[PATCH v2] bsps/arm: Move optfdt* files to shared parent directory
pranav dangipranav at gmail.com
Sun Jun 27 20:46:01 UTC 2021
 .../arm/altera-cyclone-v/bspalteracyclonev.yml   |  8 ++++----
 spec/build/bsps/arm/beagle/grp.yml               |  8 ++++----
 spec/build/bsps/arm/beagle/optfdtcpyro.yml       | 15 ---------------
 spec/build/bsps/arm/beagle/optfdtmxsz.yml        | 16 ----------------
 spec/build/bsps/arm/beagle/optfdtro.yml          | 15 ---------------
 spec/build/bsps/arm/beagle/optfdtuboot.yml       | 15 ---------------
 spec/build/bsps/arm/imx/bspimx.yml               |  8 ++++----
 spec/build/bsps/arm/imx/optfdtcpyro.yml          | 15 ---------------
 spec/build/bsps/arm/imx/optfdtmxsz.yml           | 16 ----------------
 spec/build/bsps/arm/imx/optfdtro.yml             | 15 ---------------
 spec/build/bsps/arm/imx/optfdtuboot.yml          | 15 ---------------
 .../arm/{altera-cyclone-v => }/optfdtcpyro.yml   |  0
 .../arm/{altera-cyclone-v => }/optfdtmxsz.yml    |  0
 .../bsps/arm/{altera-cyclone-v => }/optfdtro.yml |  0
 .../arm/{altera-cyclone-v => }/optfdtuboot.yml   |  0
 spec/build/bsps/arm/raspberrypi/grp.yml          |  8 ++++++++
 16 files changed, 20 insertions(+), 134 deletions(-)
 delete mode 100644 spec/build/bsps/arm/beagle/optfdtcpyro.yml
 delete mode 100644 spec/build/bsps/arm/beagle/optfdtmxsz.yml
 delete mode 100644 spec/build/bsps/arm/beagle/optfdtro.yml
 delete mode 100644 spec/build/bsps/arm/beagle/optfdtuboot.yml
 delete mode 100644 spec/build/bsps/arm/imx/optfdtcpyro.yml
 delete mode 100644 spec/build/bsps/arm/imx/optfdtmxsz.yml
 delete mode 100644 spec/build/bsps/arm/imx/optfdtro.yml
 delete mode 100644 spec/build/bsps/arm/imx/optfdtuboot.yml
 rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtcpyro.yml (100%)
 rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtmxsz.yml (100%)
 rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtro.yml (100%)
 rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtuboot.yml (100%)
diff --git a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
index da567ddd79..faf7203cd4 100644
--- a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
+++ b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
@@ -73,15 +73,15 @@ links:
 - role: build-dependency
   uid: optconuart1
-  uid: optfdtcpyro
+  uid: ../optfdtcpyro
   uid: optfdten
-  uid: optfdtmxsz
+  uid: ../optfdtmxsz
-  uid: optfdtro
+  uid: ../optfdtro
-  uid: optfdtuboot
+  uid: ../optfdtuboot
   uid: opti2cspeed
diff --git a/spec/build/bsps/arm/beagle/grp.yml b/spec/build/bsps/arm/beagle/grp.yml
index 1375913fd0..20fafa79a0 100644
--- a/spec/build/bsps/arm/beagle/grp.yml
+++ b/spec/build/bsps/arm/beagle/grp.yml
@@ -22,13 +22,13 @@ links:
   uid: optdm3730
-  uid: optfdtcpyro
-  uid: optfdtmxsz
-  uid: optfdtro
+  uid: ../optfdtro
-  uid: optfdtuboot
   uid: ../grp
diff --git a/spec/build/bsps/arm/beagle/optfdtcpyro.yml b/spec/build/bsps/arm/beagle/optfdtcpyro.yml
deleted file mode 100644
index c26b1ae051..0000000000
--- a/spec/build/bsps/arm/beagle/optfdtcpyro.yml
+++ /dev/null
@@ -1,15 +0,0 @@
-SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
-actions:
-- get-boolean: null
-- define-condition: null
-build-type: option
-copyrights:
-- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
-default: true
-default-by-variant: []
-description: |
-  copy the FDT blob into the read-only load area via bsp_fdt_copy()
-enabled-by: true
-links: []
-name: BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA
-type: build
diff --git a/spec/build/bsps/arm/beagle/optfdtmxsz.yml b/spec/build/bsps/arm/beagle/optfdtmxsz.yml
index 14af766230..0000000000
--- a/spec/build/bsps/arm/beagle/optfdtmxsz.yml
+++ /dev/null
@@ -1,16 +0,0 @@
-actions:
-- get-integer: null
-- define: null
-build-type: option
-copyrights:
-default: 262144
-description: |
-  maximum size of the FDT blob in bytes
-enabled-by: true
-format: '{}'
-links: []
-name: BSP_FDT_BLOB_SIZE_MAX
-type: build
diff --git a/spec/build/bsps/arm/beagle/optfdtro.yml b/spec/build/bsps/arm/beagle/optfdtro.yml
index a61bb2924b..0000000000
--- a/spec/build/bsps/arm/beagle/optfdtro.yml
+++ /dev/null
@@ -1,15 +0,0 @@
-actions:
-build-type: option
-copyrights:
-default: true
-description: |
-  place the FDT blob into the read-only data area
-enabled-by: true
-links: []
-name: BSP_FDT_BLOB_READ_ONLY
-type: build
diff --git a/spec/build/bsps/arm/beagle/optfdtuboot.yml b/spec/build/bsps/arm/beagle/optfdtuboot.yml
index 5805e912ff..0000000000
--- a/spec/build/bsps/arm/beagle/optfdtuboot.yml
+++ /dev/null
@@ -1,15 +0,0 @@
-actions:
-build-type: option
-copyrights:
-default: true
-description: |
-  copy the U-Boot provided FDT to an internal storage
-enabled-by: true
-links: []
-name: BSP_START_COPY_FDT_FROM_U_BOOT
-type: build
diff --git a/spec/build/bsps/arm/imx/bspimx.yml b/spec/build/bsps/arm/imx/bspimx.yml
index c65e02db2b..faaca77e63 100644
--- a/spec/build/bsps/arm/imx/bspimx.yml
+++ b/spec/build/bsps/arm/imx/bspimx.yml
@@ -61,13 +61,13 @@ links:
   uid: optconirq
-  uid: optfdtcpyro
-  uid: optfdtmxsz
-  uid: optfdtro
+  uid: ../optfdtro
-  uid: optfdtuboot
   uid: optresetvec
diff --git a/spec/build/bsps/arm/imx/optfdtcpyro.yml b/spec/build/bsps/arm/imx/optfdtcpyro.yml
--- a/spec/build/bsps/arm/imx/optfdtcpyro.yml
+++ /dev/null
@@ -1,15 +0,0 @@
-actions:
-build-type: option
-copyrights:
-default: true
-description: |
-enabled-by: true
-links: []
-type: build
diff --git a/spec/build/bsps/arm/imx/optfdtmxsz.yml b/spec/build/bsps/arm/imx/optfdtmxsz.yml
--- a/spec/build/bsps/arm/imx/optfdtmxsz.yml
+++ /dev/null
@@ -1,16 +0,0 @@
-actions:
-- define: null
-build-type: option
-copyrights:
-default: 262144
-description: |
-enabled-by: true
-format: '{}'
-links: []
-type: build
diff --git a/spec/build/bsps/arm/imx/optfdtro.yml b/spec/build/bsps/arm/imx/optfdtro.yml
--- a/spec/build/bsps/arm/imx/optfdtro.yml
+++ /dev/null
@@ -1,15 +0,0 @@
-actions:
-build-type: option
-copyrights:
-default: true
-description: |
-enabled-by: true
-links: []
-type: build
diff --git a/spec/build/bsps/arm/imx/optfdtuboot.yml b/spec/build/bsps/arm/imx/optfdtuboot.yml
--- a/spec/build/bsps/arm/imx/optfdtuboot.yml
+++ /dev/null
@@ -1,15 +0,0 @@
-actions:
-build-type: option
-copyrights:
-default: true
-description: |
-enabled-by: true
-links: []
-type: build
diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml b/spec/build/bsps/arm/optfdtcpyro.yml
similarity index 100%
rename from spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml
rename to spec/build/bsps/arm/optfdtcpyro.yml
diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml b/spec/build/bsps/arm/optfdtmxsz.yml
rename from spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml
rename to spec/build/bsps/arm/optfdtmxsz.yml
diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml b/spec/build/bsps/arm/optfdtro.yml
rename from spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml
rename to spec/build/bsps/arm/optfdtro.yml
diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml b/spec/build/bsps/arm/optfdtuboot.yml
rename from spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml
rename to spec/build/bsps/arm/optfdtuboot.yml
diff --git a/spec/build/bsps/arm/raspberrypi/grp.yml b/spec/build/bsps/arm/raspberrypi/grp.yml
index 7291e8b178..e6b0a1cf75 100644
--- a/spec/build/bsps/arm/raspberrypi/grp.yml
+++ b/spec/build/bsps/arm/raspberrypi/grp.yml
@@ -31,6 +31,14 @@ links:
   uid: optrpi2
   uid: optspiiomode
+- role: build-dependency
+  uid: ../optfdtro
   uid: ../start
2.27.0
