[PATCH rtems-libbsd] aarch64/nexus: add GEM definitions for Versal
Gedare Bloom
gedare at rtems.org
Fri Jun 25 18:44:30 UTC 2021
rtemsbsd/include/bsp/nexus-devices.h | 7 +++++++
rtemsbsd/include/machine/rtems-bsd-nexus-bus.h | 11 +++++++++++
2 files changed, 18 insertions(+)
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index efe4fcb4..e6487470 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -115,6 +115,13 @@ RTEMS_BSD_DRIVER_E1000PHY;
RTEMS_BSD_DRIVER_XILINX_ZYNQMP_CGEM0(ZYNQMP_IRQ_ETHERNET_0);
+#elif defined(LIBBSP_AARCH64_XILINX_VERSAL_BSP_H)
+#include <bsp/irq.h>
+RTEMS_BSD_DRIVER_XILINX_VERSAL_GEM0(VERSAL_IRQ_ETHERNET_0);
+RTEMS_BSD_DRIVER_E1000PHY;
#elif defined(LIBBSP_ARM_ATSAM_BSP_H)
RTEMS_BSD_DRIVER_USB;
diff --git a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
index 5902c58c..2c013ef3 100644
--- a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
+++ b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
@@ -409,6 +409,17 @@ extern "C" {
#define RTEMS_BSD_DRIVER_XILINX_ZYNQMP_CGEM3(_irq) \
RTEMS_BSD_DRIVER_XILINX_ZYNQ_CGEM(3, 0xff0e0000, _irq)
#endif /* RTEMS_BSD_DRIVER_XILINX_ZYNQMP_CGEM3 */
+ * Versal has a similar GEM as the CGEM. This should work for now.
+#if !defined(RTEMS_BSD_DRIVER_XILINX_VERSAL_GEM0)
+ #define RTEMS_BSD_DRIVER_XILINX_VERSAL_GEM0(_irq) \
+ RTEMS_BSD_DRIVER_XILINX_ZYNQ_GEM(0, 0xff0c0000, _irq)
+#endif /* RTEMS_BSD_DRIVER_XILINX_VERSAL_GEM0 */
+#if !defined(RTEMS_BSD_DRIVER_XILINX_VERSAL_GEM1)
+ #define RTEMS_BSD_DRIVER_XILINX_VERSAL_GEM1(_irq) \
+ RTEMS_BSD_DRIVER_XILINX_ZYNQ_GEM(1, 0xff0d0000, _irq)
+#endif /* RTEMS_BSD_DRIVER_XILINX_VERSAL_GEM1 */
* Designware/Synopsys Ethernet MAC Controller.
2.25.1
