[PATCH v6 2/2] Update smpstrongapa01; Add smpstrongapa02,smpstrongapa03
Richi Dubey richidubey at gmail.com
Fri Jun 25 12:19:11 UTC 2021
Hi,
Great! Thanks a lot for the review process and the merge :)
Why can't the test cases of the additional two test programs be merged
> into the existing test program smpstrongapa01?
Good point. I am looking into this right now. The original idea behind
having multiple test programs was to have more testing - and be more
confident that the task-shifting works. I will see if the tests can be
merged safely.
On Thu, Jun 24, 2021 at 5:50 PM Sebastian Huber <
> On 16/06/2021 08:00, Richi Dubey wrote:
> > Update smpstrongapa01 to account for task shifting.
> >   spec/build/testsuites/smptests/grp.yml        |   4 +
> >   .../testsuites/smptests/smpstrongapa02.yml    |  21 +
> >   .../testsuites/smptests/smpstrongapa03.yml    |  21 +
> >   testsuites/smptests/smpstrongapa01/init.c     |  72 ++--
> >   testsuites/smptests/smpstrongapa02/init.c     | 373 ++++++++++++++++++
> >   .../smpstrongapa02/smpstrongapa02.doc         |  11 +
> >   .../smpstrongapa02/smpstrongapa02.scn         |   2 +
> >   testsuites/smptests/smpstrongapa03/init.c     | 358 +++++++++++++++++
> >   .../smpstrongapa03/smpstrongapa03.doc         |  11 +
> >   .../smpstrongapa03/smpstrongapa03.scn         |   2 +
> >   10 files changed, 846 insertions(+), 29 deletions(-)
> >   create mode 100644 spec/build/testsuites/smptests/smpstrongapa02.yml
> >   create mode 100644 spec/build/testsuites/smptests/smpstrongapa03.yml
> >   create mode 100644 testsuites/smptests/smpstrongapa02/init.c
> >   create mode 100644
> testsuites/smptests/smpstrongapa02/smpstrongapa02.doc
> >   create mode 100644
> testsuites/smptests/smpstrongapa02/smpstrongapa02.scn
> >   create mode 100644 testsuites/smptests/smpstrongapa03/init.c
> >   create mode 100644
> testsuites/smptests/smpstrongapa03/smpstrongapa03.doc
> >   create mode 100644
> testsuites/smptests/smpstrongapa03/smpstrongapa03.scn
> I checked in the first patch with a small modification to be in line
> with the file header template.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210625/5dde969d/attachment.html>
