[PATCH 03/10] score: Move _ISR_Vector_table[] to separate file
Sebastian Huber
Wed Jun 23 06:49:29 UTC 2021
The _ISR_Handler_initialization() does not touch the _ISR_Vector_table[]. Move
the definition of _ISR_Vector_table[] to a separate file.
Change license to BSD-2-Clause according to file history and re-licensing
agreement.
Update #3053.
cpukit/Makefile.am | 1 +
cpukit/score/src/isr.c | 8 ------
cpukit/score/src/isrvectortable.c | 48 +++++++++++++++++++++++++++++++
spec/build/cpukit/librtemscpu.yml | 1 +
4 files changed, 50 insertions(+), 8 deletions(-)
create mode 100644 cpukit/score/src/isrvectortable.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index df970e5a1c..25382f38ca 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1023,6 +1023,7 @@ librtemscpu_a_SOURCES += score/src/chainnodecount.c
librtemscpu_a_SOURCES += score/src/debugisthreaddispatchingallowed.c
librtemscpu_a_SOURCES += score/src/interr.c
librtemscpu_a_SOURCES += score/src/isr.c
+librtemscpu_a_SOURCES += score/src/isrvectortable.c
librtemscpu_a_SOURCES += score/src/wkspace.c
librtemscpu_a_SOURCES += score/src/wkspaceisunifieddefault.c
librtemscpu_a_SOURCES += score/src/wkspacemallocinitdefault.c
diff --git a/cpukit/score/src/isr.c b/cpukit/score/src/isr.c
index 28a6b3082e..b77f682663 100644
--- a/cpukit/score/src/isr.c
+++ b/cpukit/score/src/isr.c
@@ -25,14 +25,6 @@
#include <rtems/config.h>
-#if (CPU_SIMPLE_VECTORED_INTERRUPTS == TRUE)
- ISR_Handler_entry _ISR_Vector_table[ CPU_INTERRUPT_NUMBER_OF_VECTORS ];
-#elif defined(CPU_INTERRUPT_NUMBER_OF_VECTORS)
- #error "CPU_INTERRUPT_NUMBER_OF_VECTORS is defined for non-simple vectored interrupts"
-#elif defined(CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER)
- #error "CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER is defined for non-simple vectored interrupts"
-#endif
void _ISR_Handler_initialization( void )
uint32_t cpu_max;
diff --git a/cpukit/score/src/isrvectortable.c b/cpukit/score/src/isrvectortable.c
new file mode 100644
index 0000000000..4bd892757e
--- /dev/null
+++ b/cpukit/score/src/isrvectortable.c
@@ -0,0 +1,48 @@
+ * @file
+ * @ingroup RTEMSScoreISR
+ * @brief This source file contains the definition of ::_ISR_Vector_table.
+ * Copyright (C) 2014 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/isr.h>
+#if (CPU_SIMPLE_VECTORED_INTERRUPTS == TRUE)
+ ISR_Handler_entry _ISR_Vector_table[ CPU_INTERRUPT_NUMBER_OF_VECTORS ];
+#elif defined(CPU_INTERRUPT_NUMBER_OF_VECTORS)
+ #error "CPU_INTERRUPT_NUMBER_OF_VECTORS is defined for non-simple vectored interrupts"
+#elif defined(CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER)
+ #error "CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER is defined for non-simple vectored interrupts"
+#endif
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index e3f328ec5f..0abff9d439 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1417,6 +1417,7 @@ source:
- cpukit/score/src/iovprintf.c
- cpukit/score/src/isr.c
- cpukit/score/src/isrisinprogress.c
+- cpukit/score/src/isrvectortable.c
- cpukit/score/src/iterateoverthreads.c
- cpukit/score/src/kern_tc.c
- cpukit/score/src/libatomic.c
2.26.2
