[PATCH v6 2/2] Update smpstrongapa01; Add smpstrongapa02,smpstrongapa03
Thu Jun 24 12:20:07 UTC 2021
On 16/06/2021 08:00, Richi Dubey wrote:
> Update smpstrongapa01 to account for task shifting.
>   spec/build/testsuites/smptests/grp.yml        |   4 +
>   .../testsuites/smptests/smpstrongapa02.yml    |  21 +
>   .../testsuites/smptests/smpstrongapa03.yml    |  21 +
>   testsuites/smptests/smpstrongapa01/init.c     |  72 ++--
>   testsuites/smptests/smpstrongapa02/init.c     | 373 ++++++++++++++++++
>   .../smpstrongapa02/smpstrongapa02.doc         |  11 +
>   .../smpstrongapa02/smpstrongapa02.scn         |   2 +
>   testsuites/smptests/smpstrongapa03/init.c     | 358 +++++++++++++++++
>   .../smpstrongapa03/smpstrongapa03.doc         |  11 +
>   .../smpstrongapa03/smpstrongapa03.scn         |   2 +
>   10 files changed, 846 insertions(+), 29 deletions(-)
>   create mode 100644 spec/build/testsuites/smptests/smpstrongapa02.yml
>   create mode 100644 spec/build/testsuites/smptests/smpstrongapa03.yml
>   create mode 100644 testsuites/smptests/smpstrongapa02/init.c
>   create mode 100644 testsuites/smptests/smpstrongapa02/smpstrongapa02.doc
>   create mode 100644 testsuites/smptests/smpstrongapa02/smpstrongapa02.scn
>   create mode 100644 testsuites/smptests/smpstrongapa03/init.c
>   create mode 100644 testsuites/smptests/smpstrongapa03/smpstrongapa03.doc
>   create mode 100644 testsuites/smptests/smpstrongapa03/smpstrongapa03.scn
I checked in the first patch with a small modification to be in line
with the file header template.
Why can't the test cases of the additional two test programs be merged
into the existing test program smpstrongapa01?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
