[PATCH 04/10] bsps/sparc: Add a symbol for each trap table entry
Wed Jun 23 17:06:36 UTC 2021
On Wed, Jun 23, 2021 at 12:49 AM Sebastian Huber
> This makes it easier to review start.o and set break points to trap table
> entries.  This change was checked by inspecting the trap table in start.o with
> objdump.
> Update #4458.
>  bsps/sparc/shared/start/start.S | 359 +++++++++++++++++++++++---------
>  1 file changed, 264 insertions(+), 95 deletions(-)
> diff --git a/bsps/sparc/shared/start/start.S b/bsps/sparc/shared/start/start.S
> index 13c3cffc00..9bdc752fa2 100644
> --- a/bsps/sparc/shared/start/start.S
> +++ b/bsps/sparc/shared/start/start.S
> @@ -23,10 +23,13 @@
>    #define START_LEON3_ENABLE_SMP
>  #endif
> +#define TRAP_SYM(_vector) SYM(trap_##_vector)
>   *  Unexpected trap will halt the processor by forcing it to error state
> -#define BAD_TRAP \
> +#define BAD_TRAP(_vector) \
> +  TRAP_SYM(_vector):; \
>    ta 0; \
>    nop; \
>    nop; \
> @@ -81,7 +84,7 @@
>   *  Software trap. Treat as BAD_TRAP for the time being...
> -#define SOFT_TRAP BAD_TRAP
> +#define SOFT_TRAP(_vector) BAD_TRAP(_vector)
>    .section    ".text"
>    PUBLIC(start)
> @@ -105,73 +108,143 @@ start:
>  SYM(trap_table):
>    RTRAP( 0, SYM(hard_reset) );                  ! 00 reset trap
> -  BAD_TRAP;                                     ! 01 instruction access
> +  BAD_TRAP(0x01)                                ! 01 instruction access
>                                                  !    exception
> -  BAD_TRAP;                                     ! 02 illegal instruction
> -  BAD_TRAP;                                     ! 03 privileged instruction
> +  BAD_TRAP(0x02)                                ! 02 illegal instruction
> +  BAD_TRAP(0x03)                                ! 03 privileged instruction
>  #if defined(SPARC_USE_LAZY_FP_SWITCH)
> +TRAP_SYM(0x04):
>    FPDIS_TRAP(SYM(syscall_lazy_fp_switch));      ! 04 fp disabled
>  #else
> -  BAD_TRAP;                                     ! 04 fp disabled
> +  BAD_TRAP(0x04)                                ! 04 fp disabled
>  #endif
> +TRAP_SYM(0x05):
>    WOTRAP(5, SYM(window_overflow_trap_handler)); ! 05 window overflow
> +TRAP_SYM(0x06):
>    WUTRAP(6, SYM(window_underflow_trap_handler));! 06 window underflow
> -  BAD_TRAP;                                     ! 07 memory address not aligned
> -  BAD_TRAP;                                     ! 08 fp exception
> -  BAD_TRAP;                                     ! 09 data access exception
> -  BAD_TRAP;                                     ! 0A tag overflow
> -  BAD_TRAP;                                     ! 0B undefined
> -  BAD_TRAP;                                     ! 0C undefined
> -  BAD_TRAP;                                     ! 0D undefined
> -  BAD_TRAP;                                     ! 0E undefined
> -  BAD_TRAP;                                     ! 0F undefined
> -  BAD_TRAP;                                     ! 10 undefined
> +  BAD_TRAP(0x07)                                ! 07 memory address not aligned
> +  BAD_TRAP(0x08)                                ! 08 fp exception
> +  BAD_TRAP(0x09)                                ! 09 data access exception
> +  BAD_TRAP(0x0a)                                ! 0A tag overflow
> +  BAD_TRAP(0x0b)                                ! 0B undefined
> +  BAD_TRAP(0x0c)                                ! 0C undefined
> +  BAD_TRAP(0x0d)                                ! 0D undefined
> +  BAD_TRAP(0x0e)                                ! 0E undefined
> +  BAD_TRAP(0x0f)                                ! 0F undefined
> +  BAD_TRAP(0x10)                                ! 10 undefined
This code could be simplified using assembly macros (.irp) something
like what I did in bsps/sparc64/shared/start/trap_table.S
.irp idx, 0x07, 0x08, .... 0x10
  BAD_TRAP(\idx)
.endr
Not necessary to do, but came to my mind. Perhaps, keeping them broken
out makes it easier to document with comments.
> -   *  ERC32 defined traps
> +   *  External interrupt traps
> -  BAD_TRAP;                                     ! 11 masked errors
> -  BAD_TRAP;                                     ! 12 external 1
> -  BAD_TRAP;                                     ! 13 external 2
> -  BAD_TRAP;                                     ! 14 UART A RX/TX
> -  BAD_TRAP;                                     ! 15 UART B RX/TX
> -  BAD_TRAP;                                     ! 16 correctable memory error
> -  BAD_TRAP;                                     ! 17 UART error
> -  BAD_TRAP;                                     ! 18 DMA access error
> -  BAD_TRAP;                                     ! 19 DMA timeout
> -  BAD_TRAP;                                     ! 1A external 3
> -  BAD_TRAP;                                     ! 1B external 4
> -  BAD_TRAP;                                     ! 1C general purpose timer
> -  BAD_TRAP;                                     ! 1D real time clock
> -  BAD_TRAP;                                     ! 1E external 5
> -  BAD_TRAP;                                     ! 1F watchdog timeout
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 20 - 23 undefined
> -  BAD_TRAP;                                     ! 24 cp_disabled
> -            BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 25 - 27 undefined
> -  BAD_TRAP;                                     ! 28 cp_exception
> -            BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 29 - 2B undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 2C - 2F undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 30 - 33 undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 34 - 37 undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 38 - 3B undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 3C - 3F undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 40 - 43 undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 44 - 47 undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 48 - 4B undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 4C - 4F undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 50 - 53 undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 54 - 57 undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 58 - 5B undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 5C - 5F undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 60 - 63 undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 64 - 67 undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 68 - 6B undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 6C - 6F undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 70 - 73 undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 74 - 77 undefined
> -  BAD_TRAP; BAD_TRAP; BAD_TRAP; BAD_TRAP;       ! 78 - 7B undefined
> +  BAD_TRAP(0x11)                                ! 11 external interrupt 1
> +  BAD_TRAP(0x12)                                ! 12 external interrupt 2
> +  BAD_TRAP(0x13)                                ! 13 external interrupt 3
> +  BAD_TRAP(0x14)                                ! 14 external interrupt 4
> +  BAD_TRAP(0x15)                                ! 15 external interrupt 5
> +  BAD_TRAP(0x16)                                ! 16 external interrupt 6
> +  BAD_TRAP(0x17)                                ! 17 external interrupt 7
> +  BAD_TRAP(0x18)                                ! 18 external interrupt 8
> +  BAD_TRAP(0x19)                                ! 19 external interrupt 9
> +  BAD_TRAP(0x1a)                                ! 1A external interrupt 10
> +  BAD_TRAP(0x1b)                                ! 1B external interrupt 11
> +  BAD_TRAP(0x1c)                                ! 1C external interrupt 12
> +  BAD_TRAP(0x1d)                                ! 1D external interrupt 13
> +  BAD_TRAP(0x1e)                                ! 1E external interrupt 14
> +  BAD_TRAP(0x1f)                                ! 1F external interrupt 15
> +  BAD_TRAP(0x20)                                ! 20 undefined
> +  BAD_TRAP(0x21)                                ! 21 undefined
> +  BAD_TRAP(0x22)                                ! 22 undefined
> +  BAD_TRAP(0x23)                                ! 23 undefined
> +  BAD_TRAP(0x24)                                ! 24 cp_disabled
> +  BAD_TRAP(0x25)                                ! 25 undefined
> +  BAD_TRAP(0x26)                                ! 26 undefined
> +  BAD_TRAP(0x27)                                ! 27 undefined
> +  BAD_TRAP(0x28)                                ! 28 cp_exception
> +  BAD_TRAP(0x29)                                ! 29 undefined
> +  BAD_TRAP(0x2a)                                ! 2A undefined
> +  BAD_TRAP(0x2b)                                ! 2B undefined
> +  BAD_TRAP(0x2c)                                ! 2C undefined
> +  BAD_TRAP(0x2d)                                ! 2D undefined
> +  BAD_TRAP(0x2e)                                ! 2E undefined
> +  BAD_TRAP(0x2f)                                ! 2F undefined
> +  BAD_TRAP(0x30)                                ! 30 undefined
> +  BAD_TRAP(0x31)                                ! 31 undefined
> +  BAD_TRAP(0x32)                                ! 32 undefined
> +  BAD_TRAP(0x33)                                ! 33 undefined
> +  BAD_TRAP(0x34)                                ! 34 undefined
> +  BAD_TRAP(0x35)                                ! 35 undefined
> +  BAD_TRAP(0x36)                                ! 36 undefined
> +  BAD_TRAP(0x37)                                ! 37 undefined
> +  BAD_TRAP(0x38)                                ! 38 undefined
> +  BAD_TRAP(0x39)                                ! 39 undefined
> +  BAD_TRAP(0x3a)                                ! 3A undefined
> +  BAD_TRAP(0x3b)                                ! 3B undefined
> +  BAD_TRAP(0x3c)                                ! 3C undefined
> +  BAD_TRAP(0x3d)                                ! 3D undefined
> +  BAD_TRAP(0x3e)                                ! 3E undefined
> +  BAD_TRAP(0x3f)                                ! 3F undefined
> +  BAD_TRAP(0x40)                                ! 40 undefined
> +  BAD_TRAP(0x41)                                ! 41 undefined
> +  BAD_TRAP(0x42)                                ! 42 undefined
> +  BAD_TRAP(0x43)                                ! 43 undefined
> +  BAD_TRAP(0x44)                                ! 44 undefined
> +  BAD_TRAP(0x45)                                ! 45 undefined
> +  BAD_TRAP(0x46)                                ! 46 undefined
> +  BAD_TRAP(0x47)                                ! 47 undefined
> +  BAD_TRAP(0x48)                                ! 48 undefined
> +  BAD_TRAP(0x49)                                ! 49 undefined
> +  BAD_TRAP(0x4a)                                ! 4A undefined
> +  BAD_TRAP(0x4b)                                ! 4B undefined
> +  BAD_TRAP(0x4c)                                ! 4C undefined
> +  BAD_TRAP(0x4d)                                ! 4D undefined
> +  BAD_TRAP(0x4e)                                ! 4E undefined
> +  BAD_TRAP(0x4f)                                ! 4F undefined
> +  BAD_TRAP(0x50)                                ! 50 undefined
> +  BAD_TRAP(0x51)                                ! 51 undefined
> +  BAD_TRAP(0x52)                                ! 52 undefined
> +  BAD_TRAP(0x53)                                ! 53 undefined
> +  BAD_TRAP(0x54)                                ! 54 undefined
> +  BAD_TRAP(0x55)                                ! 55 undefined
> +  BAD_TRAP(0x56)                                ! 56 undefined
> +  BAD_TRAP(0x57)                                ! 57 undefined
> +  BAD_TRAP(0x58)                                ! 58 undefined
> +  BAD_TRAP(0x59)                                ! 59 undefined
> +  BAD_TRAP(0x5a)                                ! 5A undefined
> +  BAD_TRAP(0x5b)                                ! 5B undefined
> +  BAD_TRAP(0x5c)                                ! 5C undefined
> +  BAD_TRAP(0x5d)                                ! 5D undefined
> +  BAD_TRAP(0x5e)                                ! 5E undefined
> +  BAD_TRAP(0x5f)                                ! 5F undefined
> +  BAD_TRAP(0x60)                                ! 60 undefined
> +  BAD_TRAP(0x61)                                ! 61 undefined
> +  BAD_TRAP(0x62)                                ! 62 undefined
> +  BAD_TRAP(0x63)                                ! 63 undefined
> +  BAD_TRAP(0x64)                                ! 64 undefined
> +  BAD_TRAP(0x65)                                ! 65 undefined
> +  BAD_TRAP(0x66)                                ! 66 undefined
> +  BAD_TRAP(0x67)                                ! 67 undefined
> +  BAD_TRAP(0x68)                                ! 68 undefined
> +  BAD_TRAP(0x69)                                ! 69 undefined
> +  BAD_TRAP(0x6a)                                ! 6A undefined
> +  BAD_TRAP(0x6b)                                ! 6B undefined
> +  BAD_TRAP(0x6c)                                ! 6C undefined
> +  BAD_TRAP(0x6d)                                ! 6D undefined
> +  BAD_TRAP(0x6e)                                ! 6E undefined
> +  BAD_TRAP(0x6f)                                ! 6F undefined
> +  BAD_TRAP(0x70)                                ! 70 undefined
> +  BAD_TRAP(0x71)                                ! 71 undefined
> +  BAD_TRAP(0x72)                                ! 72 undefined
> +  BAD_TRAP(0x73)                                ! 73 undefined
> +  BAD_TRAP(0x74)                                ! 74 undefined
> +  BAD_TRAP(0x75)                                ! 75 undefined
> +  BAD_TRAP(0x76)                                ! 76 undefined
> +  BAD_TRAP(0x77)                                ! 77 undefined
> +  BAD_TRAP(0x78)                                ! 78 undefined
> +  BAD_TRAP(0x79)                                ! 79 undefined
> +  BAD_TRAP(0x7a)                                ! 7A undefined
> +  BAD_TRAP(0x7b)                                ! 7B undefined
>     This is a sad patch to make sure that we know where the
> @@ -184,13 +257,15 @@ SYM(trap_table):
>  SYM(_ERC32_MEC_Timer_Control_Mirror):
> -  BAD_TRAP; BAD_TRAP;                           ! 7C - 7D undefined
> +  BAD_TRAP(0x7C)                                ! 7C undefined
> +  BAD_TRAP(0x7D)                                ! 7D undefined
>  SYM(CLOCK_SPEED):
> +TRAP_SYM(0x7e):
>    .word        0x0a, 0, 0, 0                           ! 7E (10 MHz default)
> -  BAD_TRAP;                                    ! 7F undefined
> +  BAD_TRAP(0x7F)                                ! 7F undefined
>     *  Software traps
> @@ -201,12 +276,17 @@ SYM(CLOCK_SPEED):
>     *        installed before.
> +TRAP_SYM(0x80):
>    TRAP( 0x80, SYM(syscall) );                   ! 80 halt syscall SW trap
> -  SOFT_TRAP; SOFT_TRAP;                         ! 81 - 82
> +  SOFT_TRAP(0x81)                               ! 81
> +  SOFT_TRAP(0x82)                               ! 82
> +TRAP_SYM(0x83):
>    TRAP( 0x83, SYM(window_flush_trap_handler) ); ! 83 flush windows SW trap
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! 84 - 87
> -  SOFT_TRAP;                                    ! 88
> +  SOFT_TRAP(0x84)                               ! 84
> +  SOFT_TRAP(0x85)                               ! 85
> +  SOFT_TRAP(0x86)                               ! 86
> +  SOFT_TRAP(0x87)                               ! 87
> +  SOFT_TRAP(0x88)                               ! 88
>     *  SW Trap 9-15 Reserved for Operating System
> @@ -214,44 +294,133 @@ SYM(CLOCK_SPEED):
>     *  SPARC_SWTRAP_IRQDIS
>     *  SPARC_SWTRAP_IRQEN
> +TRAP_SYM(0x89):
>    IRQDIS_TRAP(SYM(syscall_irqdis));             ! 89 IRQ Disable syscall trap
> +TRAP_SYM(0x8a):
>    IRQEN_TRAP(SYM(syscall_irqen));               ! 8A IRQ Enable syscall trap
>  #if defined(SPARC_USE_SYNCHRONOUS_FP_SWITCH)
> +TRAP_SYM(0x8b):
>    IRQDIS_TRAP(SYM(syscall_irqdis_fp));          ! 8B IRQ disable
>                                                  ! and set PSR[EF] syscall trap
>  #else
> -  SOFT_TRAP;                                    ! 8B
> +  SOFT_TRAP(0x8b)                               ! 8B
>  #endif
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! 8C - 8F
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! 90 - 93
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! 94 - 97
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! 98 - 9B
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! 9C - 9F
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! A0 - A3
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! A4 - A7
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! A8 - AB
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! AC - AF
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! B0 - B3
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! B4 - B7
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! B8 - BB
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! BC - BF
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! C0 - C3
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! C4 - C7
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! C8 - CB
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! CC - CF
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! D0 - D3
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! D4 - D7
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! D8 - DB
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! DC - DF
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! E0 - E3
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! E4 - E7
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! E8 - EB
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! EC - EF
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! F0 - F3
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! F4 - F7
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! F8 - FB
> -  SOFT_TRAP; SOFT_TRAP; SOFT_TRAP; SOFT_TRAP;   ! FC - FF
> +  SOFT_TRAP(0x8c)                               ! 8C
> +  SOFT_TRAP(0x8d)                               ! 8D
> +  SOFT_TRAP(0x8e)                               ! 8E
> +  SOFT_TRAP(0x8f)                               ! 8F
> +  SOFT_TRAP(0x90)                               ! 90
> +  SOFT_TRAP(0x91)                               ! 91
> +  SOFT_TRAP(0x92)                               ! 92
> +  SOFT_TRAP(0x93)                               ! 93
> +  SOFT_TRAP(0x94)                               ! 94
> +  SOFT_TRAP(0x95)                               ! 95
> +  SOFT_TRAP(0x96)                               ! 96
> +  SOFT_TRAP(0x97)                               ! 97
> +  SOFT_TRAP(0x98)                               ! 98
> +  SOFT_TRAP(0x99)                               ! 99
> +  SOFT_TRAP(0x9a)                               ! 9A
> +  SOFT_TRAP(0x9b)                               ! 9B
> +  SOFT_TRAP(0x9c)                               ! 9C
> +  SOFT_TRAP(0x9d)                               ! 9D
> +  SOFT_TRAP(0x9e)                               ! 9E
> +  SOFT_TRAP(0x9f)                               ! 9F
> +  SOFT_TRAP(0xa0)                               ! a0
> +  SOFT_TRAP(0xa1)                               ! a1
> +  SOFT_TRAP(0xa2)                               ! a2
> +  SOFT_TRAP(0xa3)                               ! a3
> +  SOFT_TRAP(0xa4)                               ! a4
> +  SOFT_TRAP(0xa5)                               ! a5
> +  SOFT_TRAP(0xa6)                               ! a6
> +  SOFT_TRAP(0xa7)                               ! a7
> +  SOFT_TRAP(0xa8)                               ! a8
> +  SOFT_TRAP(0xa9)                               ! a9
> +  SOFT_TRAP(0xaa)                               ! aA
> +  SOFT_TRAP(0xab)                               ! aB
> +  SOFT_TRAP(0xac)                               ! aC
> +  SOFT_TRAP(0xad)                               ! aD
> +  SOFT_TRAP(0xae)                               ! aE
> +  SOFT_TRAP(0xaf)                               ! aF
> +  SOFT_TRAP(0xb0)                               ! b0
> +  SOFT_TRAP(0xb1)                               ! b1
> +  SOFT_TRAP(0xb2)                               ! b2
> +  SOFT_TRAP(0xb3)                               ! b3
> +  SOFT_TRAP(0xb4)                               ! b4
> +  SOFT_TRAP(0xb5)                               ! b5
> +  SOFT_TRAP(0xb6)                               ! b6
> +  SOFT_TRAP(0xb7)                               ! b7
> +  SOFT_TRAP(0xb8)                               ! b8
> +  SOFT_TRAP(0xb9)                               ! b9
> +  SOFT_TRAP(0xba)                               ! bA
> +  SOFT_TRAP(0xbb)                               ! bB
> +  SOFT_TRAP(0xbc)                               ! bC
> +  SOFT_TRAP(0xbd)                               ! bD
> +  SOFT_TRAP(0xbe)                               ! bE
> +  SOFT_TRAP(0xbf)                               ! bF
> +  SOFT_TRAP(0xc0)                               ! c0
> +  SOFT_TRAP(0xc1)                               ! c1
> +  SOFT_TRAP(0xc2)                               ! c2
> +  SOFT_TRAP(0xc3)                               ! c3
> +  SOFT_TRAP(0xc4)                               ! c4
> +  SOFT_TRAP(0xc5)                               ! c5
> +  SOFT_TRAP(0xc6)                               ! c6
> +  SOFT_TRAP(0xc7)                               ! c7
> +  SOFT_TRAP(0xc8)                               ! c8
> +  SOFT_TRAP(0xc9)                               ! c9
> +  SOFT_TRAP(0xca)                               ! cA
> +  SOFT_TRAP(0xcb)                               ! cB
> +  SOFT_TRAP(0xcc)                               ! cC
> +  SOFT_TRAP(0xcd)                               ! cD
> +  SOFT_TRAP(0xce)                               ! cE
> +  SOFT_TRAP(0xcf)                               ! cF
> +  SOFT_TRAP(0xd0)                               ! d0
> +  SOFT_TRAP(0xd1)                               ! d1
> +  SOFT_TRAP(0xd2)                               ! d2
> +  SOFT_TRAP(0xd3)                               ! d3
> +  SOFT_TRAP(0xd4)                               ! d4
> +  SOFT_TRAP(0xd5)                               ! d5
> +  SOFT_TRAP(0xd6)                               ! d6
> +  SOFT_TRAP(0xd7)                               ! d7
> +  SOFT_TRAP(0xd8)                               ! d8
> +  SOFT_TRAP(0xd9)                               ! d9
> +  SOFT_TRAP(0xda)                               ! dA
> +  SOFT_TRAP(0xdb)                               ! dB
> +  SOFT_TRAP(0xdc)                               ! dC
> +  SOFT_TRAP(0xdd)                               ! dD
> +  SOFT_TRAP(0xde)                               ! dE
> +  SOFT_TRAP(0xdf)                               ! dF
> +  SOFT_TRAP(0xe0)                               ! e0
> +  SOFT_TRAP(0xe1)                               ! e1
> +  SOFT_TRAP(0xe2)                               ! e2
> +  SOFT_TRAP(0xe3)                               ! e3
> +  SOFT_TRAP(0xe4)                               ! e4
> +  SOFT_TRAP(0xe5)                               ! e5
> +  SOFT_TRAP(0xe6)                               ! e6
> +  SOFT_TRAP(0xe7)                               ! e7
> +  SOFT_TRAP(0xe8)                               ! e8
> +  SOFT_TRAP(0xe9)                               ! e9
> +  SOFT_TRAP(0xea)                               ! eA
> +  SOFT_TRAP(0xeb)                               ! eB
> +  SOFT_TRAP(0xec)                               ! eC
> +  SOFT_TRAP(0xed)                               ! eD
> +  SOFT_TRAP(0xee)                               ! eE
> +  SOFT_TRAP(0xef)                               ! eF
> +  SOFT_TRAP(0xf0)                               ! f0
> +  SOFT_TRAP(0xf1)                               ! f1
> +  SOFT_TRAP(0xf2)                               ! f2
> +  SOFT_TRAP(0xf3)                               ! f3
> +  SOFT_TRAP(0xf4)                               ! f4
> +  SOFT_TRAP(0xf5)                               ! f5
> +  SOFT_TRAP(0xf6)                               ! f6
> +  SOFT_TRAP(0xf7)                               ! f7
> +  SOFT_TRAP(0xf8)                               ! f8
> +  SOFT_TRAP(0xf9)                               ! f9
> +  SOFT_TRAP(0xfa)                               ! fA
> +  SOFT_TRAP(0xfb)                               ! fB
> +  SOFT_TRAP(0xfc)                               ! fC
> +  SOFT_TRAP(0xfd)                               ! fD
> +  SOFT_TRAP(0xfe)                               ! fE
> +  SOFT_TRAP(0xff)                               ! fF
>   *  This is the hard reset code.
> 2.26.2
> devel mailing list
> devel at rtems.org
