[PATCH 03/10] score: Move _ISR_Vector_table[] to separate file
Wed Jun 23 16:59:00 UTC 2021
On Wed, Jun 23, 2021 at 12:49 AM Sebastian Huber
> The _ISR_Handler_initialization() does not touch the _ISR_Vector_table[].  Move
> the definition of _ISR_Vector_table[] to a separate file.
> Change license to BSD-2-Clause according to file history and re-licensing
> agreement.
> Update #3053.
>  cpukit/Makefile.am                |  1 +
>  cpukit/score/src/isr.c            |  8 ------
>  cpukit/score/src/isrvectortable.c | 48 +++++++++++++++++++++++++++++++
>  spec/build/cpukit/librtemscpu.yml |  1 +
>  4 files changed, 50 insertions(+), 8 deletions(-)
>  create mode 100644 cpukit/score/src/isrvectortable.c
> diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
> index df970e5a1c..25382f38ca 100644
> --- a/cpukit/Makefile.am
> +++ b/cpukit/Makefile.am
> @@ -1023,6 +1023,7 @@ librtemscpu_a_SOURCES += score/src/chainnodecount.c
>  librtemscpu_a_SOURCES += score/src/debugisthreaddispatchingallowed.c
>  librtemscpu_a_SOURCES += score/src/interr.c
>  librtemscpu_a_SOURCES += score/src/isr.c
> +librtemscpu_a_SOURCES += score/src/isrvectortable.c
>  librtemscpu_a_SOURCES += score/src/wkspace.c
>  librtemscpu_a_SOURCES += score/src/wkspaceisunifieddefault.c
>  librtemscpu_a_SOURCES += score/src/wkspacemallocinitdefault.c
> diff --git a/cpukit/score/src/isr.c b/cpukit/score/src/isr.c
> index 28a6b3082e..b77f682663 100644
> --- a/cpukit/score/src/isr.c
> +++ b/cpukit/score/src/isr.c
> @@ -25,14 +25,6 @@
>  #include <rtems/score/percpu.h>
>  #include <rtems/config.h>
> -#if (CPU_SIMPLE_VECTORED_INTERRUPTS == TRUE)
> -  ISR_Handler_entry _ISR_Vector_table[ CPU_INTERRUPT_NUMBER_OF_VECTORS ];
> -#elif defined(CPU_INTERRUPT_NUMBER_OF_VECTORS)
> -  #error "CPU_INTERRUPT_NUMBER_OF_VECTORS is defined for non-simple vectored interrupts"
> -#elif defined(CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER)
> -  #error "CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER is defined for non-simple vectored interrupts"
> -#endif
>  void _ISR_Handler_initialization( void )
>    uint32_t  cpu_max;
> diff --git a/cpukit/score/src/isrvectortable.c b/cpukit/score/src/isrvectortable.c
> new file mode 100644
> index 0000000000..4bd892757e
> --- /dev/null
> +++ b/cpukit/score/src/isrvectortable.c
> @@ -0,0 +1,48 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup RTEMSScoreISR
> + * @brief This source file contains the definition of ::_ISR_Vector_table.
> + * Copyright (C) 2014 embedded brains GmbH (http://www.embedded-brains.de)
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/score/isr.h>
> +#if (CPU_SIMPLE_VECTORED_INTERRUPTS == TRUE)
> +  ISR_Handler_entry _ISR_Vector_table[ CPU_INTERRUPT_NUMBER_OF_VECTORS ];
> +#elif defined(CPU_INTERRUPT_NUMBER_OF_VECTORS)
Do we want to change this to _VECTOR_COUNT to be consistent with the
other patch set/API?
> +  #error "CPU_INTERRUPT_NUMBER_OF_VECTORS is defined for non-simple vectored interrupts"
> +#elif defined(CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER)
> +  #error "CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER is defined for non-simple vectored interrupts"
> +#endif
> diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
> index e3f328ec5f..0abff9d439 100644
> --- a/spec/build/cpukit/librtemscpu.yml
> +++ b/spec/build/cpukit/librtemscpu.yml
> @@ -1417,6 +1417,7 @@ source:
>  - cpukit/score/src/iovprintf.c
>  - cpukit/score/src/isr.c
>  - cpukit/score/src/isrisinprogress.c
> +- cpukit/score/src/isrvectortable.c
>  - cpukit/score/src/iterateoverthreads.c
>  - cpukit/score/src/kern_tc.c
>  - cpukit/score/src/libatomic.c
> 2.26.2
> devel mailing list
> devel at rtems.org
