[PATCH v2 0/7] Add aarch64/xilinx-versal
Gedare Bloom
gedare at rtems.org
Thu Jun 24 15:50:17 UTC 2021
* Rebased and updated for BSP Interrupt Vector changes.
* Renamed BSP_START_IN_MON_SUPPORT to BSP_START_IN_EL3_MONITOR_MODE_SUPPORT
* Replaced BSP_START_IN_EL3_MONITOR_MODE_SUPPORT and
BSP_START_IN_HYP_SUPPORT conditional code compliation with
assembly switch-like logic to dynamically handle stepping
down from EL3 or EL2 into EL1.
Tested with aarch64:
- xilinx_versal_lp64_qemu
- xilinx_zynqmp_lp64_qemu
- a72_lp64_qemu
Gedare Bloom (6):
aarch64/xilinx-versal: new BSPs for qemu and vck190
bsps/dev/irq: make icspicfgr an indexable array
bsps/aarch64: add mnemonic for ICC_IGRPEN1_EL3
bsps/aarch64: add physical secure timer
bsps/aarch64: add non-secure mode and versal support
bsps/aarch64: replace boot options with asm switch code
Kinsey Moore (1):
aarch64: add support to drop EL3 to EL2
.../shared/clock/arm-generic-timer-aarch64.c | 8 +
bsps/aarch64/shared/start/start.S | 46 +++-
bsps/aarch64/xilinx-versal/console/console.c | 134 ++++++++++
.../dev/serial/versal-uart-polled.c | 228 ++++++++++++++++++
bsps/aarch64/xilinx-versal/include/bsp.h | 81 +++++++
bsps/aarch64/xilinx-versal/include/bsp/irq.h | 71 ++++++
.../include/dev/serial/versal-uart-regs.h | 141 +++++++++++
.../include/dev/serial/versal-uart.h | 90 +++++++
bsps/aarch64/xilinx-versal/include/tm27.h | 45 ++++
bsps/aarch64/xilinx-versal/start/bspstart.c | 48 ++++
.../xilinx-versal/start/bspstarthooks.c | 51 ++++
.../aarch64/xilinx-versal/start/bspstartmmu.c | 77 ++++++
bsps/include/dev/irq/arm-gic-regs.h | 6 +-
bsps/shared/dev/irq/arm-gicv3.c | 24 +-
spec/build/bsps/aarch64/a53/grp.yml | 2 +
spec/build/bsps/aarch64/a72/grp.yml | 2 +
spec/build/bsps/aarch64/optgtuseps.yml | 17 ++
spec/build/bsps/aarch64/optgtusevirt.yml | 16 ++
spec/build/bsps/aarch64/optisns.yml | 20 ++
spec/build/bsps/aarch64/xilinx-versal/abi.yml | 22 ++
.../aarch64/xilinx-versal/bspqemuilp32.yml | 19 ++
.../aarch64/xilinx-versal/bspqemulp64.yml | 19 ++
.../aarch64/xilinx-versal/bspvck190ilp32.yml | 19 ++
.../aarch64/xilinx-versal/bspvck190lp64.yml | 19 ++
spec/build/bsps/aarch64/xilinx-versal/grp.yml | 56 +++++
.../bsps/aarch64/xilinx-versal/grp_qemu.yml | 16 ++
.../bsps/aarch64/xilinx-versal/grp_vck190.yml | 16 ++
.../aarch64/xilinx-versal/linkcmds_ilp32.yml | 74 ++++++
.../aarch64/xilinx-versal/linkcmds_lp64.yml | 74 ++++++
spec/build/bsps/aarch64/xilinx-versal/obj.yml | 44 ++++
.../bsps/aarch64/xilinx-versal/optclkuart.yml | 20 ++
.../aarch64/xilinx-versal/optconminor.yml | 16 ++
.../bsps/aarch64/xilinx-versal/optloadoff.yml | 22 ++
.../aarch64/xilinx-versal/optnocachelen.yml | 18 ++
.../bsps/aarch64/xilinx-versal/optramlen.yml | 18 ++
.../bsps/aarch64/xilinx-versal/optramori.yml | 22 ++
.../bsps/aarch64/xilinx-versal/tstqemu.yml | 19 ++
.../bsps/aarch64/xilinx-versal/tstvck190.yml | 19 ++
spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml | 2 +
.../bsps/aarch64/xilinx-zynqmp/grp_zu3eg.yml | 2 -
40 files changed, 1633 insertions(+), 10 deletions(-)
create mode 100644 bsps/aarch64/xilinx-versal/console/console.c
create mode 100644 bsps/aarch64/xilinx-versal/dev/serial/versal-uart-polled.c
create mode 100644 bsps/aarch64/xilinx-versal/include/bsp.h
create mode 100644 bsps/aarch64/xilinx-versal/include/bsp/irq.h
create mode 100644 bsps/aarch64/xilinx-versal/include/dev/serial/versal-uart-regs.h
create mode 100644 bsps/aarch64/xilinx-versal/include/dev/serial/versal-uart.h
create mode 100644 bsps/aarch64/xilinx-versal/include/tm27.h
create mode 100644 bsps/aarch64/xilinx-versal/start/bspstart.c
create mode 100644 bsps/aarch64/xilinx-versal/start/bspstarthooks.c
create mode 100644 bsps/aarch64/xilinx-versal/start/bspstartmmu.c
create mode 100644 spec/build/bsps/aarch64/optgtuseps.yml
create mode 100644 spec/build/bsps/aarch64/optgtusevirt.yml
create mode 100644 spec/build/bsps/aarch64/optisns.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/abi.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/bspqemuilp32.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/bspqemulp64.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/bspvck190ilp32.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/bspvck190lp64.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/grp.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/grp_qemu.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/grp_vck190.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/obj.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optconminor.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optnocachelen.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optramlen.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optramori.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/tstvck190.yml
2.25.1
