupt 3
+ ISR_TRAP(0x14) ! 14 external interrupt 4
+ ISR_TRAP(0x15) ! 15 external interrupt 5
+ ISR_TRAP(0x16) ! 16 external interrupt 6
+ ISR_TRAP(0x17) ! 17 external interrupt 7
+ ISR_TRAP(0x18) ! 18 external interrupt 8
+ ISR_TRAP(0x19) ! 19 external interrupt 9
+ ISR_TRAP(0x1a) ! 1A external interrupt 10
+ ISR_TRAP(0x1b) ! 1B external interrupt 11
+ ISR_TRAP(0x1c) ! 1C external interrupt 12
+ ISR_TRAP(0x1d) ! 1D external interrupt 13
+ ISR_TRAP(0x1e) ! 1E external interrupt 14
+ ISR_TRAP(0x1f) ! 1F external interrupt 15
BAD_TRAP(0x20) ! 20 undefined
BAD_TRAP(0x21) ! 21 undefined
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 83c14cd2ab..c83167668d 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1623,6 +1623,7 @@ librtemscpu_a_SOURCES += score/cpu/sparc/sparc-context-validate.S
librtemscpu_a_SOURCES += score/cpu/sparc/sparc-context-volatile-clobber.S
librtemscpu_a_SOURCES += score/cpu/sparc/sparc-counter-asm.S
librtemscpu_a_SOURCES += score/cpu/sparc/sparc-exception-frame-print.c
+librtemscpu_a_SOURCES += score/cpu/sparc/sparc-isr-handler.S
librtemscpu_a_SOURCES += score/cpu/sparc/sparc-isr-install.c
librtemscpu_a_SOURCES += score/cpu/sparc/syscall.S
librtemscpu_a_SOURCES += score/cpu/sparc/window.S
diff --git a/cpukit/score/cpu/sparc/cpu_asm.S b/cpukit/score/cpu/sparc/cpu_asm.S
index 16f5c70206..45d1495af7 100644
--- a/cpukit/score/cpu/sparc/cpu_asm.S
+++ b/cpukit/score/cpu/sparc/cpu_asm.S
@@ -295,7 +295,7 @@ SYM(_CPU_Context_restore):
mov %i0, %o1 ! in the delay slot
- * void _ISR_Handler()
+ * void _SPARC_Interrupt_trap()
* This routine provides the RTEMS interrupt management.
@@ -305,28 +305,14 @@ SYM(_CPU_Context_restore):
* l0 = PSR
* l1 = PC
* l2 = nPC
- * l3 = trap type
+ * l3 = interrupt vector number (this is not the trap type)
- * NOTE: By an executive defined convention, trap type is between 0 and 255 if
- * it is an asynchonous trap and 256 and 511 if it is synchronous.
+ * NOTE: This trap handler is intended to service external interrupts.
.align 4
- PUBLIC(_ISR_Handler)
-SYM(_ISR_Handler):
- * Fix the return address for synchronous traps.
- andcc %l3, SPARC_SYNCHRONOUS_TRAP_BIT_MASK, %g0
- ! Is this a synchronous trap?
- be,a win_ovflow ! No, then skip the adjustment
- nop ! DELAY
- mov %l1, %l6 ! save trapped pc for debug info
- mov %l2, %l1 ! do not return to the instruction
- add %l2, 4, %l2 ! indicated
-win_ovflow:
+ PUBLIC(_SPARC_Interrupt_trap)
+SYM(_SPARC_Interrupt_trap):
* Save the globals this block uses.
@@ -413,7 +399,7 @@ dont_do_the_window:
* includes a regular minimum stack frame which will be used if
* needed by register window overflow and underflow handlers.
- * REGISTERS SAME AS AT _ISR_Handler
+ * REGISTERS SAME AS AT _SPARC_Interrupt_trap()
sub %fp, CPU_INTERRUPT_FRAME_SIZE, %sp
@@ -439,9 +425,6 @@ dont_do_the_window:
rd %y, %g1
st %g1, [%sp + ISF_Y_OFFSET] ! save y
- st %l6, [%sp + ISF_TPC_OFFSET] ! save real trapped pc
- mov %sp, %o1 ! 2nd arg to ISR Handler
* Increment ISR nest level and Thread dispatch disable level.
@@ -520,26 +503,16 @@ dont_switch_stacks:
sub %sp, SPARC_MINIMUM_STACK_FRAME_SIZE, %sp
- * Check if we have an external interrupt (trap 0x11 - 0x1f). If so,
- * set the PIL in the %psr to mask off interrupts with lower priority.
+ * Set the PIL in the %psr to mask off interrupts with lower priority.
* The original %psr in %l0 is not modified since it will be restored
* when the interrupt handler returns.
mov %l0, %g5
- and %l3, 0x0ff, %g4
- subcc %g4, 0x11, %g0
- bl dont_fix_pil
- subcc %g4, 0x1f, %g0
- bg dont_fix_pil
- sll %g4, 8, %g4
+ sll %l3, 8, %g4
and %g4, SPARC_PSR_PIL_MASK, %g4
andn %l0, SPARC_PSR_PIL_MASK, %g5
- ba pil_fixed
or %g4, %g5, %g5
-dont_fix_pil:
- or %g5, SPARC_PSR_PIL_MASK, %g5
-pil_fixed:
#if SPARC_HAS_FPU == 1
@@ -552,23 +525,10 @@ pil_fixed:
wr %g5, SPARC_PSR_ET_MASK, %psr ! **** ENABLE TRAPS ****
- * Vector to user's handler.
- * NOTE: TBR may no longer have vector number in it since
- * we just enabled traps. It is definitely in l3.
+ * Call _SPARC_Interrupt_dispatch( %l3 )
- sethi %hi(SYM(_ISR_Vector_table)), %g4
- or %g4, %lo(SYM(_ISR_Vector_table)), %g4
- and %l3, 0xFF, %g5 ! remove synchronous trap indicator
- sll %g5, 2, %g5 ! g5 = offset into table
- ld [%g4 + %g5], %g4 ! g4 = _ISR_Vector_table[ vector ]
- ! o1 = 2nd arg = address of the ISF
- ! WAS LOADED WHEN ISF WAS SAVED!!!
mov %l3, %o0 ! o0 = 1st arg = vector number
- call %g4
+ call SYM(_SPARC_Interrupt_dispatch)
#if defined(RTEMS_PROFILING)
mov %o5, %l3 ! save interrupt entry instant
#else
@@ -780,8 +740,8 @@ isr_dispatch:
* The CWP in place at this point may be different from
* that which was in effect at the beginning of the ISR if we
* have been context switched between the beginning of this invocation
- * of _ISR_Handler and this point. Thus the CWP and WIM should
- * not be changed back to their values at ISR entry time. Any
+ * of _SPARC_Interrupt_trap() and this point. Thus the CWP and WIM
+ * should not be changed back to their values at ISR entry time. Any
* changes to the PSR must preserve the CWP.
diff --git a/cpukit/score/cpu/sparc/include/rtems/score/cpu.h b/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
index f3f50d4f78..0abc929c54 100644
--- a/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
@@ -743,9 +743,13 @@ extern const CPU_Trap_table_entry _CPU_Trap_slot_template;
#ifndef ASM
- * ISR handler macros
+ * @brief Dispatches the installed interrupt handlers.
+ * @param irq is the interrupt vector number of the external interrupt ranging
+ * from 0 to 15. This is not a trap number.
+void _SPARC_Interrupt_dispatch( uint32_t irq );
* Disable all interrupts for a critical section. The previous
diff --git a/cpukit/score/cpu/sparc/sparc-isr-handler.S b/cpukit/score/cpu/sparc/sparc-isr-handler.S
new file mode 100644
index 0000000000..068fad1e84
--- /dev/null
+++ b/cpukit/score/cpu/sparc/sparc-isr-handler.S
@@ -0,0 +1,620 @@
+ * This file contains the basic algorithms for all assembly code used
+ * in an specific CPU port of RTEMS. These algorithms must be implemented
+ * in assembly language.
+ * COPYRIGHT (c) 1989-2011.
+ * On-Line Applications Research Corporation (OAR).
+ * Copyright (c) 2014, 2017 embedded brains GmbH
+ * Ported to ERC32 implementation of the SPARC by On-Line Applications
+ * Research Corporation (OAR) under contract to the European Space
+ * Agency (ESA).
+ * ERC32 modifications of respective RTEMS file: COPYRIGHT (c) 1995.
+ * European Space Agency.
+#include <rtems/asm.h>
+#include <rtems/score/percpu.h>
+#include <libcpu/grlib-tn-0018.h>
+ * void _ISR_Handler()
+ * This routine provides the RTEMS interrupt management.
+ * We enter this handler from the 4 instructions in the trap table with
+ * the following registers assumed to be set as shown:
+ * l0 = PSR
+ * l1 = PC
+ * l2 = nPC
+ * l3 = trap type
+ * NOTE: By an executive defined convention, trap type is between 0 and 255 if
+ * it is an asynchonous trap and 256 and 511 if it is synchronous.
+ .align 4
+ PUBLIC(_ISR_Handler)
+SYM(_ISR_Handler):
+ * Fix the return address for synchronous traps.
+ andcc %l3, SPARC_SYNCHRONOUS_TRAP_BIT_MASK, %g0
+ ! Is this a synchronous trap?
+ be,a win_ovflow ! No, then skip the adjustment
+ nop ! DELAY
+ mov %l1, %l6 ! save trapped pc for debug info
+ mov %l2, %l1 ! do not return to the instruction
+ add %l2, 4, %l2 ! indicated
+win_ovflow:
+ * Save the globals this block uses.
+ * These registers are not restored from the locals. Their contents
+ * are saved directly from the locals into the ISF below.
+ mov %g4, %l4 ! save the globals this block uses
+ mov %g5, %l5
+ * When at a "window overflow" trap, (wim == (1 << cwp)).
+ * If we get here like that, then process a window overflow.
+ rd %wim, %g4
+ srl %g4, %l0, %g5 ! g5 = win >> cwp ; shift count and CWP
+ ! are LS 5 bits ; how convenient :)
+ cmp %g5, 1 ! Is this an invalid window?
+ bne dont_do_the_window ! No, then skip all this stuff
+ ! we are using the delay slot
+ * The following is same as a 1 position right rotate of WIM
+ srl %g4, 1, %g5 ! g5 = WIM >> 1
+ sll %g4, SPARC_NUMBER_OF_REGISTER_WINDOWS-1 , %g4
+ ! g4 = WIM << (Number Windows - 1)
+ or %g4, %g5, %g4 ! g4 = (WIM >> 1) |
+ ! (WIM << (Number Windows - 1))
+ * At this point:
+ * g4 = the new WIM
+ * g5 is free
+ * Since we are tinkering with the register windows, we need to
+ * make sure that all the required information is in global registers.
+ save ! Save into the window
+ wr %g4, 0, %wim ! WIM = new WIM
+ nop ! delay slots
+ nop
+ nop
+ * Now save the window just as if we overflowed to it.
+ std %l0, [%sp + CPU_STACK_FRAME_L0_OFFSET]
+ SPARC_LEON3FT_B2BST_NOP
+ std %l2, [%sp + CPU_STACK_FRAME_L2_OFFSET]
+ std %l4, [%sp + CPU_STACK_FRAME_L4_OFFSET]
+ std %l6, [%sp + CPU_STACK_FRAME_L6_OFFSET]
+ std %i0, [%sp + CPU_STACK_FRAME_I0_OFFSET]
+ std %i2, [%sp + CPU_STACK_FRAME_I2_OFFSET]
+ std %i4, [%sp + CPU_STACK_FRAME_I4_OFFSET]
+ std %i6, [%sp + CPU_STACK_FRAME_I6_FP_OFFSET]
+ restore
+ nop
+dont_do_the_window:
+ * Global registers %g4 and %g5 are saved directly from %l4 and
+ * %l5 directly into the ISF below.
+ * Save the state of the interrupted task -- especially the global
+ * registers -- in the Interrupt Stack Frame. Note that the ISF
+ * includes a regular minimum stack frame which will be used if
+ * needed by register window overflow and underflow handlers.
+ * REGISTERS SAME AS AT _ISR_Handler
+ sub %fp, CPU_INTERRUPT_FRAME_SIZE, %sp
+ ! make space for ISF
+ std %l0, [%sp + ISF_PSR_OFFSET] ! save psr, PC
+ st %l2, [%sp + ISF_NPC_OFFSET] ! save nPC
+ st %g1, [%sp + ISF_G1_OFFSET] ! save g1
+ std %g2, [%sp + ISF_G2_OFFSET] ! save g2, g3
+ std %l4, [%sp + ISF_G4_OFFSET] ! save g4, g5 -- see above
+ st %g7, [%sp + ISF_G7_OFFSET] ! save g7
+ std %i0, [%sp + ISF_I0_OFFSET] ! save i0, i1
+ std %i2, [%sp + ISF_I2_OFFSET] ! save i2, i3
+ std %i4, [%sp + ISF_I4_OFFSET] ! save i4, i5
+ std %i6, [%sp + ISF_I6_FP_OFFSET] ! save i6/fp, i7
+ rd %y, %g1
+ st %g1, [%sp + ISF_Y_OFFSET] ! save y
+ st %l6, [%sp + ISF_TPC_OFFSET] ! save real trapped pc
+ mov %sp, %o1 ! 2nd arg to ISR Handler
+ * Increment ISR nest level and Thread dispatch disable level.
+ * Register usage for this section:
+ * l6 = _Thread_Dispatch_disable_level value
+ * l7 = _ISR_Nest_level value
+ * NOTE: It is assumed that l6 - l7 will be preserved until the ISR
+ * nest and thread dispatch disable levels are unnested.
+ ld [%g6 + PER_CPU_ISR_NEST_LEVEL], %l7
+ ld [%g6 + PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL], %l6
+ add %l7, 1, %l7
+ st %l7, [%g6 + PER_CPU_ISR_NEST_LEVEL]
+ add %l6, 1, %l6
+ st %l6, [%g6 + PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
+#if SPARC_HAS_FPU == 1
+ * We cannot use an intermediate value for operations with the PSR[EF]
+ * bit since they use a 13-bit sign extension and PSR[EF] is bit 12.
+ sethi %hi(SPARC_PSR_EF_MASK), %l5
+#endif
+ * If ISR nest level was zero (now 1), then switch stack.
+ mov %sp, %fp
+ subcc %l7, 1, %l7 ! outermost interrupt handler?
+ bnz dont_switch_stacks ! No, then do not switch stacks
+#if defined(RTEMS_PROFILING)
+ sethi %hi(_SPARC_Counter), %o5
+ ld [%o5 + %lo(_SPARC_Counter)], %l4
+ call %l4
+ nop
+ mov %o0, %o5
+#else
+ nop
+#endif
+ ld [%g6 + PER_CPU_INTERRUPT_STACK_HIGH], %sp
+ * Test if the interrupted thread uses the floating point unit
+ * (PSR[EF] == 1). In case it uses the floating point unit, then store
+ * the floating point status register. This has the side-effect that
+ * all pending floating point operations complete before the store
+ * completes. The PSR[EF] bit is restored after the call to the
+ * interrupt handler. Thus post-switch actions (e.g. signal handlers)
+ * and context switch extensions may still corrupt the floating point
+ * context.
+ andcc %l0, %l5, %g0
+ beq dont_switch_stacks
+ nop
+ st %fsr, [%g6 + SPARC_PER_CPU_FSR_OFFSET]
+#endif
+dont_switch_stacks:
+ * Make sure we have a place on the stack for the window overflow
+ * trap handler to write into. At this point it is safe to
+ * enable traps again.
+ sub %sp, SPARC_MINIMUM_STACK_FRAME_SIZE, %sp
+ * Check if we have an external interrupt (trap 0x11 - 0x1f). If so,
+ * set the PIL in the %psr to mask off interrupts with lower priority.
+ * The original %psr in %l0 is not modified since it will be restored
+ * when the interrupt handler returns.
+ mov %l0, %g5
+ and %l3, 0x0ff, %g4
+ subcc %g4, 0x11, %g0
+ bl dont_fix_pil
+ subcc %g4, 0x1f, %g0
+ bg dont_fix_pil
+ sll %g4, 8, %g4
+ and %g4, SPARC_PSR_PIL_MASK, %g4
+ andn %l0, SPARC_PSR_PIL_MASK, %g5
+ ba pil_fixed
+ or %g4, %g5, %g5
+dont_fix_pil:
+ or %g5, SPARC_PSR_PIL_MASK, %g5
+pil_fixed:
+ * Clear the PSR[EF] bit of the interrupted context to ensure that
+ * interrupt service routines cannot corrupt the floating point context.
+ andn %g5, %l5, %g5
+#endif
+ wr %g5, SPARC_PSR_ET_MASK, %psr ! **** ENABLE TRAPS ****
+ * Vector to user's handler.
+ * NOTE: TBR may no longer have vector number in it since
+ * we just enabled traps. It is definitely in l3.
+ sethi %hi(SYM(_ISR_Vector_table)), %g4
+ or %g4, %lo(SYM(_ISR_Vector_table)), %g4
+ and %l3, 0xFF, %g5 ! remove synchronous trap indicator
+ sll %g5, 2, %g5 ! g5 = offset into table
+ ld [%g4 + %g5], %g4 ! g4 = _ISR_Vector_table[ vector ]
+ ! o1 = 2nd arg = address of the ISF
+ ! WAS LOADED WHEN ISF WAS SAVED!!!
+ mov %l3, %o0 ! o0 = 1st arg = vector number
+ call %g4
+ mov %o5, %l3 ! save interrupt entry instant
+#else
+ nop ! delay slot
+#endif
+#if defined(SPARC_USE_SYNCHRONOUS_FP_SWITCH)
+ mov %l0, %g1 ! PSR[EF] value of interrupted context
+ ta SPARC_SWTRAP_IRQDIS_FP ! **** DISABLE INTERRUPTS ****
+#else
+ ta SPARC_SWTRAP_IRQDIS ! **** DISABLE INTERRUPTS ****
+#endif
+ cmp %l7, 0
+ bne profiling_not_outer_most_exit
+ nop
+ call %l4 ! Call _SPARC_Counter.counter_read
+ mov %g1, %l4 ! Save previous interrupt status
+ mov %o0, %o2 ! o2 = 3rd arg = interrupt exit instant
+ mov %l3, %o1 ! o1 = 2nd arg = interrupt entry instant
+ call SYM(_Profiling_Outer_most_interrupt_entry_and_exit)
+ mov %g6, %o0 ! o0 = 1st arg = per-CPU control
+profiling_not_outer_most_exit:
+#endif
+ * Decrement ISR nest level and Thread dispatch disable level.
+ * o2 = g6->dispatch_necessary value
+ * o3 = g6->isr_dispatch_disable value
+ * l6 = g6->thread_dispatch_disable_level value
+ * l7 = g6->isr_nest_level value
+ ldub [%g6 + PER_CPU_DISPATCH_NEEDED], %o2
+ ld [%g6 + PER_CPU_ISR_DISPATCH_DISABLE], %o3
+ sub %l6, 1, %l6
+ * Thread dispatching is necessary and allowed if and only if
+ * g6->dispatch_necessary == 1 and
+ * g6->isr_dispatch_disable == 0 and
+ * g6->thread_dispatch_disable_level == 0.
+ * Otherwise, continue with the simple return.
+ xor %o2, 1, %o2
+ or %o2, %l6, %o2
+ orcc %o2, %o3, %o2
+ bnz simple_return
+ * Switch back on the interrupted tasks stack and add enough room to
+ * invoke the dispatcher. Doing this in the delay slot causes no harm,
+ * since the stack pointer (%sp) is not used in the simple return path.
+ sub %fp, SPARC_MINIMUM_STACK_FRAME_SIZE, %sp
+isr_dispatch:
+ /* Set ISR dispatch disable and thread dispatch disable level to one */
+ mov 1, %l6
+ st %l6, [%g6 + PER_CPU_ISR_DISPATCH_DISABLE]
+ /* Call _Thread_Do_dispatch(), this function will enable interrupts */
+ mov 0, %o1 ! ISR level for _Thread_Do_dispatch()
+#if defined(SPARC_USE_LAZY_FP_SWITCH)
+ /* Test if we interrupted a floating point thread (PSR[EF] == 1) */
+ be .Lnon_fp_thread_dispatch
+ ld [%g6 + PER_CPU_OFFSET_EXECUTING], %l6
+ /* Set new floating point unit owner to executing thread */
+ st %l6, [%g6 + SPARC_PER_CPU_FP_OWNER_OFFSET]
+ call SYM(_Thread_Do_dispatch)
+ mov %g6, %o0
+ * If we are still the floating point unit owner, then reset the
+ * floating point unit owner to NULL, otherwise clear PSR[EF] in the
+ * interrupt frame and let the FP disabled system call do the floating
+ * point context save/restore.
+ ld [%g6 + SPARC_PER_CPU_FP_OWNER_OFFSET], %l7
+ cmp %l6, %l7
+ bne,a .Ldisable_fp
+ andn %l0, %l5, %l0
+ st %g0, [%g6 + SPARC_PER_CPU_FP_OWNER_OFFSET]
+ ba .Lthread_dispatch_done
+ nop
+.Ldisable_fp:
+ st %l0, [%fp + ISF_PSR_OFFSET]
+ nop
+.Lnon_fp_thread_dispatch:
+#elif defined(SPARC_USE_SYNCHRONOUS_FP_SWITCH)
+ nop
+ * Yes, this is a floating point thread, then save the floating point
+ * context to a new stack frame. Then do the thread dispatch.
+ * Post-switch actions (e.g. signal handlers) and context switch
+ * extensions may safely use the floating point unit.
+ sub %sp, SPARC_FP_FRAME_SIZE, %sp
+ std %f0, [%sp + SPARC_FP_FRAME_OFFSET_FO_F1]
+ std %f2, [%sp + SPARC_FP_FRAME_OFFSET_F2_F3]
+ std %f4, [%sp + SPARC_FP_FRAME_OFFSET_F4_F5]
+ std %f6, [%sp + SPARC_FP_FRAME_OFFSET_F6_F7]
+ std %f8, [%sp + SPARC_FP_FRAME_OFFSET_F8_F9]
+ std %f10, [%sp + SPARC_FP_FRAME_OFFSET_F1O_F11]
+ std %f12, [%sp + SPARC_FP_FRAME_OFFSET_F12_F13]
+ std %f14, [%sp + SPARC_FP_FRAME_OFFSET_F14_F15]
+ std %f16, [%sp + SPARC_FP_FRAME_OFFSET_F16_F17]
+ std %f18, [%sp + SPARC_FP_FRAME_OFFSET_F18_F19]
+ std %f20, [%sp + SPARC_FP_FRAME_OFFSET_F2O_F21]
+ std %f22, [%sp + SPARC_FP_FRAME_OFFSET_F22_F23]
+ std %f24, [%sp + SPARC_FP_FRAME_OFFSET_F24_F25]
+ std %f26, [%sp + SPARC_FP_FRAME_OFFSET_F26_F27]
+ std %f28, [%sp + SPARC_FP_FRAME_OFFSET_F28_F29]
+ std %f30, [%sp + SPARC_FP_FRAME_OFFSET_F3O_F31]
+ st %fsr, [%sp + SPARC_FP_FRAME_OFFSET_FSR]
+ mov %g6, %o0
+ * Restore the floating point context from stack frame and release the
+ * stack frame.
+ ldd [%sp + SPARC_FP_FRAME_OFFSET_FO_F1], %f0
+ ldd [%sp + SPARC_FP_FRAME_OFFSET_F2_F3], %f2
+ ldd [%sp + SPARC_FP_FRAME_OFFSET_F4_F5], %f4
+ ldd [%sp + SPARC_FP_FRAME_OFFSET_F6_F7], %f6
+ ldd [%sp + SPARC_FP_FRAME_OFFSET_F8_F9], %f8
+ ldd [%sp + SPARC_FP_FRAME_OFFSET_F1O_F11], %f10
+ ldd [%sp + SPARC_FP_FRAME_OFFSET_F12_F13], %f12
+ ldd [%sp + SPARC_FP_FRAME_OFFSET_F14_F15], %f14
+ ldd [%sp + SPARC_FP_FRAME_OFFSET_F16_F17], %f16
+ ldd [%sp + SPARC_FP_FRAME_OFFSET_F18_F19], %f18
+ ldd [%sp + SPARC_FP_FRAME_OFFSET_F2O_F21], %f20
+ ldd [%sp + SPARC_FP_FRAME_OFFSET_F22_F23], %f22
+ ldd [%sp + SPARC_FP_FRAME_OFFSET_F24_F25], %f24
+ ldd [%sp + SPARC_FP_FRAME_OFFSET_F26_F27], %f26
+ ldd [%sp + SPARC_FP_FRAME_OFFSET_F28_F29], %f28
+ ldd [%sp + SPARC_FP_FRAME_OFFSET_F3O_F31], %f30
+ ld [%sp + SPARC_FP_FRAME_OFFSET_FSR], %fsr
+ add %sp, SPARC_FP_FRAME_SIZE, %sp
+#endif
+ mov %g6, %o0
+.Lthread_dispatch_done:
+#endif
+ * While we had ISR dispatching disabled in this thread,
+ * did we miss anything? If so, then we need to do another
+ * _Thread_Do_dispatch() before leaving this ISR dispatch context.
+ ldub [%g6 + PER_CPU_DISPATCH_NEEDED], %l7
+ orcc %l7, %g0, %g0 ! Is a thread dispatch necessary?
+ bne isr_dispatch ! Yes, then invoke the dispatcher again.
+ * No, then set the ISR dispatch disable flag to zero and continue with
+ * the simple return.
+ st %g0, [%g6 + PER_CPU_ISR_DISPATCH_DISABLE]
+ * The CWP in place at this point may be different from
+ * that which was in effect at the beginning of the ISR if we
+ * have been context switched between the beginning of this invocation
+ * of _ISR_Handler and this point. Thus the CWP and WIM should
+ * not be changed back to their values at ISR entry time. Any
+ * changes to the PSR must preserve the CWP.
+simple_return:
+ ld [%fp + ISF_Y_OFFSET], %l5 ! restore y
+ wr %l5, 0, %y
+ ldd [%fp + ISF_PSR_OFFSET], %l0 ! restore psr, PC
+ ld [%fp + ISF_NPC_OFFSET], %l2 ! restore nPC
+ rd %psr, %l3
+ and %l3, SPARC_PSR_CWP_MASK, %l3 ! want "current" CWP
+ andn %l0, SPARC_PSR_CWP_MASK, %l0 ! want rest from task
+ or %l3, %l0, %l0 ! install it later...
+ andn %l0, SPARC_PSR_ET_MASK, %l0
+ * Restore tasks global and out registers
+ mov %fp, %g1
+ ! g1 is restored later
+ ldd [%fp + ISF_G2_OFFSET], %g2 ! restore g2, g3
+ ldd [%fp + ISF_G4_OFFSET], %g4 ! restore g4, g5
+ ld [%fp + ISF_G7_OFFSET], %g7 ! restore g7
+ ldd [%fp + ISF_I0_OFFSET], %i0 ! restore i0, i1
+ ldd [%fp + ISF_I2_OFFSET], %i2 ! restore i2, i3
+ ldd [%fp + ISF_I4_OFFSET], %i4 ! restore i4, i5
+ ldd [%fp + ISF_I6_FP_OFFSET], %i6 ! restore i6/fp, i7
+ * Registers:
+ * ALL global registers EXCEPT G1 and the input registers have
+ * already been restored and thuse off limits.
+ * The following is the contents of the local registers:
+ * l0 = original psr
+ * l1 = return address (i.e. PC)
+ * l2 = nPC
+ * l3 = CWP
+ * if (CWP + 1) is an invalid window then we need to reload it.
+ * WARNING: Traps should now be disabled
+ mov %l0, %psr ! **** DISABLE TRAPS ****
+ nop
+ nop
+ nop
+ rd %wim, %l4
+ add %l0, 1, %l6 ! l6 = cwp + 1
+ and %l6, SPARC_PSR_CWP_MASK, %l6 ! do the modulo on it
+ srl %l4, %l6, %l5 ! l5 = win >> cwp + 1 ; shift count
+ ! and CWP are conveniently LS 5 bits
+ cmp %l5, 1 ! Is tasks window invalid?
+ bne good_task_window
+ * The following code is the same as a 1 position left rotate of WIM.
+ sll %l4, 1, %l5 ! l5 = WIM << 1
+ srl %l4, SPARC_NUMBER_OF_REGISTER_WINDOWS-1 , %l4
+ ! l4 = WIM >> (Number Windows - 1)
+ or %l4, %l5, %l4 ! l4 = (WIM << 1) |
+ ! (WIM >> (Number Windows - 1))
+ * Now restore the window just as if we underflowed to it.
+ wr %l4, 0, %wim ! WIM = new WIM
+ nop ! must delay after writing WIM
+ nop
+ nop
+ restore ! now into the tasks window
+ ldd [%g1 + CPU_STACK_FRAME_L0_OFFSET], %l0
+ ldd [%g1 + CPU_STACK_FRAME_L2_OFFSET], %l2
+ ldd [%g1 + CPU_STACK_FRAME_L4_OFFSET], %l4
+ ldd [%g1 + CPU_STACK_FRAME_L6_OFFSET], %l6
+ ldd [%g1 + CPU_STACK_FRAME_I0_OFFSET], %i0
+ ldd [%g1 + CPU_STACK_FRAME_I2_OFFSET], %i2
+ ldd [%g1 + CPU_STACK_FRAME_I4_OFFSET], %i4
+ ldd [%g1 + CPU_STACK_FRAME_I6_FP_OFFSET], %i6
+ ! reload of sp clobbers ISF
+ save ! Back to ISR dispatch window
+good_task_window:
+ TN0018_WAIT_IFLUSH %l3,%l4 ! GRLIB-TN-0018 work around macro
+ nop; nop; nop
+ ! and restore condition codes.
+ ld [%g1 + ISF_G1_OFFSET], %g1 ! restore g1
+ TN0018_FIX %l3,%l4 ! GRLIB-TN-0018 work around macro
+ jmp %l1 ! transfer control and
+ rett %l2 ! go back to tasks window
+/* end of file */
diff --git a/spec/build/cpukit/cpusparc.yml b/spec/build/cpukit/cpusparc.yml
index 2186505577..5cd6cd7998 100644
--- a/spec/build/cpukit/cpusparc.yml
+++ b/spec/build/cpukit/cpusparc.yml
@@ -39,6 +39,7 @@ source:
- cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S
- cpukit/score/cpu/sparc/sparc-counter-asm.S
- cpukit/score/cpu/sparc/sparc-exception-frame-print.c
+- cpukit/score/cpu/sparc/sparc-isr-handler.S
- cpukit/score/cpu/sparc/sparc-isr-install.c
- cpukit/score/cpu/sparc/syscall.S
- cpukit/score/cpu/sparc/window.S
2.26.2
