[PATCH v2 1/7] aarch64/xilinx-versal: new BSPs for qemu and vck190
Gedare Bloom
gedare at rtems.org
Thu Jun 24 15:50:18 UTC 2021
bsps/aarch64/xilinx-versal/console/console.c | 134 ++++++++++
.../dev/serial/versal-uart-polled.c | 228 ++++++++++++++++++
bsps/aarch64/xilinx-versal/include/bsp.h | 81 +++++++
bsps/aarch64/xilinx-versal/include/bsp/irq.h | 70 ++++++
.../include/dev/serial/versal-uart-regs.h | 141 +++++++++++
.../include/dev/serial/versal-uart.h | 90 +++++++
bsps/aarch64/xilinx-versal/include/tm27.h | 45 ++++
bsps/aarch64/xilinx-versal/start/bspstart.c | 48 ++++
.../xilinx-versal/start/bspstarthooks.c | 51 ++++
.../aarch64/xilinx-versal/start/bspstartmmu.c | 77 ++++++
spec/build/bsps/aarch64/xilinx-versal/abi.yml | 22 ++
.../aarch64/xilinx-versal/bspqemuilp32.yml | 21 ++
.../aarch64/xilinx-versal/bspqemulp64.yml | 21 ++
.../aarch64/xilinx-versal/bspvck190ilp32.yml | 19 ++
.../aarch64/xilinx-versal/bspvck190lp64.yml | 19 ++
spec/build/bsps/aarch64/xilinx-versal/grp.yml | 50 ++++
.../bsps/aarch64/xilinx-versal/grp_vck190.yml | 18 ++
.../aarch64/xilinx-versal/linkcmds_ilp32.yml | 74 ++++++
.../aarch64/xilinx-versal/linkcmds_lp64.yml | 74 ++++++
spec/build/bsps/aarch64/xilinx-versal/obj.yml | 44 ++++
.../bsps/aarch64/xilinx-versal/optclkuart.yml | 20 ++
.../aarch64/xilinx-versal/optconminor.yml | 16 ++
.../bsps/aarch64/xilinx-versal/optloadoff.yml | 22 ++
.../aarch64/xilinx-versal/optnocachelen.yml | 18 ++
.../bsps/aarch64/xilinx-versal/optramlen.yml | 18 ++
.../bsps/aarch64/xilinx-versal/optramori.yml | 22 ++
.../bsps/aarch64/xilinx-versal/tstqemu.yml | 19 ++
.../bsps/aarch64/xilinx-versal/tstvck190.yml | 19 ++
28 files changed, 1481 insertions(+)
create mode 100644 bsps/aarch64/xilinx-versal/console/console.c
create mode 100644 bsps/aarch64/xilinx-versal/dev/serial/versal-uart-polled.c
create mode 100644 bsps/aarch64/xilinx-versal/include/bsp.h
create mode 100644 bsps/aarch64/xilinx-versal/include/bsp/irq.h
create mode 100644 bsps/aarch64/xilinx-versal/include/dev/serial/versal-uart-regs.h
create mode 100644 bsps/aarch64/xilinx-versal/include/dev/serial/versal-uart.h
create mode 100644 bsps/aarch64/xilinx-versal/include/tm27.h
create mode 100644 bsps/aarch64/xilinx-versal/start/bspstart.c
create mode 100644 bsps/aarch64/xilinx-versal/start/bspstarthooks.c
create mode 100644 bsps/aarch64/xilinx-versal/start/bspstartmmu.c
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/abi.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/bspqemuilp32.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/bspqemulp64.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/bspvck190ilp32.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/bspvck190lp64.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/grp.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/grp_vck190.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/obj.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optconminor.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optnocachelen.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optramlen.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/optramori.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-versal/tstvck190.yml
diff --git a/bsps/aarch64/xilinx-versal/console/console.c b/bsps/aarch64/xilinx-versal/console/console.c
new file mode 100644
index 0000000000..e7f752f1a7
--- /dev/null
+++ b/bsps/aarch64/xilinx-versal/console/console.c
@@ -0,0 +1,134 @@
+ * @file
+ * @ingroup RTEMSBSPsAArch64XilinxVersal
+ * @brief This source file contains this BSP's console configuration.
+ * Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <rtems/console.h>
+#include <rtems/bspIo.h>
+#include <rtems/sysinit.h>
+#include <bsp/irq.h>
+#include <dev/serial/versal-uart.h>
+#include <bspopts.h>
+static versal_uart_context versal_uart_instances[2] = {
+ .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Versal UART 0" ),
+ .regs = (volatile struct versal_uart *) 0xff000000,
+ .irq = VERSAL_IRQ_UART_0
+ .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Versal UART 1" ),
+ .regs = (volatile struct versal_uart *) 0xff010000,
+ .irq = VERSAL_IRQ_UART_1
+rtems_status_code console_initialize(
+ rtems_device_major_number major,
+ rtems_device_minor_number minor,
+ void *arg
+ size_t i;
+ rtems_termios_initialize();
+ for (i = 0; i < RTEMS_ARRAY_SIZE(versal_uart_instances); ++i) {
+ char uart[] = "/dev/ttySX";
+ uart[sizeof(uart) - 2] = (char) ('0' + i);
+ rtems_termios_device_install(
+ &uart[0],
+ &versal_uart_handler,
+ NULL,
+ &versal_uart_instances[i].base
+ if (i == BSP_CONSOLE_MINOR) {
+ link(&uart[0], CONSOLE_DEVICE_NAME);
+ return RTEMS_SUCCESSFUL;
+void versal_debug_console_flush(void)
+ versal_uart_reset_tx_flush(&versal_uart_instances[BSP_CONSOLE_MINOR].base);
+static void versal_debug_console_out(char c)
+ rtems_termios_device_context *base =
+ &versal_uart_instances[BSP_CONSOLE_MINOR].base;
+ versal_uart_write_polled(base, c);
+static void versal_debug_console_init(void)
+ (void) versal_uart_initialize(base);
+ BSP_output_char = versal_debug_console_out;
+static void versal_debug_console_early_init(char c)
+ versal_debug_console_out(c);
+static int versal_debug_console_in(void)
+ return versal_uart_read_polled(base);
+BSP_output_char_function_type BSP_output_char = versal_debug_console_early_init;
+BSP_polling_getchar_function_type BSP_poll_char = versal_debug_console_in;
+RTEMS_SYSINIT_ITEM(
+ versal_debug_console_init,
+ RTEMS_SYSINIT_BSP_START,
+ RTEMS_SYSINIT_ORDER_LAST_BUT_5
diff --git a/bsps/aarch64/xilinx-versal/dev/serial/versal-uart-polled.c b/bsps/aarch64/xilinx-versal/dev/serial/versal-uart-polled.c
index 0000000000..be46c99efd
--- /dev/null
+++ b/bsps/aarch64/xilinx-versal/dev/serial/versal-uart-polled.c
@@ -0,0 +1,228 @@
+ * are met:
+#include <dev/serial/versal-uart-regs.h>
+static inline volatile versal_uart *versal_uart_get_regs(
+ versal_uart_context *ctx = (versal_uart_context *) base;
+ return ctx->regs;
+ * Make weak and let the user override.
+uint32_t versal_uart_input_clock(void) __attribute__ ((weak));
+ return VERSAL_CLOCK_UART;
+int32_t versal_cal_baud_rate(
+ uint32_t baudrate,
+ uint32_t maxerror,
+ uint32_t *ibdiv,
+ uint32_t *fbdiv
+ uint32_t calcbaudrate;
+ uint32_t bauderror;
+ uint32_t percenterror;
+ uint32_t fbdivrnd;
+ uint32_t inputclk = versal_uart_input_clock();
+ * The baud rate cannot be larger than the UART clock / 16.
+ if ((baudrate * 16) > inputclk) {
+ return -1;
+ * The UART clock cannot be larger than 16*65535*baudrate.
+ * Could maybe use an estimate (inputclk / 2**16) to save a division.
+ * This invariant gets checked below, by ensuring ibdiv < 2**16.
+ * The UART clock cannot be more than 5/3 times faster than the LPD_LSBUS_CLK
+ * - TODO?
+ * The baud rate divisor is a 16-bit integer and 6-bit fractional part.
+ * It is equal to the UART clock / (16 * baudrate).
+ *ibdiv = inputclk / 16 / baudrate;
+ if ( *ibdiv > 1<<16 ) {
+ return -1;
+ * Find the fractional part. This can overflow with 32-bit arithmetic if
+ * inputclk > 536870911, so use 64-bit. Unfortunately, this means we have
+ * two 64-bit divisions here.
+ fbdivrnd = ((((uint64_t)inputclk / 16) << 7) / baudrate) & 0x1;
+ *fbdiv = (((((uint64_t)inputclk / 16) << 6) / baudrate) & 0x3F) + fbdivrnd;
+ * calculate the baudrate and check if the error is too large.
+ calcbaudrate = (((uint64_t)inputclk / 16) << 6) / ((*ibdiv << 6) | *fbdiv);
+ if (baudrate > calcbaudrate) {
+ bauderror = baudrate - calcbaudrate;
+ } else {
+ bauderror = calcbaudrate - baudrate;
+ percenterror = (bauderror * 100) / baudrate;
+ if (maxerror < percenterror) {
+ return -1;
+ return 0;
+int versal_uart_initialize(rtems_termios_device_context *base)
+ volatile versal_uart *regs = versal_uart_get_regs(base);
+ uint32_t maxerr = 3;
+ uint32_t ibauddiv = 0;
+ uint32_t fbauddiv = 0;
+ int rv;
+ versal_uart_reset_tx_flush(base);
+ rv = versal_cal_baud_rate(
+ VERSAL_UART_DEFAULT_BAUD,
+ maxerr,
+ &ibauddiv,
+ &fbauddiv
+ if ( rv < 0 ) {
+ return rv;
+ /* Line control: 8-bit word length, no parity, no FIFO, 1 stop bit */
+ regs->uartlcr_h = VERSAL_UARTLCR_H_WLEN( VERSAL_UARTLCR_H_WLEN_8 );
+ /* Control: receive, transmit, uart enable, no CTS, no RTS, no loopback */
+ regs->uartcr = VERSAL_UARTCR_RXE
+ | VERSAL_UARTCR_TXE
+ | VERSAL_UARTCR_UARTEN;
+ regs->uartibrd = VERSAL_UARTIBRD_BAUD_DIVINT(ibauddiv);
+ regs->uartfbrd = VERSAL_UARTFBRD_BAUD_DIVFRAC(fbauddiv);
+ return 0;
+static bool versal_uart_first_open(
+ struct rtems_termios_tty *tty,
+ rtems_termios_device_context *base,
+ struct termios *term,
+ rtems_libio_open_close_args_t *args
+ int rc = versal_uart_initialize(base);
+ if ( rc < 0 ) {
+ return false;
+ rtems_termios_set_initial_baud(tty, VERSAL_UART_DEFAULT_BAUD);
+ return true;
+int versal_uart_read_polled(rtems_termios_device_context *base)
+ if ((regs->uartfr & VERSAL_UARTFR_RXFE) != 0) {
+ return -1;
+ } else {
+ return VERSAL_UARTDR_DATA_GET(regs->uartdr);
+void versal_uart_write_polled(
+ char c
+ while ((regs->uartfr & VERSAL_UARTFR_TXFF) != 0) {
+ /* Wait while full */
+ regs->uartdr = VERSAL_UARTDR_DATA(c);
+void versal_uart_reset_tx_flush(rtems_termios_device_context *base)
+ int c = 4;
+ while (c-- > 0)
+ versal_uart_write_polled(base, '\r');
+ while ((regs->uartfr & VERSAL_UARTFR_TXFE) == 0) {
+ /* Wait for empty */
+static void versal_uart_write_support(
+ const char *s,
+ size_t n
+ size_t i;
+ for (i = 0; i < n; i++) {
+ versal_uart_write_polled(base, s[i]);
+const rtems_termios_device_handler versal_uart_handler = {
+ .first_open = versal_uart_first_open,
+ .write = versal_uart_write_support,
+ .poll_read = versal_uart_read_polled,
+ .mode = TERMIOS_POLLED
diff --git a/bsps/aarch64/xilinx-versal/include/bsp.h b/bsps/aarch64/xilinx-versal/include/bsp.h
index 0000000000..2017e10ade
--- /dev/null
+++ b/bsps/aarch64/xilinx-versal/include/bsp.h
@@ -0,0 +1,81 @@
+ * @file
+ * @brief This header file provides the core BSP definitions
+ * are met:
+#ifndef LIBBSP_AARCH64_XILINX_VERSAL_BSP_H
+#define LIBBSP_AARCH64_XILINX_VERSAL_BSP_H
+ * @addtogroup RTEMSBSPsAArch64
+#ifndef ASM
+#include <bsp/default-initial-extension.h>
+#include <bsp/start.h>
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#define BSP_ARM_GIC_CPUIF_BASE 0xf9040000
+#define BSP_ARM_GIC_DIST_BASE 0xf9000000
+#define BSP_ARM_GIC_REDIST_BASE 0xf9080000
+#define BSP_RESET_SMC
+ * @brief Versal specific set up of the MMU.
+ * Provide in the application to override the defaults in the BSP.
+BSP_START_TEXT_SECTION void versal_setup_mmu_and_cache(void);
+void versal_debug_console_flush(void);
+#ifdef __cplusplus
+#endif /* ASM */
+#endif /* LIBBSP_AARCH64_XILINX_VERSAL_BSP_H */
diff --git a/bsps/aarch64/xilinx-versal/include/bsp/irq.h b/bsps/aarch64/xilinx-versal/include/bsp/irq.h
index 0000000000..ec39b727d9
--- /dev/null
+++ b/bsps/aarch64/xilinx-versal/include/bsp/irq.h
@@ -0,0 +1,70 @@
+ * @file
+ * @brief This header file provides the BSP's IRQ definitions.
+ * Copyright (C) Gedare Bloom <gedare at rtems.org>
+ * are met:
+#ifndef LIBBSP_AARCH64_XILINX_VERSAL_IRQ_H
+#define LIBBSP_AARCH64_XILINX_VERSAL_IRQ_H
+#ifndef ASM
+#include <rtems/irq.h>
+#include <rtems/irq-extension.h>
+#include <dev/irq/arm-gic-irq.h>
+#ifdef __cplusplus
+extern "C" {
+#define BSP_INTERRUPT_VECTOR_COUNT 1024
+/* Interrupts vectors */
+#define BSP_TIMER_VIRT_PPI 27
+#define BSP_TIMER_PHYS_NS_PPI 30
+#define VERSAL_IRQ_UART_0 50
+#define VERSAL_IRQ_UART_1 51
+#define VERSAL_IRQ_ETHERNET_0 88
+#define VERSAL_IRQ_ETHERNET_0_WAKEUP 89
+#define VERSAL_IRQ_ETHERNET_1 90
+#define VERSAL_IRQ_ETHERNET_1_WAKEUP 91
+#ifdef __cplusplus
+#endif /* ASM */
+#endif /* LIBBSP_AARCH64_XILINX_VERSAL_IRQ_H */
diff --git a/bsps/aarch64/xilinx-versal/include/dev/serial/versal-uart-regs.h b/bsps/aarch64/xilinx-versal/include/dev/serial/versal-uart-regs.h
index 0000000000..59db8f950a
--- /dev/null
+++ b/bsps/aarch64/xilinx-versal/include/dev/serial/versal-uart-regs.h
@@ -0,0 +1,141 @@
+ * @file
+ * @ingroup versal_uart_regs
+ * @brief Xilinx Versal UART register definitions.
+ * are met:
+ * @defgroup versal_uart_regs Xilinx Versal UART Register Definitions
+ * @ingroup versal
+ * @brief Xilinx Versal UART Register Definitions
+#ifndef LIBBSP_ARM_XILINX_VERSAL_UART_REGS_H
+#define LIBBSP_ARM_XILINX_VERSAL_UART_REGS_H
+#include <bsp/utility.h>
+#define VERSAL_UART_FIFO_DEPTH 64
+typedef struct versal_uart {
+ uint32_t uartdr;
+#define VERSAL_UARTDR_OE BSP_BIT32(11)
+#define VERSAL_UARTDR_BE BSP_BIT32(10)
+#define VERSAL_UARTDR_PE BSP_BIT32(9)
+#define VERSAL_UARTDR_FE BSP_BIT32(8)
+#define VERSAL_UARTDR_DATA(val) BSP_FLD32(val, 0, 7)
+#define VERSAL_UARTDR_DATA_GET(reg) BSP_FLD32GET(reg, 0, 7)
+#define VERSAL_UARTDR_DATA_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
+ uint32_t uartrsr_uartecr;
+#define VERSAL_UARTRSR_UARTECR_OE BSP_BIT32(3)
+#define VERSAL_UARTRSR_UARTECR_BE BSP_BIT32(2)
+#define VERSAL_UARTRSR_UARTECR_PE BSP_BIT32(1)
+#define VERSAL_UARTRSR_UARTECR_FE BSP_BIT32(0)
+ uint32_t reserved_08[4];
+ uint32_t uartfr;
+#define VERSAL_UARTFR_RI BSP_BIT32(8)
+#define VERSAL_UARTFR_TXFE BSP_BIT32(7)
+#define VERSAL_UARTFR_RXFF BSP_BIT32(6)
+#define VERSAL_UARTFR_TXFF BSP_BIT32(5)
+#define VERSAL_UARTFR_RXFE BSP_BIT32(4)
+#define VERSAL_UARTFR_BUSY BSP_BIT32(3)
+#define VERSAL_UARTFR_DCD BSP_BIT32(2)
+#define VERSAL_UARTFR_DSR BSP_BIT32(1)
+#define VERSAL_UARTFR_CTS BSP_BIT32(0)
+ uint32_t reserved_1c;
+ uint32_t uartilpr;
+#define VERSAL_UARTILPR_ILPDVSR(val) BSP_FLD32(val, 0, 7)
+#define VERSAL_UARTILPR_ILPDVSR_GET(reg) BSP_FLD32GET(reg, 0, 7)
+#define VERSAL_UARTILPR_ILPDVSR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
+ uint32_t uartibrd;
+#define VERSAL_UARTIBRD_BAUD_DIVINT(val) BSP_FLD32(val, 0, 15)
+#define VERSAL_UARTIBRD_BAUD_DIVINT_GET(reg) BSP_FLD32GET(reg, 0, 15)
+#define VERSAL_UARTIBRD_BAUD_DIVINT_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
+ uint32_t uartfbrd;
+#define VERSAL_UARTFBRD_BAUD_DIVFRAC(val) BSP_FLD32(val, 0, 5)
+#define VERSAL_UARTFBRD_BAUD_DIVFRAC_GET(reg) BSP_FLD32GET(reg, 0, 5)
+#define VERSAL_UARTFBRD_BAUD_DIVFRAC_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)
+ uint32_t uartlcr_h;
+#define VERSAL_UARTLCR_H_SPS BSP_BIT32(7)
+#define VERSAL_UARTLCR_H_WLEN(val) BSP_FLD32(val, 5, 6)
+#define VERSAL_UARTLCR_H_WLEN_GET(reg) BSP_FLD32GET(reg, 5, 6)
+#define VERSAL_UARTLCR_H_WLEN_SET(reg, val) BSP_FLD32SET(reg, val, 5, 6)
+#define VERSAL_UARTLCR_H_WLEN_5 0x00U
+#define VERSAL_UARTLCR_H_WLEN_6 0x01U
+#define VERSAL_UARTLCR_H_WLEN_7 0x02U
+#define VERSAL_UARTLCR_H_WLEN_8 0x03U
+#define VERSAL_UARTLCR_H_FEN BSP_BIT32(4)
+#define VERSAL_UARTLCR_H_STP2 BSP_BIT32(3)
+#define VERSAL_UARTLCR_H_EPS BSP_BIT32(2)
+#define VERSAL_UARTLCR_H_PEN BSP_BIT32(1)
+#define VERSAL_UARTLCR_H_BRK BSP_BIT32(0)
+ uint32_t uartcr;
+#define VERSAL_UARTCR_CTSEN BSP_BIT32(15)
+#define VERSAL_UARTCR_RTSEN BSP_BIT32(14)
+#define VERSAL_UARTCR_OUT2 BSP_BIT32(13)
+#define VERSAL_UARTCR_OUT1 BSP_BIT32(12)
+#define VERSAL_UARTCR_RTS BSP_BIT32(11)
+#define VERSAL_UARTCR_DTR BSP_BIT32(10)
+#define VERSAL_UARTCR_RXE BSP_BIT32(9)
+#define VERSAL_UARTCR_TXE BSP_BIT32(8)
+#define VERSAL_UARTCR_LBE BSP_BIT32(7)
+//#define VERSAL_UARTCR_SIREN BSP_BIT32()?
+#define VERSAL_UARTCR_UARTEN BSP_BIT32(0)
+ uint32_t uartifls;
+#define VERSAL_UARTIFLS_RXIFLSEL(val) BSP_FLD32(val, 3, 5)
+#define VERSAL_UARTIFLS_RXIFLSEL_GET(reg) BSP_FLD32GET(reg, 3, 5)
+#define VERSAL_UARTIFLS_RXIFLSEL_SET(reg, val) BSP_FLD32SET(reg, val, 3, 5)
+#define VERSAL_UARTIFLS_TXIFLSEL(val) BSP_FLD32(val, 0, 2)
+#define VERSAL_UARTIFLS_TXIFLSEL_GET(reg) BSP_FLD32GET(reg, 0, 2)
+#define VERSAL_UARTIFLS_TXIFLSEL_SET(reg, val) BSP_FLD32SET(reg, val, 0, 2)
+ uint32_t uartimsc;
+ uint32_t uartris;
+ uint32_t uartmis;
+ uint32_t uarticr;
+#define VERSAL_UARTI_OEI BSP_BIT32(10)
+#define VERSAL_UARTI_BEI BSP_BIT32(9)
+#define VERSAL_UARTI_PEI BSP_BIT32(8)
+#define VERSAL_UARTI_FEI BSP_BIT32(7)
+#define VERSAL_UARTI_RTI BSP_BIT32(6)
+#define VERSAL_UARTI_TXI BSP_BIT32(5)
+#define VERSAL_UARTI_RXI BSP_BIT32(4)
+#define VERSAL_UARTI_DSRMI BSP_BIT32(3)
+#define VERSAL_UARTI_DCDMI BSP_BIT32(2)
+#define VERSAL_UARTI_CTSMI BSP_BIT32(1)
+#define VERSAL_UARTI_RIMI BSP_BIT32(0)
+} versal_uart;
+#endif /* LIBBSP_ARM_XILINX_ZYNQ_UART_REGS_H */
diff --git a/bsps/aarch64/xilinx-versal/include/dev/serial/versal-uart.h b/bsps/aarch64/xilinx-versal/include/dev/serial/versal-uart.h
index 0000000000..95b5172218
--- /dev/null
+++ b/bsps/aarch64/xilinx-versal/include/dev/serial/versal-uart.h
@@ -0,0 +1,90 @@
+ * @file
+ * @brief Xilinx Versal UART support.
+ * are met:
+#ifndef LIBBSP_ARM_XILINX_VERSAL_UART_H
+#define LIBBSP_ARM_XILINX_VERSAL_UART_H
+#include <rtems/termiostypes.h>
+#ifdef __cplusplus
+extern "C" {
+ * @defgroup versal_uart Xilinx Versal UART Support
+ * @ingroup RTEMSBSPsARMVersal
+ * @brief UART Support
+ * This driver operates an instance of the Xilinx UART present in the
+ * family of Xilinx Versal SoCs.
+typedef struct {
+ rtems_termios_device_context base;
+ volatile struct versal_uart *regs;
+ bool transmitting; /* Currently unused */
+ rtems_vector_number irq;
+} versal_uart_context;
+extern const rtems_termios_device_handler versal_uart_handler;
+#define VERSAL_UART_DEFAULT_BAUD 115200
+int versal_uart_initialize(rtems_termios_device_context *base);
+int versal_uart_read_polled(rtems_termios_device_context *base);
+ char c
+ * Flush TX FIFO and wait until it is empty.
+void versal_uart_reset_tx_flush(rtems_termios_device_context *base);
+int versal_cal_baud_rate(
+ uint32_t* ibdiv,
+ uint32_t* fbdiv
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_XILINX_VERSAL_UART_H */
diff --git a/bsps/aarch64/xilinx-versal/include/tm27.h b/bsps/aarch64/xilinx-versal/include/tm27.h
index 0000000000..acf26a255d
--- /dev/null
+++ b/bsps/aarch64/xilinx-versal/include/tm27.h
@@ -0,0 +1,45 @@
+ * @file
+ * @brief This header file provides functionality for the tm27 test.
+ * are met:
+#ifndef _RTEMS_TMTEST27
+#error "This is an RTEMS internal file you must not include directly."
+#endif
+#ifndef __tm27_h
+#define __tm27_h
+#include <dev/irq/arm-gic-tm27.h>
+#endif /* __tm27_h */
diff --git a/bsps/aarch64/xilinx-versal/start/bspstart.c b/bsps/aarch64/xilinx-versal/start/bspstart.c
index 0000000000..2f0048ddf3
--- /dev/null
+++ b/bsps/aarch64/xilinx-versal/start/bspstart.c
@@ -0,0 +1,48 @@
+ * @file
+ * @brief This source file contains the implementation of bsp_start().
+ * are met:
+#include <bsp.h>
+#include <bsp/bootcard.h>
+#include <bsp/irq-generic.h>
+#include <bsp/linker-symbols.h>
+void bsp_start( void )
+ bsp_interrupt_initialize();
+ rtems_cache_coherent_add_area(
+ bsp_section_nocacheheap_begin,
+ (uintptr_t) bsp_section_nocacheheap_size
diff --git a/bsps/aarch64/xilinx-versal/start/bspstarthooks.c b/bsps/aarch64/xilinx-versal/start/bspstarthooks.c
index 0000000000..be98675a24
--- /dev/null
+++ b/bsps/aarch64/xilinx-versal/start/bspstarthooks.c
@@ -0,0 +1,51 @@
+ * @file
+ * @brief This source file contains the implementation of this BSP's startup
+ * hooks.
+ * are met:
+#include <bsp.h>
+BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
+ /* Do nothing */
+BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
+ AArch64_start_set_vector_base();
+ bsp_start_copy_sections();
+ versal_setup_mmu_and_cache();
+ bsp_start_clear_bss();
diff --git a/bsps/aarch64/xilinx-versal/start/bspstartmmu.c b/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
index 0000000000..6ab33cc4f1
--- /dev/null
+++ b/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
@@ -0,0 +1,77 @@
+ * @file
+ * @brief This source file contains the default MMU tables and setup.
+ * are met:
+#include <bsp.h>
+#include <bsp/aarch64-mmu.h>
+BSP_START_DATA_SECTION static const aarch64_mmu_config_entry
+versal_mmu_config_table[] = {
+ AARCH64_MMU_DEFAULT_SECTIONS,
+ { /* APU GIC */
+ .begin = 0xf9000000U,
+ .end = 0xf90c0000U,
+ .flags = AARCH64_MMU_DEVICE
+ }, { /* FPD CSRs */
+ .begin = 0xfd000000U,
+ .end = 0xfe000000U,
+ }, { /* LPD CSRs */
+ .begin = 0xfe000000U,
+ .end = 0xfe800000U,
+ }, { /* LPD IOP CSRs and LPD peripherals */
+ .begin = 0xff000000U,
+ .end = 0xffc00000U,
+versal_setup_mmu_and_cache( void ) __attribute__ ((weak));
+ aarch64_mmu_setup();
+ aarch64_mmu_setup_translation_table_and_enable(
+ &versal_mmu_config_table[ 0 ],
+ RTEMS_ARRAY_SIZE( versal_mmu_config_table )
diff --git a/spec/build/bsps/aarch64/xilinx-versal/abi.yml b/spec/build/bsps/aarch64/xilinx-versal/abi.yml
index 0000000000..67340ffa08
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/abi.yml
@@ -0,0 +1,22 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-string: null
+- split: null
+- env-append: null
+build-type: option
+copyrights:
+- Copyright (C) 2021 Gedare Bloom
+default:
+- -mcpu=cortex-a72
+default-by-variant:
+- value:
+ - -mcpu=cortex-a72
+ - -mabi=ilp32
+ variants:
+ - aarch64/xilinx_versal_ilp32_qemu
+description: |
+ ABI flags
+enabled-by: true
+links: []
+name: ABI_FLAGS
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/bspqemuilp32.yml b/spec/build/bsps/aarch64/xilinx-versal/bspqemuilp32.yml
index 0000000000..85d508a6f4
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/bspqemuilp32.yml
@@ -0,0 +1,21 @@
+arch: aarch64
+bsp: xilinx_versal_ilp32_qemu
+build-type: bsp
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+family: xilinx-versal
+includes: []
+install: []
+links:
+- role: build-dependency
+ uid: grp
+ uid: tstqemu
+ uid: linkcmds_ilp32
+source: []
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/bspqemulp64.yml b/spec/build/bsps/aarch64/xilinx-versal/bspqemulp64.yml
index 0000000000..5df2483d34
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/bspqemulp64.yml
@@ -0,0 +1,21 @@
+arch: aarch64
+bsp: xilinx_versal_lp64_qemu
+build-type: bsp
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+install: []
+links:
+ uid: grp
+ uid: tstqemu
+ uid: linkcmds_lp64
+source: []
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/bspvck190ilp32.yml b/spec/build/bsps/aarch64/xilinx-versal/bspvck190ilp32.yml
index 0000000000..741b28c6e8
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/bspvck190ilp32.yml
@@ -0,0 +1,19 @@
+arch: aarch64
+bsp: xilinx_versal_ilp32_vck190
+build-type: bsp
+cflags: []
+copyrights:
+- Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
+cppflags: []
+enabled-by: true
+includes: []
+install: []
+links:
+ uid: grp_vck190
+source: []
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/bspvck190lp64.yml b/spec/build/bsps/aarch64/xilinx-versal/bspvck190lp64.yml
index 0000000000..b33a10f8f0
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/bspvck190lp64.yml
@@ -0,0 +1,19 @@
+arch: aarch64
+bsp: xilinx_versal_lp64_vck190
+build-type: bsp
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+install: []
+links:
+ uid: grp_vck190
+source: []
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/grp.yml b/spec/build/bsps/aarch64/xilinx-versal/grp.yml
index 0000000000..7c7dea0fef
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/grp.yml
@@ -0,0 +1,50 @@
+build-type: group
+copyrights:
+enabled-by: true
+includes: []
+install: []
+ldflags: []
+links:
+ uid: ../grp
+ uid: ../start
+ uid: ../optmmupages
+ uid: abi
+ uid: obj
+ uid: optloadoff
+ uid: optnocachelen
+ uid: optramlen
+ uid: optramori
+ uid: optclkuart
+ uid: optconminor
+ uid: ../../obj
+ uid: ../../objirq
+ uid: ../../objdevspizynq
+ uid: ../../objdevspixil
+ uid: ../../optcachedata
+ uid: ../../optcacheinst
+ uid: ../../opto2
+ uid: ../../bspopts
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/bsps/aarch64/xilinx-versal/grp_vck190.yml b/spec/build/bsps/aarch64/xilinx-versal/grp_vck190.yml
index 0000000000..c10f2a725f
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/grp_vck190.yml
@@ -0,0 +1,18 @@
+build-type: group
+copyrights:
+enabled-by: true
+includes: []
+install: []
+ldflags: []
+links:
+ uid: grp
+ uid: ../../optstarthyp
+ uid: tstvck190
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml b/spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml
index 0000000000..3030fd0ae9
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml
@@ -0,0 +1,74 @@
+build-type: config-file
+content: |
+ /* SPDX-License-Identifier: BSD-2-Clause */
+ * are met:
+ MEMORY {
+ RAM : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_LOAD_OFFSET}, LENGTH = ${BSP_XILINX_VERSAL_RAM_LENGTH} - ${BSP_XILINX_VERSAL_LOAD_OFFSET} - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH} - (0x4000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES})
+ NOCACHE : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_RAM_LENGTH} - (0x4000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}) - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH}, LENGTH = ${BSP_XILINX_VERSAL_NOCACHE_LENGTH}
+ RAM_MMU : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_RAM_LENGTH} - (0x4000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}), LENGTH = 0x4000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}
+ REGION_ALIAS ("REGION_START", RAM);
+ REGION_ALIAS ("REGION_VECTOR", RAM);
+ REGION_ALIAS ("REGION_TEXT", RAM);
+ REGION_ALIAS ("REGION_TEXT_LOAD", RAM);
+ REGION_ALIAS ("REGION_RODATA", RAM);
+ REGION_ALIAS ("REGION_RODATA_LOAD", RAM);
+ REGION_ALIAS ("REGION_DATA", RAM);
+ REGION_ALIAS ("REGION_DATA_LOAD", RAM);
+ REGION_ALIAS ("REGION_FAST_TEXT", RAM);
+ REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
+ REGION_ALIAS ("REGION_FAST_DATA", RAM);
+ REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
+ REGION_ALIAS ("REGION_BSS", RAM);
+ REGION_ALIAS ("REGION_WORK", RAM);
+ REGION_ALIAS ("REGION_STACK", RAM);
+ REGION_ALIAS ("REGION_NOCACHE", NOCACHE);
+ REGION_ALIAS ("REGION_NOCACHE_LOAD", NOCACHE);
+ bsp_stack_exception_size = DEFINED (bsp_stack_exception_size) ? bsp_stack_exception_size : 1024;
+ bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1M;
+ bsp_vector_table_in_start_section = 1;
+ bsp_translation_table_base = ORIGIN (RAM_MMU);
+ bsp_translation_table_end = ORIGIN (RAM_MMU) + LENGTH (RAM_MMU);
+ OUTPUT_FORMAT ("elf32-littleaarch64")
+ OUTPUT_ARCH (aarch64:ilp32)
+ INCLUDE linkcmds.base
+copyrights:
+enabled-by: true
+install-path: ${BSP_LIBDIR}
+links: []
+target: linkcmds
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml b/spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml
index 0000000000..bd5d1f791b
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml
@@ -0,0 +1,74 @@
+content: |
+ * are met:
+ MEMORY {
+ OUTPUT_FORMAT ("elf64-littleaarch64")
+ OUTPUT_ARCH (aarch64)
+copyrights:
+enabled-by: true
+links: []
+target: linkcmds
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/obj.yml b/spec/build/bsps/aarch64/xilinx-versal/obj.yml
index 0000000000..79e7000b52
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/obj.yml
@@ -0,0 +1,44 @@
+build-type: objects
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+install:
+- destination: ${BSP_INCLUDEDIR}
+ source:
+ - bsps/aarch64/xilinx-versal/include/bsp.h
+ - bsps/aarch64/xilinx-versal/include/tm27.h
+- destination: ${BSP_INCLUDEDIR}/bsp
+ source:
+ - bsps/aarch64/xilinx-versal/include/bsp/irq.h
+ - bsps/aarch64/include/bsp/aarch64-mmu.h
+- destination: ${BSP_INCLUDEDIR}/dev/serial
+ source:
+ - bsps/aarch64/xilinx-versal/include/dev/serial/versal-uart-regs.h
+ - bsps/aarch64/xilinx-versal/include/dev/serial/versal-uart.h
+links: []
+source:
+- bsps/aarch64/shared/cache/cache.c
+- bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
+- bsps/aarch64/xilinx-versal/console/console.c
+- bsps/aarch64/xilinx-versal/dev/serial/versal-uart-polled.c
+- bsps/aarch64/xilinx-versal/start/bspstart.c
+- bsps/aarch64/xilinx-versal/start/bspstarthooks.c
+- bsps/aarch64/xilinx-versal/start/bspstartmmu.c
+- bsps/shared/dev/btimer/btimer-cpucounter.c
+- bsps/shared/dev/clock/arm-generic-timer.c
+- bsps/shared/dev/getentropy/getentropy-cpucounter.c
+- bsps/shared/dev/irq/arm-gicv3.c
+- bsps/shared/dev/serial/console-termios-init.c
+- bsps/shared/dev/serial/console-termios.c
+- bsps/shared/irq/irq-default-handler.c
+- bsps/shared/start/bspfatal-default.c
+- bsps/shared/start/bspgetworkarea-default.c
+- bsps/shared/start/bspreset-arm-psci.c
+- bsps/shared/start/gettargethash-default.c
+- bsps/shared/start/sbrk.c
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml b/spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml
index 0000000000..4ba449b8fd
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml
@@ -0,0 +1,20 @@
+actions:
+- get-integer: null
+- define: null
+build-type: option
+copyrights:
+default: 24000000
+- value: 100000000
+ variants:
+ - aarch64/xilinx_versal_ilp32.*
+ - aarch64/xilinx_versal_lp64.*
+description: |
+ Versal UART clock frequency in Hz
+enabled-by: true
+format: '{}'
+links: []
+name: VERSAL_CLOCK_UART
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/optconminor.yml b/spec/build/bsps/aarch64/xilinx-versal/optconminor.yml
index 0000000000..bb21e8fae7
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/optconminor.yml
@@ -0,0 +1,16 @@
+actions:
+- define: null
+build-type: option
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+default: 0
+default-by-variant: []
+description: |
+ minor number of console device
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_CONSOLE_MINOR
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml b/spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml
index 0000000000..41023dcf3e
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml
@@ -0,0 +1,22 @@
+actions:
+- assert-uint32: null
+- env-assign: null
+- format-and-define: null
+build-type: option
+copyrights:
+default: 32768
+- value: 0x0
+ variants:
+ - aarch64/xilinx_versal_lp64_vck190
+ - aarch64/xilinx_versal_ilp32_vck190
+description: |
+ offset of RAM region from memory area base
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_XILINX_VERSAL_LOAD_OFFSET
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/optnocachelen.yml b/spec/build/bsps/aarch64/xilinx-versal/optnocachelen.yml
index 0000000000..97c1c8bfab
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/optnocachelen.yml
@@ -0,0 +1,18 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default: 0x100000
+description: |
+ length of nocache RAM region
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_XILINX_VERSAL_NOCACHE_LENGTH
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/optramlen.yml b/spec/build/bsps/aarch64/xilinx-versal/optramlen.yml
index 0000000000..ebc36d3139
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/optramlen.yml
@@ -0,0 +1,18 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default: 0x10000000
+description: |
+ length of memory area available to the BSP
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_XILINX_VERSAL_RAM_LENGTH
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/optramori.yml b/spec/build/bsps/aarch64/xilinx-versal/optramori.yml
index 0000000000..8ab8f5bc13
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/optramori.yml
@@ -0,0 +1,22 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default: 0x20000000
+- value: 0x10000000
+ variants:
+description: |
+ base address of memory area available to the BSP
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_XILINX_VERSAL_RAM_BASE
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml b/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
index 0000000000..8828185cd8
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
@@ -0,0 +1,19 @@
+actions:
+- set-test-state:
+ # expected to fail
+ minimum: exclude
+ # don't compile due to toolchain issues, see RTEMS issue #4218
+ spconfig01: exclude
+ spmisc01: exclude
+build-type: option
+copyrights:
+default: null
+description: ''
+enabled-by: true
+links: []
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/tstvck190.yml b/spec/build/bsps/aarch64/xilinx-versal/tstvck190.yml
index 0000000000..4f9a21e9d7
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/tstvck190.yml
@@ -0,0 +1,19 @@
+actions:
+- set-test-state:
+ # expected to produce a fatal-error when run
+ minimum: exclude
+ spmisc01: exclude
+build-type: option
+copyrights:
+default: null
+description: ''
+enabled-by: true
+links: []
+type: build
2.25.1
